Old 01-02-2014, 01:13 PM   #176
solidaxel
solidaxel's Avatar
Re: 49 ls1
Me neither !!!
That is why I am asking questions BEFORE I string it up!
Thanks for the info, this is my first 4 bar.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-02-2014, 01:46 PM   #177
99 to Life
99 to Life's Avatar
Re: 49 ls1
The angles look good, I haven't peeped your links yet, but will. I like reading up anything I can. A side note for the fellas asking about the angles, those are one thing. The other thing is keeping in mind your bag travel. At ride height, you want the bottom bars level and your top bars level or from what I'm told, slightly higher on the axle and a slight grade to your xmember. What the top link bars do here or on a wish bone is not only keep the axle from going left to right but also keeps it from axle wrapping (if doing bolt on lower links) and or less stress on lower link bars that are welded to axle. These bars IMO are more critical than the lower link bars, tho both are extremely critical.
oh, I forgot to mention all angles and link bars should be added when the axle is at the proper ride height pinion angle, which is based off of your trans. looks like that is what sarge did. on system with bolt on link bars (many people do) its a bit more forgiving because you can shim your axle to adjust pinion.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-02-2014, 02:33 PM   #178
skymangs
skymangs's Avatar
Re: 49 ls1
Exactly 99. My frame is was mocked up at ride height, with a +1 degree pinion angle (so when it's under torque it should travel to 0 degrees). The uppers are by far the most critical, the angle of the uppers will affect your anti-squat. In simple terms, If your instant center is too far forward, the axle will try to force upwards under acceleration causing hop and traction issues. If the instant center is too far back, you will end up with axle wrap, pre-mature tire wear, and Huge amounts of stress on your link/tab ends.
Also, the higher off the axle tube that the uppers are, the better it will control axle wrap (within reason) this measurement should be no less than 25% of the total tire height. My uppers are a shade over 8" above the lower link mounts. I'm using 24" tall tires, so my upper and lower links need to be separated at a minimum of 6" in height. If you were building a rock crawler with 40" tires, you would want your upper and lower links vertically separated by at least 10 inches.
Uppers should be situated at an upward angle, but as I said before, the horizontal roll center (viewed from the side) needs to be at least 50% of the COG, but shouldn't exceed 80% of the center of gravity (middle of the bell housing). It makes sense to me, but sounds very confusing... LMAO!
skymangs is offline   Reply With Quote
Old 01-02-2014, 10:52 PM   #179
skymangs
skymangs's Avatar
Re: 49 ls1
not too many pics today. finished seaming all my suspension today, removed the rear crossmember and spring perches, and mocked up the gas tank today. I also fixed my frame rust. here's pics.
Old 01-02-2014, 11:27 PM   #180
99 to Life
99 to Life's Avatar
Re: 49 ls1
ha, I was just looking up tanks today. Yours looks like a 65 stang. I'm looking into blazer tanks and also repro chevy car tanks, all exit out side and are good specs and prices are good. I just gotta confirm my area and see if how big of a tank I want.
Old 01-03-2014, 12:13 AM   #181
skymangs
skymangs's Avatar
Re: 49 ls1
Yup, 65 Stang tank. If it makes any difference, this tank will fit with a 5 gal air tank in front of it. Gives about 1.5" of clearance behind the diff at full stuff. I just liked it cause it didn't require straps, and seemed pretty compact. I hear now that the 68-9 tanks are 18 gal instead of 16. Next time.
Old 01-03-2014, 12:26 AM   #182
oldman3
oldman3's Avatar
Re: 49 ls1
Hey Chris, since you already have your tank, are you going to be running and external pump, etc for the ls engine...Jim
oldman3 is offline   Reply With Quote
Old 01-03-2014, 12:43 AM   #183
skymangs
skymangs's Avatar
Re: 49 ls1
Yes sir, external pump with Corvette return style fuel filter. I'm gonna use a universal fuel sender dropped in the top of the tank for the 0-30 ohm stock 55 Chevy fuel gauge in the dash.
Old 01-03-2014, 10:44 AM   #184
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
Im looking at that same tank... on ebay! Like $108.00 plus shipping!!! The good thing is they are right here in Charlotte, I just dont know if they stock or drop ship yet. LOL I asked about dimensions, but havent gotten a response yet. I was going to ask about the pickup/sending unit, but you kinda answered that already. Where do you get the sender/pickup and what mods will you have to make to it to make it work with that tank?
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 01-03-2014, 11:01 AM   #185
skymangs
skymangs's Avatar
Re: 49 ls1
I got that tank off ebay as well. It was like $72 + shipping. It is the one with a drain (thought it would be smart). The tank is 32" wide and 24" deep. Just perfect, I can fit my air pumps on either side of it, and 5 gal air tank in front behind the rear end. This one came with a ford sending unit and pickup (Ford 230-73 ohms). As far as I know, no one makes a GM sending unit that fits it, I am going to order a universal sending unit off ebay, and mount it in the top of the tank, along with my fuel return line. No mods needed, just cut the hole and drop it in. Be sure to do this BEFORE you put gas in the tank (cause gas fumes and sparks don't mix) and vaccum it out (rinse too) before you try to run your engine.
All GM fuel gauges are 0-30 ohm until 1964, then they switched to 0-90, all aftermarket GM fuel level gauges seem to be 0-90. so be sure your sending unit is for the correct ohms for the gauge you are using.
Old 01-03-2014, 11:23 AM   #186
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
Thanks for the info!
