Old 05-07-2014, 11:55 PM   #176
C20scott
Re: Backyard Cummins
Finally removed the junk universal mirrors that the PO put on there. Went with an original set of tripods that i found locally.
1969 K20, Cummins 12v conversion in progress...
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574152
C20scott is offline   Reply With Quote
Old 05-08-2014, 12:01 AM   #177
C20scott
Found a rust-free metal floor bed locally for a good price. There will be some body work needed. but not going for a show truck here. I have it temporarily setup with lights, no tailgate.
The shackle-flip moved my axle forward a good amount, and is no longer centered in the well. I decided that i am not going to try and reverse this. Instead, i am simply going to set the current location of the axle as the centerpoint of the fenderwell, and cut from there. I will have fender flares for mockup before i do this.
I will need to make a set work, as i have yet to see a good looking set of flares for these trucks.
Old 05-08-2014, 12:13 AM   #178
C20scott
I have done alot more undercover work in the last month, more pics to come. Hopefully some smokey burnout videos once i get this engine dialed.
Old 05-08-2014, 04:13 PM   #179
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice score on the bed. Are you saying you're going to cut the bed around the wheel well and move it forward instead of just moving the axle back to center it in the wheel well? Have you thought about using a zero rate off set block to help move it back?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-15-2014, 01:53 AM   #180
C20scott
Yes, that's exactly what i'm planning. I could easily get the axle to move back, but this would mean that i need to have my driveshaft rebuilt.(didnt have the foresight to think about the axle moving forward when i measured..)
I want fender flares anyways, and a shorter wheelbase could never hurt.. Also, would linexing the entire truck in a custom color be a bad idea?
Old 05-15-2014, 09:19 AM   #181
superduty_59
Ultimately it's your truck and you will do as you see fit. I have seen Jeeps that were beat up and rusted out. The owners did a spray on bed liner just to give it a uniform look and make it look better than it did. I think it could look cool done right but very hard to remove if you want to do anything in the future.
superduty_59 is offline   Reply With Quote
Old 05-15-2014, 08:30 PM   #182
Dieselwrencher
I'd say pass on the liner over the whole body. To me it doesn't look great on a vehicle you're sticking so much money in. And how many hours will you have doing the bed sides versus moving the axle back and having your drive shaft re tubed? My drive shaft shop will re tube and balance one for around $100. I'd rather spend $100 than have several hours cutting and moving the wheel wells in the bed side. I've stretched quarter panels before on tubbed cars and that work sounds easy until you get it all cut up.
Ryan
Old 05-18-2014, 02:26 AM   #183
C20scott
Im not going to linex the whole truck, it was a thought though. I will be linexing the bumpers and rockers, because thats my style.
Also, good advice on the fenderwells, i can get a longer tube for about the same price. On the other side, its not like im going to spend weeks on the bodywork. I would literally be slapping some plastic flares over the larger opening.
Old 05-18-2014, 02:45 AM   #184
C20scott
I finally got my engine dialed today.. Im now wondering if its necessary to have this much power..
Here's a list of everything i have under the hood so far:
Engine - 1997 cummins 12v, 215hp pump, 120k on odometer before swap
Tranny - NV4500HD 5 speed
TCase - NP205 from cummins, matching spline count
Engine Upgrades:
4" straight pipe exhaust
Amsoil Ait filter, no restriction
DPS exhaust manifold
Phatshaft 62/65/12 turbo
Carl's dual intake(not sure if this really helps with power)
3k gov springs
5x.014 injectors from DFI
#11 fuel plate
Timing bumped to 16*
A badass lightweight chevy truck to put it all into
The above combo gives me more power than i could ever need in a truck. I almost want to put an auto tranny in it just to see how fast i could make it. I still have some tuning to do, but currently have no turbo lag, good fuel mileage, and more power than any other vehicle ive ever owned(tires spin in 2nd-4th gears). since injectors, timing, and sealing up all of my air leaks, this engine is a whole different animal
Old 05-18-2014, 09:06 AM   #185
84chevyguyid
How much boost does it make?
84chevyguyid is offline   Reply With Quote
Old 05-18-2014, 04:03 PM   #186
C20scott
Top gear on the highway I saw 39psi at the intake manifold. Pretty sure the wastegate is set right around 40. Im on stock head studs and gaskets, so im not going to push it over 40psi. EGTs are staying nice and low too. I need to figure out how to post a video!
Old 05-20-2014, 02:12 PM   #187
rgreathouse
How do you like the tuff country leafs?
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 05-20-2014, 08:16 PM   #188
Dieselwrencher
Have you retorqued your original head bolts yet? If not, do it. It's cheap insurance. I usually take them to 135-150lb ft depending on who's truck it is.
Ryan
Old 05-25-2014, 12:49 AM   #189
C20scott
DO NOT BUY the Tough Country HD leafs with a 4" lift for an application like the one i have. They are wayy too stiff, and have not settled at all, even with the weight of the cummins. I will be ordering a custom spring pack from ORD in the next few months that will hopefully be alot better. Spend the extra money...
