Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 03-20-2012, 12:10 AM   #176
Captainfab
60-66 Nut
Re: Camaro Caliper Brackets
Yes I currently have a few sets. PM sent
Originally Posted by rocknss View Post
Captainfab,
I would like to order a set if you have any available.
Thanks,
Steven
Old 03-20-2012, 03:02 PM   #177
rocknss
rocknss's Avatar
PayPal sent!
Thanks,
Steven
rocknss is offline   Reply With Quote
Old 03-20-2012, 07:40 PM   #178
turbonewf
turbonewf's Avatar
Originally Posted by Captainfab View Post
Nice job
I did not realize that you were in need of a replacement for the factory bracket that holds the end of the cable. I have a set of Camaro calipers that have the factory bracket that I could duplicate if that is something that is needed. I just assumed that everyone had that bracket.
I'm having a hell of a time finding new calipers that have this e-brake bracket included. I'm having just a hard of time finding a used set to rob them off. John, help us (me) out!
turbonewf is offline   Reply With Quote
Old 03-21-2012, 12:05 AM   #179
Captainfab
60-66 Nut
I've been just burried with work. Let me see what I can do next week.
Old 03-25-2012, 10:21 PM   #180
rocknss
rocknss's Avatar
Received brackets and they look great!
Old 03-27-2012, 02:01 PM   #181
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I got mine mounted and will show the pics this week.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 03-31-2012, 02:27 PM   #182
Skcess
Skcess's Avatar
Capt Fab, Id like to buy a set of these - Are you still making them?
Lance
Skcess is offline   Reply With Quote
Old 03-31-2012, 11:18 PM   #183
Captainfab
60-66 Nut
Yes these are still available. I replied to your PM also.
Lance
Old 04-06-2012, 09:41 PM   #184
71meangreenc10
Here are my issues,
The intermediate truck parking brake cable is short about 3 1/4 inches with the camaro cables. I had to improvise a solution. I dont have detachable connectors for the cables for the trailing arms, that could be the solution. Move them forward to take out the slack.
Smitty
71 C30 Wrecker
Old 04-06-2012, 11:11 PM   #185
Captainfab
60-66 Nut
Yeah, it looks like the cables to the calipers is plenty long enough. So if you were to mike the mounting bracket on the trailing arm forward, the cables should hook up?
So aside from the brackets on the calipers, are some brackets for the trailing arm end of the cable needed?
Old 04-07-2012, 03:40 PM   #186
71meangreenc10
To make it work like a kit, that would probably do it. I am going to order another set of calipers soon and see if they come complete again.
Good thing is that I didnt have to cut my brake lines at all to make them work.
Smitty
71 C30 Wrecker
Old 04-10-2012, 01:03 AM   #187
longbed67
longbed67's Avatar
Dang I wish I would have found this thread before I did my rear brake conversion a while back... oh well if I dont like it once i get her on the road, I will order this and do this conversion.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-10-2012, 01:52 AM   #188
Captainfab
60-66 Nut
I have a total of 5 different rear disc conversion brackets.....3 for 5 lug and 2 for 6 lug.
Old 04-10-2012, 12:55 PM   #189
longbed67
longbed67's Avatar
Good to know. Thank you!
Adam
(608) 214-8706
Old 04-16-2012, 10:29 PM   #190
saleen_n_around
So I am getting ready to tackle this conversion. Question I have is what Master cyl and proportion valve is to be used? I have an 85 1/2ton SWB with 10 bolt.
saleen_n_around is offline   Reply With Quote
Old 04-17-2012, 12:21 AM   #191
Captainfab
60-66 Nut
Well you can use either a mid 70's Corvette master or the '93-'97 Camaro master. The Camaro master will be aluminum with the plastic reservior. As for the proportioning valve, most any OEM disc/disc valve will be a starting point. However you may still need an adjustable valve in the rear line to get your braking dialed in the way you like it. Or you could just go with the Wilwood 260-11179 prop valve to start with.
Old 04-17-2012, 07:49 PM   #192
rocknss
rocknss's Avatar
Would the 93-97 Camaro Master work in my 69 Chevy Suburban?
Old 04-17-2012, 11:47 PM   #193
Captainfab
60-66 Nut
That should work just fine. Do you have an original style booster?
Old 04-18-2012, 12:00 PM   #194
rocknss
rocknss's Avatar
Yes, I have the original booster.
Thanks,
Steven
Old 04-19-2012, 12:13 AM   #195
Captainfab
60-66 Nut
The Camaro master will bolt right up. Just check the length of the pushrod between the booster and the master to be sure it is the correct length.
Thanks,
Steven
Old 04-20-2012, 07:09 PM   #196
Project1970
14.1 @ 96MPH
Project1970's Avatar
Does it fit the same brake lines as the factory master too or do you need to replace those?
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-20-2012, 10:18 PM   #197
rocknss
rocknss's Avatar
X2
Old 04-20-2012, 10:56 PM   #198
Captainfab
60-66 Nut
I don't have hands on experience with the Camaro master, but I would imagine it will have metric line fittings. Every other master I have worked with of that vintage, has had metric fittings.
Old 04-21-2012, 07:35 AM   #199
lovechevytrucks2
Will these work on a 9inch rear .I want to convert discs in the rear Tony
lovechevytrucks2 is offline   Reply With Quote
Old 04-21-2012, 11:14 PM   #200
Captainfab
60-66 Nut
Not unless it has had the GM truck/Impala ends welded on it when it was narrowed
