Old 10-10-2011, 10:54 PM   #176
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Jim Bob a build thread
new inners and painted outers
shined up the wifes 05 malibu with F21 tried it on the Jimmys hood only half tho for testing
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-25-2011, 12:27 PM   #177
motornut
78K & 79C Jimmys
motornut's Avatar
took out the cluster from the 79
wanting gauges for the 78
I'm gona use a 88 cluster in the 79 for now
seems the 79 cluster has issues...
John
Old 10-25-2011, 12:30 PM   #178
motornut
78K & 79C Jimmys
motornut's Avatar
Mickey was livin the fast life over the speedo
John
Old 10-25-2011, 12:49 PM   #179
motornut
78K & 79C Jimmys
motornut's Avatar
while the inners were out i got the fuel pump done
real ez sittin on the tire...
changed the wires and one of the cap plugs pulled out loose,
surprised at the amount of rusty gunk out the fuel line from the pump to the filter
prob worth anybody checkin that
can't wait to try it out now...
John
Old 10-25-2011, 12:56 PM   #180
motornut
78K & 79C Jimmys
motornut's Avatar
plugs,didn't think to get new ones but checked these2-4-6-8
John
Old 10-25-2011, 12:59 PM   #181
motornut
78K & 79C Jimmys
motornut's Avatar
and 1-3-5-7
John
Old 10-25-2011, 01:58 PM   #182
kikkegek
kikkegek's Avatar
he....those plugs look nasty? or is that OK?
kikkegek is offline   Reply With Quote
Old 10-25-2011, 02:26 PM   #183
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Wow, those have been in there for a while! Either that or the carb isn't tuned right.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 10-25-2011, 03:51 PM   #184
motornut
78K & 79C Jimmys
motornut's Avatar
might be tops 6-7000 kms on those
outa tune i suspect,with it being so screwed when I got it
vac advance was wrong spot,right since i got it
timing chain was done,fixed last winter
took out 305 plugs, last fall
dizzy weights were rusted tight,but loosened up better now
suspect the crud in the gas line ,
which i think is the oringinal 305 line and pump
has caused me some running probs ,and may have the PO setting it up too
i'd wana see the lighter colour brown on the tips ,more like the outside cyclinders
if you floored it 3 or 5 would miss fire sometimes, and blow back threw the valve cover
figured timing .....
lol but it did start faster this time
John
Old 10-30-2011, 07:53 PM   #185
motornut
78K & 79C Jimmys
motornut's Avatar
found a cracked tip
brought it back
cleaned up the vac part of the advance better
John
Old 10-30-2011, 07:59 PM   #186
motornut
78K & 79C Jimmys
motornut's Avatar
blue cap seems to be better fitting tips
i noticed my booster vac comes off the manifold not the back of the carb
John
Old 11-05-2011, 06:51 AM   #187
motornut
78K & 79C Jimmys
motornut's Avatar
thought i would use just the speedo from the 79, in to the 88 cluster, and use the 88
but the rear mount for the cable is different,so i just put the whole 88 in
with the inners out i wanted to get a few things done,
like the rag joint... toast quite an improvement
John
Old 11-05-2011, 07:02 AM   #188
motornut
78K & 79C Jimmys
motornut's Avatar
and got the inners in
we are getting frost in the morning...
John
Old 11-05-2011, 11:53 PM   #189
motornut
78K & 79C Jimmys
motornut's Avatar
found some rims to go see
any ideas what age or make?
and do they fit?
John
Old 11-17-2011, 10:04 PM   #190
motornut
78K & 79C Jimmys
motornut's Avatar
decided i'd stay with the stock rims
and picked up a stock tach/gauge cluster
being i have a idiot light setup it's all gotta change
John
Old 11-17-2011, 10:17 PM   #191
motornut
78K & 79C Jimmys
motornut's Avatar
at first i was gona use my cluster from the 79 Jimmy gauges only
it is wired different from the idiot, and the tach clusters too
NOT plug and play, closer to snap crackle pop
it's spare parts now...
put the 88 cluster in the 79 fit and worked,lack of rust might help
John
Old 11-17-2011, 10:21 PM   #192
motornut
78K & 79C Jimmys
motornut's Avatar
spent a fair bit of time trying to figure out if it was a simple wire switch
ad or subtract a few wires
when all i had to do was ask lol
http://67-72chevytrucks.com/vboard/s...d.php?t=493838
thanks again Vette Vet
John
Old 11-17-2011, 10:47 PM   #193
motornut
78K & 79C Jimmys
motornut's Avatar
So this is it
that seat belt buzzer is coming out
and thats the spot of peoples ground issues i bet ,they all go to one wire
pink seemed a little baked to the buzzer
those joints are within about 6-8 inches of the cluster plug
John
Old 11-17-2011, 11:01 PM   #194
motornut
78K & 79C Jimmys
motornut's Avatar
how it looks now .....double tach means double the rpms right lol
John
Old 11-18-2011, 06:16 AM   #195
kikkegek
kikkegek's Avatar
good job! look nice!
Old 11-19-2011, 09:26 AM   #196
motornut
78K & 79C Jimmys
motornut's Avatar
thanks
I'm glad it all worked ok
got this for the oil sender,used only one
John
Old 11-19-2011, 09:59 AM   #197
kikkegek
kikkegek's Avatar
Hi john,
what are those bent pieces for? are those adapters?
I recently replaced mine and you know how that ended...
Old 11-19-2011, 11:30 AM   #198
motornut
78K & 79C Jimmys
motornut's Avatar
Yes the sender" can " is to big to fit in straight down
I tried without the extra lenght, hit the intake
Bought an extra incase it was needed for an extra funky bend, .90 cents for the extension,$5.88 for the 45 bend.
There was another square block ish , and shorter,hit intake right away
But options were up male male1.5 inches then bend
John
Old 11-21-2011, 01:49 PM   #199
motornut
78K & 79C Jimmys
motornut's Avatar
this is the wire spots for the clusters
let me know if it changes
John
Old 11-26-2011, 03:55 PM   #200
motornut
78K & 79C Jimmys
motornut's Avatar
and now for lighting or white lightening lol
and a chance to go over it all
John