I will be re-torquing the head studs soon. Also, confirmed that my wastegate is set at 35PSI, hits it no problem.
As far as drivability, the truck is becoming alot more manageable now that i have some weight over the back tires, and the fuel system dialed in. I am however, experiencing some extremely lurchy driving when going up steep hills at less than 5mph. Its a condition similar to "speed wobbles" except the truck is lurching forward and back. I literally have to come to a complete stop, and start moving all over again to stop it. I suspect that it is a mixture of excessive lash in the drivetrain somewhere, and the overpowering low-end torque of the engine in 1st gear. Advice?
Old 06-15-2014, 02:43 AM   #190
C20scott
Plasti-dipped the panels and handles, Duplicolor on the armrest, matt black fits well in my opinion. Also put new weatherstripping, window seals and velvet, sound deadener in the door, stereo system. Amplified Alpine type-R door speakers/tweeters and 12" kicker sub behind the seat. Things are sounding good now.
Old 06-15-2014, 02:46 AM   #191
C20scott
Tomorrow i plan on removing the lowermost leaf on my front spring packs. Effectively turning the tuffcountry HD into the EZRide. As of now the front end has 0 flex, solid as a rock, and sits about 1" higher than the rear. Im hoping that the cure-all is to remove the short leaf from the pack.
Old 06-15-2014, 07:27 AM   #192
brimc
brimc's Avatar
That's a neat idea on the plasti dip for the door panels. Looks good. Interested on how you make out with the front springs as I think I have that same ones or very close.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 06-15-2014, 10:36 AM   #193
ryanroo
ryanroo's Avatar
I doubt you will see a lot of change from removing the short leaf. if you are looking to soften the ride i think it will help more if you pull a leaf from the middle. the longer ones will have a more noticeable effect.
i have the 2 1/2" ez rides on my K20 and they are not terribly smooth either. i have a set of rough country 4" springs that will probably end up on that truck but i have no idea how they ride in comparison. they have been sitting in my garage for several years without having been down the road.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-17-2014, 04:04 PM   #194
C20scott
I went ahead and removed the lower leaf from the Tuff Country 4" HD springpacks. (i think it was 12"-16"or something) I now have a total of [3] leafs, instead of [4] on the front end. The truck now sits level with the rear end, which has stock leafs and the ORD shackle flip. It has alot more "give" than previously, flexes slightly more, and feels more like a truck than a block. Still rides like an old truck though...
I wasnt sure how big of a difference removing a leaf would make, so i wanted to start small. I am happy with the current ride of the front, especially compared to what it once was. Not sure how much more weight i will be adding up front either.. I will comment again once i feel the suspension has settled to a more permanent stiffness.
CONCLUSION: Even with the added weight of the Cummins fully dressed, do not buy the 4" lift "HD" leafs on the front if you have the same setup as mine. I could get about 1/4" of flex out of the suspension by jumping on the front bumper as hard as i could, which was probably only the bushings anyways Speedbumps at <5mph were something to cringe about. Literally like driving a brick. Unless you plan on adding a 1500#+ snowplow or something, do not be tempted. I cannot speak for lower lift heights, or vehicles with more weight on front, as those would probably ride better even with the HD leafs.
Old 06-17-2014, 08:15 PM   #195
y5mgisi
Second Chance Program
y5mgisi's Avatar
Good to know!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-04-2014, 09:55 PM   #196
1972RedNeck
1972RedNeck's Avatar
If you want to run more boost, you should look into Mighty Diesel's head bolts - still not as good as studs but much cheaper.
1972RedNeck is offline   Reply With Quote
Old 07-06-2014, 11:27 AM   #197
Dieselwrencher
Just retorque your stockers and save up for actual studs. A broken allen bolt is no fun to get out.
Ryan
Old 07-10-2014, 09:50 PM   #198
C20scott
Plasti-dip was a bad idea on the door panels. It is somewhat abrasive/porus, and collects dust. Also, i started picking at it and it peels off very easily. The door panels need a slick, hard shell of paint, for getting in and out of the truck.
I have been changing jobs/locations over the past few weeks, no visible progress to post.
Old 08-27-2014, 11:14 PM   #199
C20scott
Pulled the batteries out of the engine compartment, and mounted them on the frame underneath the bed. Used pre-made battery boxes from summit racing, and fully reinforced them with angle and square tube. Lighting is terrible for these pics...
Old 08-27-2014, 11:16 PM   #200
C20scott
Grover Stuttertone 1510. Fire Truck Horn. Check out a video on youtube if you want to hear it.
I plan to have a full time on-board-air setup with a 20lb CO2 tank. A friend of mine gave me a tank for free. Once again, the lighting is terrible in this pic, makes it look like crap underneath the cab.
