Old 10-31-2011, 09:12 PM   #176
litew8
litew8's Avatar
Re: Project "My Happy Mess"
Thanks , the fuel line routing was the work of "The Fixer". We shaved the exhaust manifold (driver's side only) and the alternator.
Both fitting now, looking good for a custom/modified install. Last I saw, "The Fixer" was creating an oil pump primer tool with an old distributer.
He was going to adjust the rocker arms, etc... also. I got hit with a cold this weekend so nothing else new. What's written above is what we did this morning.
Pics from this morning I'll try and get posted late tonight.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-31-2011, 09:16 PM   #177
VA72C10
VA72C10
VA72C10's Avatar
Nice work. I like the way it looks..... I hope i'm wrong but I worry about vapor lock issues in the summer with that fuel line....I can only imagine it gets pretty hot in between the intake there....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-31-2011, 09:33 PM   #178
litew8
litew8's Avatar
ty I did question it, but since it's opened and air will be flowin, "The Fixer" thinks it'd be ok.
Old 11-01-2011, 08:42 AM   #179
hgs_notes
GEARHEAD
hgs_notes's Avatar
I have tall valve covers on mine also and I added a couple inchs to the bottom end of my alt bracket to get it past the cover, then used a longer belt. BTW, I think the belt you have is too wide. If you go to a napa or other part store that has all the belts hanging there to see, just ask to pull some down and look. The length and width are usually printed on the cover and you should be able to find a belt with similar length but narrower that will fit in the pulleys better. Probably use the same length and it will actually seem longer because it'll fit deeper in the grooves and allow the alternator to move out a bit more.
No offense to "The Fixer", but I think he's wrong about the fuel line being ok through the manifold. It's going to be hot there and not flow much air. Besides, heating the fuel is bad for power. At the very least it should be wrapped in some insulation. One more thing on the fuel line, with the filter in that position it will dump gas on the front of the engine everytime you need to change it. Consider moving it to the line before the fuel pump in the frame rail, even back by the tranny crossmember.
hgs_notes is offline   Reply With Quote
Old 11-01-2011, 10:20 AM   #180
litew8
litew8's Avatar
No offense taken and I appreciate your honest explanation/suggestions, as with everybody else here within the forum. He's my Brother and I coined the nickname "The Fixer" out of respect to him, but also as comic relief within the thread. I assume you've known or have first hand experience with air-gap intakes?
Funny you mention the width of the belt being too wide. Just yesterday I noticed how full it filled the pulleys. Napa (in my area) was one of the more dumber experiences for me when in search of the v-belt. I asked for a 54 1/2 inch belt, the kid came back with a 52" and was twice as thick as the one I have now. In all honesty, I hate auto stores. It stems from growing up having to deal with them - it is one of the reasons I moved on from wrenching on cars to just buying new instead. But as for the thickness, I do not know, or I will find out soon enough. I figured it being a "Gator" belt it had characteristics that produced better gripping, thus filled the pulleys better. I'm not certain they make (or sell locally to residential) a wide variety of v-belts for automotive/alternators.
If when I go and change out the bottom bracket with the aluminum Corvette bracket (which I'm afraid will break under prolong stress), I will need to get a longer belt to compensate the difference. At least in my current situation I am able to start, tune and store the truck until a later date (next summer). I've read having two fuel filters is ideal. Before and after the pump. But as you've mentioned, relocation has merit.
Old 11-01-2011, 11:07 AM   #181
litew8
litew8's Avatar
Tuesday Update -
Monday, shaved the driver's side exhaust manifold for valve
cover clearance. Shaved the alternator for the same reason.
Exhaust manifold painted while still hot, baked on -
Warranty? We don't need no stinkin warranty!
Cleaned up better than this, just didn't take a pic -
The "new" clearance
Old 11-02-2011, 08:03 PM   #182
litew8
litew8's Avatar
Haven't had much time to do a whole lot lately. Waiting on a couple of parts to arrive (soon). Primmed the oil pump and adjusted rocker arms the other day. Cleaned up the HEI Mallory Distributor today and dropped er in. Got the right spark plug wire loom kit on order and in route for a nice stock install. My air cleaner was on backorder, expected to ship on 11-15-11, but I called them up and muscled () them into pulling some strings. It's also in route to my front door as I type. I've got a few pics I'll try and get posted asap. Thanks for looking.
Old 11-02-2011, 08:05 PM   #183
litew8
litew8's Avatar
Question: Who here wants to see an HD video of the first fire?
Old 11-02-2011, 08:18 PM   #184
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I don't care if it's HD, but a video will be cool.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-02-2011, 08:50 PM   #185
litew8
litew8's Avatar
I ask it like that because it will be a lot of work for me to transfer the video from my camcorder into a format for the web. I haven't ever had time to experiment in transfering video from it (HD camcorder), but I know it's going to be a bear. It prob. won't be true 1080 quality after all is said and done. The other option, I could take the video using my 11 year old floppy disk Sony Mavica camera and post tiny videos. That might actually be the way to go.