Old 01-03-2014, 11:56 AM   #187
99 to Life
99 to Life's Avatar
Re: 49 ls1
For those of you using an original 6v fuel gauge with 12v wiring harness, here is a voltage reducer. They also sell those universal sending units. Any repro chevy tanks (not sure about ford) all make the sending units holes based off of modern repro sending unit bolt patterns, not the old bolt patterns. Like sarge is doing however, is just drilling his own sending unit pattern, with a new tank def ideal. I ran into all these problems on my 51', so I ordered a tank from tanks ink and a 30ohm sending unit. Spent too much on it, should have went a different route, glad I am on my 49' but using different tank and location.
http://www.classicparts.com/1947-54-.../#.UsbbPbQy7g4
Old 01-03-2014, 12:49 PM   #188
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
I was going to use the stock s10 fuel tank, but I have changed my mind because it limits exhaust routing, and i dont like that. So i have been thinking for awhile about the mustang tank. Plus I'd like to get my cab a little closer to the frame than most are doing. Thanks for the info 99. At this time I dont plan to use the stock gages, as I dont have any in my truck, but will still need to know that type of info for what I am planning to use. WHEN I get to that point!
Old 01-03-2014, 03:12 PM   #189
99 to Life
99 to Life's Avatar
Re: 49 ls1
billy no prob, not trying to clog up this thread, just adding some little pointers. with the s10 location tank it really isn't a bad location as you can just run your exhaust over to the pass side and stop right after cab, easiest route ever, but no tail pipes. just all depends on what you got goin on. reason I don't like rear end tanks is fear of being rear ended. You should see my s10 that got hit and ran, pushed the bed all the way into cab. But with most bagged builds the rear tank is good because it keeps the tank far off ground. As for your gauges, if your not that worried about it, just use stock tank and sender with a little aftermarket gauge you can hide under the dash.
Old 01-03-2014, 08:17 PM   #190
skymangs
skymangs's Avatar
Re: 49 ls1
Billy, I used a stock S10 tank on my 48 build. I actually like the location, it allowed me to place my fuel neck out the dvr side of the bed side, below floor height for a clean "could have been factory" look.
I routed the exhaust along the right side of the bed, then exited below the tailgate. My 48 s10 framed build is in my sig if you want to check it out.
~Chris
Old 01-03-2014, 09:38 PM   #191
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
Oh I already did Sarge! I actually followed it while you were building it! I liked the entire thing! Your build gave me lots of ideas and directions for mine.
Old 01-03-2014, 11:38 PM   #192
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks, I used a lot of other folks build ideas, and then tweaked them to what my kid wanted. The most important thing to remember on these old trucks is... whether you did it right, or you did it wrong, at least you did it! That's more than 99% of the world can say.
As long as it's safe I mean... LoL
Old 01-03-2014, 11:52 PM   #193
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
I agree. My dad had a 51 for as long as I can remember and I'm 45. I don't remember him not having it! We still have it although there isn't much left of it anymore. My brother has it now. I'm using the front clip from another 51 that my dad had for a very long time on my 49.
Old 01-04-2014, 12:16 AM   #194
Billys68SS
Billys68SS's Avatar
Re: 49 ls1
What are you planning to do with the oe sender hole in that strange tank?
Old 01-04-2014, 12:30 AM   #195
skymangs
skymangs's Avatar
Re: 49 ls1
ayep... Keep em in the family. My old man has Packards, Buicks, and Cadillacs. They will stay till at least my grandkids inherit them all!
I was going to leave the Ford sender, and use the fuel pickup that's there. Then add a bulkhead return and the universal sender to the top of the tank. I've also changed around plans for the rear bags. I'm going to axle mount them under the C-notch now. Should have pics tomorrow of that. At least mocked up.
Old 01-04-2014, 11:56 PM   #196
skymangs
skymangs's Avatar
Re: 49 ls1
Got good updates today. I decided that I didn't really want the bags hanging on my lower links afterall, so I went with a bag-over-axle setup. Made my C-notches out of 2x4 1/8 wall square tube. Set the bottom of the C-notch 5 7/8" off the top of the axle tube, to account for 3 3/8" of compressed bag and plates, 1" of pedestal off the axle (to access the lower bolts) and 1.5" lower I wanted the running boards at full stuff. Here's some pics.
Old 01-04-2014, 11:59 PM   #197
skymangs
skymangs's Avatar
Re: 49 ls1
Here's mocking up the C-notches and getting the lower bag plates ready to weld on the axle
Old 01-05-2014, 12:03 AM   #198
skymangs
skymangs's Avatar
Re: 49 ls1
Here's the finished product. Boards are exactly 2" off the ground. With my 24" tall tires, that will make the boards 1/2" off the ground aired out. Now my issue is that the oil pan is touching the garage floor! Anyone have any real measurements on that Hummer oil pan? I need 2" shorter than stock truck oil pan, otherwise it's cut and TIG the damned thing.
Old 01-05-2014, 12:18 AM   #199
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49 ls1
Super nice progress man. I like the bag over axle alot better than on the links for sure. Very nice work buddy.
--Josh
Old 01-05-2014, 12:56 AM   #200
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks Josh, that C4 setup you're building is gonna be tits! I'm a little jealous. LoL
Yeah, the lower links taking all that additional stress wasn't sitting to well with me. I know that those S10 guys do it, but that doesn't mean it's the right answer.
Tomorrow I'm going to try to get the tank framework, Air pumps, and air tank figured out. My air line and fittings should be here on Monday or Tuesday. My old man's gonna be here this coming weekend, and I'd like for it to go up and down when he comes out to the shop to check it out.
