Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-06-2014, 08:30 AM   #176
billinthehills
Re: F/S Wiper Delay
I would like to purchase one of your gen 2 delays for my 65. My wipers are hooked upon toggle switch and appear to be single speed. Anything out of ordinary to install? If you could send me a PM on how to pay, I would appreciate it.
billinthehills is offline   Reply With Quote
Old 12-06-2014, 11:29 AM   #177
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
PM sent and thank you!
twouvakind is offline   Reply With Quote
Old 12-11-2014, 03:56 PM   #178
Black Burban
Re: F/S Wiper Delay
I received my delay switch a few days ago and installed it last night, works great, and was an easy install, thanks for a great addition to my 66 C-10.
Thought I would share a few things I noted during the install process for mid 60's C-10.
1) After being hooked up or test fit turn the delay switch on first to get delay function, then turn on factory switch for slow or fast speed. If you turn on factory switch first it will over ride the delay switch and you may think it is not working (like I did for a couple minutes...Blonde moment or in my case old and gray...LOL)
2)I used the hole already in the bottom edge of the dash below the wiper switch for the new delay switch (page 2 post #43-48), I just used a washer for correct fit. I also drilled a 1/8 hole for the clocking pin on the new switch next to the factory hole. This keeps both switches near each other for easy use IMO.
3)My factory switch has two connections, one is a two wire and the other a single wire connection. I disconnected the single wire from the back of the factory switch and plugged in the single female connector from the delay then plugged the male connector from delay into the wire that I removed from the back of the factory switch.
4) power and ground were easy as there was a factory screw next to the steering column that worked great for ground. And the left side of fuse block has tabs that are keyed power and the delay power wire plugged right on.
This install took less than an hour and only a couple of hand tools. that was with a test fit of all connections and function first then doing the install. I hope this helps others add a simple yet great addition to there trucks.
Black Burban is offline   Reply With Quote
Old 12-11-2014, 09:51 PM   #179
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
I couldn't have said it better myself, thank you for the install experience and most of all.....THANK YOU FOR DRIVING IN THE RAIN!
Old 12-15-2014, 10:52 PM   #180
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top, currently limited to 60-66 production-67 to 72 not available
Old 12-19-2014, 09:07 AM   #181
cmabolt
cmabolt's Avatar
Re: F/S Wiper Delay
Want to purchase delay for 72. Please pm me eta and pmt info.
Thanks Chris.
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 12-20-2014, 10:46 AM   #182
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
Thanks Chris.
PM sent, just to be clear-I am still building for 60-66, makes a great gift!
Old 12-24-2014, 09:46 AM   #183
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 01-01-2015, 12:36 AM   #184
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 01-04-2015, 06:29 PM   #185
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 01-10-2015, 11:21 AM   #186
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 01-18-2015, 11:22 AM   #187
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 01-22-2015, 08:49 PM   #188
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 02-10-2015, 07:36 PM   #189
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
To top
Old 02-22-2015, 12:23 PM   #190
LPS68
Re: F/S Wiper Delay
Originally Posted by twouvakind View Post
Ready to ship!
This is the "next gen" wiper delay. The first gen saw much success in the 67-72 forum. This revised model will fit 60-72 MY's. 100% reversible and installs in minutes. Gives you approx. 3-30 seconds of delay and does not require harness cutting, splicing or soldering. The video shows the "install" in my 72, installing it in your 60-66 will be very similar. Instructions specific to 60-66 are included. A big thank you to CaptainFab as he was instrumental in making the adaptation to the 60-66 MY's possible.
http://www.youtube.com/watch?v=SWpj-...ature=youtu.be
Please see this informative post from 67-72:
http://67-72chevytrucks.com/vboard/s...d.php?t=593984
I would like to purchase your wiper delay, how do I contact you?
LPS68 is offline   Reply With Quote
Old 04-12-2015, 12:15 AM   #191
Captainfab
60-66 Nut
Re: F/S Wiper Delay
I am in need of a couple of your wiper delays. Do you have any available?
Old 04-15-2015, 01:23 PM   #192
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
PM sent
Old 06-05-2015, 12:30 AM   #193
sdwolff98
Turning Wrenches Daily
Re: F/S Wiper Delay
Twouv,
I am interested in a 60-66 delay switch as well IM me details how to get one from you?
thanks
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 06-15-2015, 06:27 AM   #194
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
PM coming and thank you for looking.
Originally Posted by sdwolff98 View Post
Twouv,
thanks
Sean
Old 09-02-2015, 12:04 PM   #195
3drburb
Re: F/S Wiper Delay
Are you still selling these wiper delays?
3drburb is offline   Reply With Quote
Old 09-04-2015, 09:52 PM   #196
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
PM sent
Old 09-05-2015, 12:59 PM   #197
mikie 1954
Re: F/S Wiper Delay
I got one, very nice upgrade and simple to install now if we can just get some rain.
mikie 1954 is offline   Reply With Quote
Old 09-10-2015, 09:05 PM   #198
twouvakind
twouvakind's Avatar
Re: F/S Wiper Delay
Thanks for the kind words, enjoy!
Old 09-11-2015, 06:49 AM   #199
PGSigns
PGSigns's Avatar
Re: F/S Wiper Delay
They are a nice setup. Once you put on on and get used to using it would be hard not to have it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-14-2015, 06:24 AM   #200
67chevy4x4c
Re: F/S Wiper Delay
I would like to get wiper delay for 67/72
67chevy4x4c is offline   Reply With Quote