Old 11-04-2011, 02:53 AM   #186
litew8
litew8's Avatar
Old 11-04-2011, 06:29 PM   #187
bollybib
bollybib's Avatar
Just letting you know I enjoy reading your thread and I'm following along. I love the happy mess title haha.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 11-05-2011, 08:48 PM   #188
litew8
litew8's Avatar
Thank you Jim. Complements coming from a retired engineer, that means a lot to me. We got the distributor dropped. Got the stock spark plug wire heat sheilds in and I began installing them this afternoon. Well, my dumb luck - the first one I installed (driver's side, rear) didn't seem to provide enough clearance for the 90 degree boot on the Taylor spark plug wire. The boot was touching the sheild, no matter which way I turned it. Also, removal of the spark plugs themselves would have been a real pain with the sheilds installed due to clearance provided. I decided we'd probably be better off not installing the heat sheilds. $18 bucks worth of metal. The other peices I will use. They are looms that originally were on Corvette installations (or older years). Two brackets for the back bellhousing to hold the wires coming off of the distributor and then two small brackets that mount on the block (front, where the front heat sheilds would have been installed). There are 4 small threaded holes on a 350 block for this purpose. The aftermarket (Taylor) spark plug wires are from a 1976 length Corvette installation. The wires will run from behind (distributor) and under exhaust manifolds. No wires draping over valve covers.
I went to take the heat sheild off and the damn bolt busted off inside of the block. Oh well.
Maybe we can tap it out and modify the sheilds for better clearance. I'm thinking the difference between stock heads and the E-tec's are such that it messes with things in the smallest irritating ways.
"The Fixer" is drilling a 1 3/8" hole in each aluminum valve cover tonight for breather and pvc installation.
Air cleaner is scheduled to arrive on Monday.
Old 11-05-2011, 10:36 PM   #189
doubleb's69
doubleb's69's Avatar
Hello from another Des Moines resident. I Spent some time going through the thread. Keep up the good work.
Bud
doubleb's69 is offline   Reply With Quote
Old 11-06-2011, 02:37 AM   #190
litew8
litew8's Avatar
Originally Posted by Cameron 1137 View Post
This is what mine sounds like at idle:
Hope this helps
Thank you. You're not running a full exhaust so it's a different sound. Can anyone say what a 69 Chevelle sounded like, or a super bee or something comparable. A larger era specific sound. Maybe it'd require a converter before the muffler?
Old 11-06-2011, 02:39 AM   #191
litew8
litew8's Avatar
Thanks for looking Bud. Here's hoping for a late snow.
Old 11-06-2011, 10:43 AM   #192
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
pix????
John
1999 Toyota Tacoma 4x4
Old 11-06-2011, 12:01 PM   #193
litew8
litew8's Avatar
Going over to work on it now. Will get pics posted this afternoon if I have time.
Old 11-06-2011, 02:43 PM   #194
Cameron 1137
Cameron 1137's Avatar
Yes, the video with just idle is with the incomplete system, the video where i open it up is with full exhaust to the bumper.
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 11-06-2011, 05:32 PM   #195
litew8
litew8's Avatar
Sunday Update -
Inspiration. On the way to work on the truck, I see a Chevy I've seen before
driving my streets. Took a couple pics for everyone to see what it looks like
when our trucks drive my neighborhood.
Got the wires run.
The hole the heat sheild bolt busted off into (back, driver's side) -
One retaining clip installed on both sides of oil pan (total of 2)
Looms installed on transmission bell housing, where guard should be -
I'll get the other two smaller front clips installed tomorrow.
"The Fixer" didn't drill the holes last night, but will find some time
tonight. Here's the tool -
Old 11-06-2011, 06:13 PM   #196
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 11-06-2011, 08:02 PM   #197
brans72
From reading couple pages could you use the corvette upper braket and not have had to mod alt and gave your more clearance? Or would you have had to buy more then just upper bracket? Thanks Brandon
brans72 is offline   Reply With Quote
Old 11-06-2011, 08:11 PM   #198
oldman3
oldman3's Avatar
Engine stuff looking real good....Jim
oldman3 is offline   Reply With Quote
Old 11-06-2011, 08:24 PM   #199
litew8
litew8's Avatar
Originally Posted by VA72C10 View Post
Looking good!
ty VA
Hi Brandon. No. The (shorter) Upper bracket installed in the stock location (on top of the lower bracket) wouldn't reach the alternator. That's why we had to drill a second hole (to the right on the lower bracket) - to extend the tension bracket outward. To do it right, the bottom bracket should get replaced with the Corvette lower (aluminum) bracket so that it extends the alternator out to the right. Coupled with the Corvette Upper (longer) tension bracket. That way Everything will get pushed outward towards the fender, and no tension issues would arise. There's a point of no return when pulling on the alternator as it sits now with the current setup. If you pull too far to get tension, the arc will start to go downward and the belt just loosens up. So to be correct, everything needs to be lengthened to the right for proper tension. If I end up using the Corvette brackets, I'll probably need a 55" v-belt also.
Hope that helps answer your question in a roundabout way.
A more direct reply - Both upper and lower Corvette brackets should be used for best clearnace.
The upper bracket should be a longer arc, and the lower bracket should kick out to the right more.
As it sits, I probably will end up having 1/8" clearance from alternator (after shaving the back edge and 1/2 of the bolt head) to valve cover.
As long as the alternator doesn't vibrate loose and move, it should remain fine.
I've asked that some of the posts up thread be removed so that they wouldn't cause confusion. va
ty Jim
Old 11-06-2011, 09:15 PM   #200
litew8
litew8's Avatar
Brandon, also keep in mind that I'm using E-Tec 170 heads and tall fabricated valve covers. Together, I think they exagerrate clearnce issues. The E-Tec heads seem to stand taller than stock heads. So it might be that stock heads and tall valve covers wouldn't create as much of a hassle I've encountered, but from what I've read, tall valve covers do create some issue on their own.
