Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 10-06-2020, 02:42 PM   #176
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1963-1966 Chevrolet & GMC C10 / C20 Aluminum Radiators!
Thanks for the order!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 10-30-2020, 12:37 PM   #177
SparkyRnD
SparkyRnD's Avatar
back up top
Old 11-20-2020, 03:57 PM   #178
SparkyRnD
SparkyRnD's Avatar
back up again
Old 11-30-2020, 12:56 PM   #179
SparkyRnD
SparkyRnD's Avatar
back up again!
Old 12-21-2020, 02:31 PM   #180
joesscamaro
Not sure what info you need, but I’m looking for a price quote on a radiator/fan setup for a ‘65 C-10 with a ‘00 LS1, 4l60 or 4l80, also running a PSI harness. One more thing, can I get dimensions on the final product? Thanks in advance!
joesscamaro is offline   Reply With Quote
Old 12-21-2020, 03:24 PM   #181
SparkyRnD
SparkyRnD's Avatar
$450 retail on the radiator ($425 forum member price). For the fan kit, what kind of power are you making and is it naturally aspirated? Size is about 24" wide x 22" tall
Old 12-21-2020, 07:57 PM   #182
joesscamaro
I should be making about 450 to the wheels naturally aspirated. Thanks for the quick response.
Old 12-22-2020, 10:57 AM   #183
SparkyRnD
SparkyRnD's Avatar
With that, I'd recommend our upgraded single 17" that has dual speeds (up to 2,400cfm on high). If you'd like to set up an order, pm me your email address and full shipping address. Then I can put together an invoice and send to you.
Old 12-22-2020, 11:41 AM   #184
REDROCKER652002
I'm liking your 56 Belair set up. I need to go and get into my dad's car again and see what it needs. Does the member discount apply to that as well?
REDROCKER652002 is offline   Reply With Quote
Old 12-22-2020, 12:08 PM   #185
SparkyRnD
SparkyRnD's Avatar
Yes, member discount applies to any radiator, fan & shroud combo, and any overflow tank. Just make sure to mention you are a member when ordering.
Old 01-06-2021, 10:42 AM   #186
88Stanger
88Stanger's Avatar
SparkyRnD
I am in need of a 4-Row radiator with an electric fan. I have been looking all over and someone on here gave me RnD info to contact you on, so i am doing that. Can you tell me what the price would be and how to go about getting one? PM or here, what ever is easier.
Thanks for your time
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 01-06-2021, 07:35 PM   #187
SparkyRnD
SparkyRnD's Avatar
Originally Posted by 88Stanger View Post
SparkyRnD
Thanks for contacting us. On the 4-row part, that refers to 4 cores that are 1/2" thick in brass & copper, which gives you a total core-thickness of 2" (4x.5). On aluminum radiators, we use dual 1" thick cores, so our core-thickness is 2", same as the brass & copper 4-core.
The radiator to fit your rig is $450 retail / $425 forum member price.
I have a few questions so that we can put together a total quote for you:
1. what engine & transmission are you running?
2. do you want the built-in trans cooler (no additional charge)?
3. how much horsepower is the engine going to make?
4. are you using any power adders (nitrous, turbo, supercharger)?
5. do you want to add the controller with relay to control the fan?
6. do you need an overflow / catch can? We have them available in round & square styles.
7. What is your zip code for shipping?
Let me know on the above and I can put together a complete quote for you.
Old 03-08-2021, 09:42 AM   #188
SparkyRnD
SparkyRnD's Avatar
back up top
Old 03-24-2021, 12:40 PM   #189
bigguy
How thick are the radiator and fan combos?
bigguy is offline   Reply With Quote
Old 04-05-2021, 06:07 PM   #190
SparkyRnD
SparkyRnD's Avatar
that depends on HP level as to which fan(s) we choose
Old 04-05-2021, 06:46 PM   #191
bigguy
500 ish.
Old 04-06-2021, 09:11 AM   #192
SparkyRnD
SparkyRnD's Avatar
500hp would use our upgraded dual-speed 17" fan ($340 retail / $320 member price). The radiator is about 3.5" thick, and the upgraded 17" fan is about 3.5" thick as well, for a total of 7" thickness (it's a bit thinner than that combined, but we use that for planning purposes to give adequate space).
Old 05-18-2021, 12:58 PM   #193
SparkyRnD
SparkyRnD's Avatar
back up top
Old 06-10-2021, 03:20 PM   #194
SparkyRnD
SparkyRnD's Avatar
up top again!
Old 07-07-2021, 10:08 AM   #195
SparkyRnD
SparkyRnD's Avatar
back up again!
Old 08-03-2021, 09:26 AM   #196
SparkyRnD
SparkyRnD's Avatar
up top
Old 10-04-2021, 09:28 AM   #197
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering!
Old 10-21-2021, 08:18 PM   #198
idreama300
Sparky I have a 383 with no power adders and th350 making about 500hp. Looking for radiator with trans cooler, fans, wiring harness, and overflow.
idreama300 is offline   Reply With Quote
Old 10-25-2021, 08:32 AM   #199
SparkyRnD
SparkyRnD's Avatar
thanks for contacting us! I'll shoot a PM to you shortly
Old 01-04-2022, 09:39 AM   #200
SparkyRnD
SparkyRnD's Avatar
back up again!
