Old 11-01-2014, 11:42 PM   #176
boynton
boynton's Avatar
Re: First Steps LS Swap......
Excellent planning and work!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 11-01-2014, 11:49 PM   #177
lynnfield
The Waco Kid
lynnfield's Avatar
I recommend ordering some of these Packard 56 type terminals before doing this, they are easy and make your install look factory when routing wires thru your firewall bulk head connector. Greg
I ordered most of my connectors here:
http://theelectricaldepot.com/index....43e4aaf857036e
lynnfield is offline   Reply With Quote
Old 12-16-2014, 05:32 PM   #178
lynnfield
The Waco Kid
lynnfield's Avatar
Things have been going slow lately. I've been tidying up the wiring and working on the mount for the air box, and some other things. Started with the support for the battery tray from the 06 truck, and made it fit the core support.
Old 12-16-2014, 05:44 PM   #179
lynnfield
The Waco Kid
lynnfield's Avatar
If you're looking at the pictures above and thinking that bracket is mounted at an angle, it is. The first was straight, then I realized that the bottom of the air box was at a slight angle to the top. Had to make a trip to pick n pull and start over with another bracket. So, next a flat plate to connect the support bracket and the box mounting plate. If you look back at the battery box I made using the tray from the 06 truck, you will see I cut a two holed mounting tab off it (post #149). That was welded onto this plate and used to bolt it to the inner fender, the inner fender had to be worked a bit also. I thought about welding all this together, like the original battery box was, but this allows for disassembly for access to wiring and some adjustment of the mount. Greg
Old 12-16-2014, 05:49 PM   #180
lynnfield
The Waco Kid
lynnfield's Avatar
Back from powder coat and installed.
Old 12-16-2014, 05:52 PM   #181
lynnfield
The Waco Kid
lynnfield's Avatar
I got side tracked by some other projects and the mess under my dash. I have been wanting to try this intermittent wiper set up for a while now:
http://67-72chevytrucks.com/vboard/s...ad.php?t=32017
This works, but I made a few of my own changes
Old 12-16-2014, 05:56 PM   #182
lynnfield
The Waco Kid
lynnfield's Avatar
First was the mounting of the knob. The knob that comes with the switch has an aluminum bushing that is useful.
Old 12-16-2014, 06:06 PM   #183
lynnfield
The Waco Kid
lynnfield's Avatar
Use about a #18 (or about a .169) drill to oversize the threaded hole in the factory knob. Drill the factory knob out with a 1/2" to about a .390 depth, be careful not to push thru. I did that with the standard knob in the pic above, it helps to have a practice one. The deluxe knobs are easier because there is a hole in the bottom and you can see the back of the stainless to see when you're getting close. I recommend doing this in a drill press BTW. The bushing can be worked out of the other knob with a pick, it has a knurled place about 1/8 wide about even with the set screw, once you get past that it goes easier. Greg
Old 12-16-2014, 06:18 PM   #184
lynnfield
The Waco Kid
lynnfield's Avatar
Next the tricky part, use a nut/bushing from the headlight switch. Order a 7/16"-28 tap, I got mine from McMaster Carr, about $11 plus shipping, I think the total was around $20. Remove the plastic bushing inside BEFORE you drill it out, it will cause you problems and theres not a lot of extra material. Drill the center of that out with a 25/64" drill, then tap 7/16"-28. BE CAREFUL, it is close, and there is not a lot of extra material, but it does work.
Old 12-16-2014, 06:21 PM   #185
lynnfield
The Waco Kid
lynnfield's Avatar
More pics
Old 12-16-2014, 06:30 PM   #186
lynnfield
The Waco Kid
lynnfield's Avatar
Second, in that thread for the wipers, some were trimming the lip of the dash. I found that doesn't have to happen. The switch hits at the top and the inside lip of the dash, trimming that lip didn't seem to gain anything. Instead, make a shim for the bottom inside, about the same height as the lip itself. My shim, or spacer came out to about 1/4" X 5/16". using a 1/4" piece of aluminum, I just sanded it to the same height as the lip. Then epoxied it to the back side of the dash. That gave a solid even mount for the top and bottom of the switch. I did file the lip up in the corner to allow the switch to be centered in the hole, But I only filed a fraction of an inch, nothing that would be noticeable.
Old 12-16-2014, 06:49 PM   #187
lynnfield
The Waco Kid
lynnfield's Avatar
With all of that this was the most important thing. Follow the wiring diagram completely in that thread and you will have low speed only. I spent a day alone on this. The wiring for the relays is correct, if you look at the orientation of the factory plug (the 3 wire one that plugs into the stock switch) it is backward or upside-down. If you wire this up as I did and have low speed only swap the hi and low speed wires at that plug and all will be well. Also all the Cole Hersee switches with the 75600- part number look to be the same as long as they are 12v. If you get the 75600-02, it comes with a 6 wire packard 56 connector already on it, and you can order the female connector #2977044 and wire directly to it. I found the switches at a local big truck repair shop here in Waco (Truckmotive) for $59.
Relays I used: https://theelectricaldepot.com/index...93964d5ce92511
6 way connector: https://theelectricaldepot.com/index...93964d5ce92511
Use these 3 way connectors to replace the factory plug for the original switch: FEMALE: https://theelectricaldepot.com/index...d709cb2db5040b MALE: https://theelectricaldepot.com/index...d709cb2db5040b
I used these also to hold the relays, the bases lock together: https://theelectricaldepot.com/index...93964d5ce92511
Last thing, order the terminal connectors for the relays if you use those bases: https://theelectricaldepot.com/index...93964d5ce92511
Old 12-17-2014, 10:43 PM   #188
70chev383
70chev383's Avatar
Subsribed
70chev383 is offline   Reply With Quote
Old 12-19-2014, 10:23 AM   #189
mrsiege
mrsiege's Avatar
yes same here been kicking the idea around and think im diving in "the swap" and this thread is AMAZING!!! subscribed. ceige
mrsiege is offline   Reply With Quote
Old 12-23-2014, 10:08 PM   #190
Dustytrix
Great work, I like all the diy work.
Dustytrix is offline   Reply With Quote
Old 02-14-2015, 08:56 PM   #191
lynnfield
The Waco Kid
lynnfield's Avatar
I want to update this thread, since the truck is on the road now. This is the last pic from the wiper mod, I used the mounting from the washer pump, made a bracket and mounted the three relays to it.
Old 02-14-2015, 09:02 PM   #192
lynnfield
The Waco Kid
lynnfield's Avatar
Pics of the last bit of wiring under the dash, and the gauge panel installed. As I stated before the truck is now on the road, licensed, tagged and inspected. There are about 200 miles on it so far and all is well. Thanks to everyone who commented and helped me out along the way. I'll get some final pics with the truck all back together as soon as I get some time and the weather is nice. Greg
Old 12-11-2017, 11:17 PM   #193
thehata1
Very thorough thread. Thank you for all of the guidance you have given the rest of us that are planning the same. Last post in 2015. I'll be referencing it in a build in 2018. That's a great testament.
thehata1 is offline   Reply With Quote
