Old 05-07-2014, 11:46 AM   #176
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1963 C-10 SWB BBW Fleetside in NC
Looks nice.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-07-2014, 12:04 PM   #177
1963c-10
1963c-10's Avatar
Originally Posted by T.J. MCCAULEY View Post
Looks nice.
Thanks TJ. Came out pretty good considering what I started with. Surprisingly....no rot or pinholes....but a good coat of surface rust. Found a little pitting, but nothing to weld up or replace. Used my usual rust converters, primers and paints. I used an engine paint on the shroud just due to the radiator temps....probably overkill, but its what I used.
Worse part was some giant bondo overspill to clean up. Didn't find any repairs on the shroud, so must have been from the truck it was pulled from.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-07-2014, 12:10 PM   #178
Ta2Don
Ta2Don's Avatar
Me Likes!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-07-2014, 02:48 PM   #179
1963c-10
1963c-10's Avatar
Originally Posted by Ta2Don View Post
Me Likes!
Thanks Don!!!
Old 05-13-2014, 10:21 AM   #180
1963c-10
1963c-10's Avatar
Classic Industries was running a 20% off sale for mother's day, so ordered the turn signal switch that was destroyed in shipping and ordered the new cab mounts. Now I can get the last of the frame prepped under the cab and install it for the last time. Once cab is mounted I can get the auto steering column installed and the steering wheel on.
Old 05-27-2014, 09:39 AM   #181
1963c-10
1963c-10's Avatar
OK, got the truck moved on to concrete and under shade yesterday so I can get back on it. I have new cab mounts in, so I can lift the cab and finish the frame prep and get it bolted down for the last time and then install the steering column. Ordered a new outer tie rod for the bent one, so the front end should be good minus new brakes and lines.
New parts in:
cab mounts
turn signal switch and column bearings
deluxe steering wheel
GMC side window trim
60-61 wide front windshield trim
front end rubbers and seals (inner fenders and such)
Was real fun moving the truck alone with no brakes or steering down the hill, but I got it done.
Old 05-27-2014, 10:13 AM   #182
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Least ya got it there in one piece! LOL!
Old 05-27-2014, 10:16 AM   #183
1963c-10
1963c-10's Avatar
x2......and now I have shade and concrete!! Will be a big help, especially when pressure washing. No I don't have to let the dirt dry before I get back under it. And it'll stay dry now too.
Old 05-27-2014, 11:33 AM   #184
McMurphy
McMurphy's Avatar
Couple of walls and a door and you would have a pretty decent shop there sir!!
Though i am sure that has already crossed your mind
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 05-27-2014, 11:47 AM   #185
1963c-10
1963c-10's Avatar
That's what the 24x48 3 stall barn on top of the hill will become.
Old 05-27-2014, 11:52 AM   #186
McMurphy
McMurphy's Avatar
3 stall shop = drool
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 05-27-2014, 11:59 AM   #187
Sharps40
Host lost the pics, sorry.
Sharps40 is offline   Reply With Quote
Old 05-27-2014, 01:30 PM   #188
1963c-10
1963c-10's Avatar
I milled 2" thick planks 17' long and most around 20" wide last fall from 100' yellow pines that I was dropping around the house. They have been taking up space under the carport until they were dry enough to use. So spent all of Sunday dragging them up to the build site and milling them down to rafter size. Most are 7"-10" now. Very time consuming doing the tree work and milling myself, but its cost effective. Them cleaned up the carport and moved the fleetside into it.
The poles will be the main supports and they have been in since fall/winter so they can settle. They are solid now. Roof up soon and then some concrete down and I can get the walls up. Will be so nice to finally have an enclosed area to work, but the carport is an upgrade from the yard.
Old 05-27-2014, 01:35 PM   #189
1963c-10
1963c-10's Avatar
Originally Posted by Sharps40 View Post
Jes remembered. Update on the custom gun I told ya about earlier. Finished it up and here it is.......Too bad yer keepin the 63 cause I'da swaped it sure nuff and ya wouldn't have so much grease under yer fingernails! HA!
And nope, that black ain't DuraCrap nor GoneKoteCrap nor even CermaKrap....its old time Slow Rust Black!
Came out great Rich, but I have to respectfully decline. The fleetside has grown on me and I have plans for it. If anything changes I'll be sure to let you know and I'll keep my eyes peeled for you down here.
Old 05-27-2014, 09:30 PM   #190
Sharps40
I knew ya wasn't gonna sell it or trade it when ya spent months planning for the pick up trip and then got the cab and box assembled and on a frame and on the trailer and outta there in under 3 hours! HA! I never stood a chance of getting tween a man and his plans for a BBW Short Fleet! But don't worry, that lil Lightning Sheriff is posted up on gunbroker and teasing and tickling thousands of wallets even as we type back and forth!
Old 05-28-2014, 09:29 AM   #191
1963c-10
1963c-10's Avatar
Here you go Rich....a 65 sb fleetside custom cab in Wendell for $1200
Link: http://raleigh.craigslist.org/cto/4491463570.html
Old 05-28-2014, 09:54 AM   #192
Sharps40
Wrong year. Gotta be a 63 for me so I can trade my 65 on a 55 for GoodWife. But it'll be down the road bout a year yet anyhow unless its cheep like that one there. Sellin the house and castin about for a retirement property loaded with deer and nutgetters and wabbits and a shootin range.
Old 05-28-2014, 09:59 AM   #193
1963c-10
1963c-10's Avatar
Gotcha....I'll keep on the look out for you then. Didn't know you specifically wanted a knee knocker.
Old 05-28-2014, 10:01 AM   #194
Sharps40
Yep. 63 is the birth year. The 64 and the 65 are just temp fillers till I find the right 63.
Old 05-28-2014, 10:40 AM   #195
1963c-10
1963c-10's Avatar
Gotcha....I'm on the lookout!!
Old 05-28-2014, 11:35 AM   #196
1963c-10
1963c-10's Avatar
Heading up to a small yard Sunday in Greenville NC if anyone wants to go. Guy has around 10 1960-66 parts trucks and trucks for sale. Leaving my place at 8:30 or can meet up there. Has tons of parts.
Old 05-28-2014, 01:12 PM   #197
1963c-10
1963c-10's Avatar
Heres a link to about 20 picks of his yard and treasure trove of 60-66 trucks
http://67-72chevytrucks.com/vboard/s...=1#post6696551
Old 05-29-2014, 10:58 AM   #198
1963c-10
1963c-10's Avatar
Rain stalled me for a little last night. But had time to jack up the front of the cab to grind off the last 4 rivots of the bellhousing crossmember. Will get rust converters and paint down on the next 2-3 days and the new cab mounts on. Then I can install the fresh auto steering column. I replaced the bearings, cancel cam switch and wiring. Should be good to go for a few more years.
Old 05-29-2014, 10:59 AM   #199
1963c-10
1963c-10's Avatar
Also got the 60-61 style fresh air vents ready to install. This will put cable pull vents in....same as the 63 step side. I like them much better, especially when using them while driving.
Old 05-29-2014, 03:32 PM   #200
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
You have no idea of how jealous I am of you!!! Wish I new of some yard that had that much eye candy!!!!!!! MAN!!! NO FAIR!!!!!!!!!!! LOL!
