Old 10-24-2012, 11:23 PM   #176
daverod
SSN 706
daverod's Avatar
Re: '49 chevy with s-10
Now I don't know what I want? haha thanks
daverod is offline   Reply With Quote
Old 10-26-2012, 03:51 AM   #177
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
What a cool project. Nice work.
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
Old 10-26-2012, 06:38 AM   #178
bk2life
What green is on the motor/trans? Kinda looks like John Deere green..?
bk2life is offline   Reply With Quote
Old 10-26-2012, 10:41 AM   #179
rollinrooster
rollinrooster's Avatar
Thanks, i love the patina on your truck!!!
rollinrooster is offline   Reply With Quote
Old 10-26-2012, 10:43 AM   #180
rollinrooster
Nope...not John Deere green. Its actually alot darker than the pics show. My buddy ownes a hot rod shop and he helped me come up with the color.
Old 11-29-2012, 06:36 PM   #181
Dirty Doug
Dirty Doug's Avatar
I love the look of this truck. I'm started a 1st 55 this fall. I'm using a S-10 too. But a short bed Reg cab I got with it. I'm in the middle of stretching it now. If I knew what the "correct" or true center was , I could set it up when I fit the pieces in the splice. Any updates on your truck ?
Dirty Doug is offline   Reply With Quote
Old 11-29-2012, 06:52 PM   #182
daverod
SSN 706
daverod's Avatar
oh. false alarm. I though there might be some more Progress...
Old 12-03-2012, 01:47 PM   #183
rollinrooster
Been makn some progress...just nothing intresting enuff to post yet. Alot of loose ends
Old 12-03-2012, 01:51 PM   #184
rollinrooster
Thanks, its hard to give you a "correct" or true center measurement. I tried to make the cab to bed gap closer on mine. Good luck with yours and keep us posted!!
Old 12-04-2012, 07:05 AM   #185
Dirty Doug
Dirty Doug's Avatar
Im using a tri-4 link , I should be able to get it close. I going to mount the box and cab close together too. Have you mount the under dash master assembly yet ? I wanted to use one them but filling and room has me thinking about a firewall mount .
Old 01-01-2013, 09:52 PM   #186
rollinrooster
Started moching the steering up.... and decided to move column to the left some to help line the wheel in the center of the gages.
Old 01-01-2013, 09:55 PM   #187
daverod
SSN 706
daverod's Avatar
Nice engine.
Old 01-01-2013, 10:08 PM   #188
rollinrooster
Originally Posted by daverod View Post
Nice engine.
Thanks.... It gets killer gas mileage to!!
Old 01-01-2013, 11:08 PM   #189
Dirty Doug
Dirty Doug's Avatar
I just need to see more of your shock mounts. I don't think I could handle that motor.
Old 01-02-2013, 01:50 PM   #190
rollinrooster
check out post # 136 and 141.
Old 01-02-2013, 02:15 PM   #191
Dirty Doug
Dirty Doug's Avatar
I guess I did see those pics now that I looked at them again. Did you make the top bracket ? What brand and number shock is that ? I have a Ride Tech upper that use the eyelet or bolt through type shock but the bracket looks thinner the the S10 frame .
Old 01-03-2013, 01:28 PM   #192
Jesse49chevy
Jesse49chevy's Avatar
Quick question,
Im using a S10 front clip and a Mustang rear end. Does anyone know if i can change the bolt pattern on them? if so? how?
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 01-03-2013, 01:39 PM   #193
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by Jesse49chevy View Post
Quick question,
Yes you can. You can have the Mustang rearend axles and rotors/drums redrilled to Chevy bolt pattern. I have a 9 inch in my 55 Chevy 210 and I had the axles and rotors redrilled to a Chevy bolt pattern. It was about 80 bucks.
Or you can have your S10 rotors redrilled to Ford pattern.Yuck.lol Just kidding but you can do that if thats an option for you. As you can see in the pic below my new rotors came with Ford 5 on 4 1/2 and Chevy 5 4 3/4 bolt patterns. They also came with 7/16 Chevy studs and 1/2 Ford studs
Kabwe is offline   Reply With Quote
Old 01-03-2013, 02:38 PM   #194
Jesse49chevy
thanks BAM we can always count on you.
where did you buy the rotors? and did you request the bolt patterns?
Semper Fi
Old 01-03-2013, 02:49 PM   #195
Kabwe
Certified Car Nut
Kabwe's Avatar
Jesse I'm going to PM you because I don't want to hijack rollinrooster's thread.
Old 01-03-2013, 04:06 PM   #196
rollinrooster
No worries man.... thats some go info. If you dont mind i would like to know where you got the rotors from also.
Old 01-03-2013, 05:45 PM   #197
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
where's the fat boy at now!!!
Originally Posted by rollinrooster View Post
Found a few pics of my road glide and some of my ole fat boy.
Smoke_Dog is offline   Reply With Quote
Old 01-03-2013, 11:21 PM   #198
rollinrooster
Done some trading with a guy from Kentucky a few years ago and havnt seen it since.
Old 01-04-2013, 12:08 AM   #199
daverod
SSN 706
daverod's Avatar
I was just wondering how many other projects you have done? Next truck I'm just going to copy you. How did you know how to make your 4 link?
Old 01-04-2013, 09:18 AM   #200
rollinrooster
This is my first time having to make everything . mostly i've just messed with harleys and just normal hot roddn stuff. On the 4 link i just talked with my buddy at the street rod shop and decided that i wanted to go with a tri-angled 4 link to keep the wheels in the center when using air ride. I used to have a '68 chevy truck that had a panhard bar that would shift side to side when you raised or lowered it.
Also, please dont follow me.... blind leading the blind!!!!
