Old 01-15-2017, 02:47 AM   #176
MTCK
MTCK's Avatar
Re: 77 k10 short box winter beater build
Looks great! That's nothing you should see all the runs on my plow hahaha.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-15-2017, 05:32 PM   #177
Jaysonb
Jaysonb's Avatar
Made a little progress today. I might put the box back on the truck before I do the bed liner, I don't trust my work stand with me climbing around in the box.
Jaysonb is offline   Reply With Quote
Old 01-15-2017, 07:57 PM   #178
rusty76
rusty76's Avatar
That looks great
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-16-2017, 06:22 AM   #179
MTCK
MTCK's Avatar
Originally Posted by rusty76 View Post
that looks great
x2
-Marcus
Project Plow Truck
Old 01-17-2017, 02:01 PM   #180
Jaysonb
Jaysonb's Avatar
I'm in the home stretch now.
Old 01-17-2017, 07:36 PM   #181
Matt Man
Matt Man's Avatar
Looking good! Wanna paint mine next? How much adjustment is there on the beds of these trucks?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-17-2017, 07:44 PM   #182
Jaysonb
Jaysonb's Avatar
Thanks man. When you put a bed together, everything bolts together, then there are a couple welds on the rear tailgate posts. There is really no adjustment. About the only adjusting you can do once it's together is move the tailgate posts with a porta power to fix the tailgate gaps.
Old 01-17-2017, 08:01 PM   #183
Matt Man
Matt Man's Avatar
I meant once the bed is on the frame. Is there a lot of adjustment in it to line it up with the cab ect.
Old 01-17-2017, 11:20 PM   #184
Jaysonb
Jaysonb's Avatar
Yes, I did it by myself this morning, and it took a couple hours of moving big washers around to get the body lines as close as I could. I used a long straight edge, and 2 different thickness washers to get it as close as I could.
Old 01-21-2017, 10:20 PM   #185
Jaysonb
Jaysonb's Avatar
I made a new taillight harness, and got that installed, I had to do some sanding and buffing on the box, and got about half the trim on the box installed.
Old 01-22-2017, 10:42 AM   #186
rusty76
rusty76's Avatar
Looks great.
My build thread
Crossmembers CC
Old 01-22-2017, 11:13 AM   #187
moregrip
moregrip's Avatar
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-22-2017, 02:16 PM   #188
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: 77 k10 short box winter beater build
the yellow stripe trim goes so well with the colors
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 01-22-2017, 07:14 PM   #189
Jaysonb
Jaysonb's Avatar
I got all of the trim installed, I still have the wheel moulding to install, but I have to paint the stripes yellow. I had help this afternoon getting the inside of the bed prepped for bed liner.
Old 01-22-2017, 07:21 PM   #190
cochino12
It followed me home?
cochino12's Avatar
Looks great!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-22-2017, 10:55 PM   #191
MTCK
MTCK's Avatar
Looks amazing! Bring on the salt.
-Marcus
Project Plow Truck
Old 01-23-2017, 12:43 AM   #192
Matt Man
Matt Man's Avatar
Looking forward to the bedliner, I want to do this to my truck as well. Which one are you going to use?
Old 01-23-2017, 01:22 AM   #193
Jaysonb
Jaysonb's Avatar
I am going to use Sem Rock-it liner. It is a spray in bed liner kit that seems to have good reviews. I have had good luck with all of the other Sem products I have used, so I will hope for the best.
Old 01-24-2017, 07:12 PM   #194
Jaysonb
Jaysonb's Avatar
Well, I don't think I could be any happier with the way the bed liner turned out. It's still curing, so there is still some glossy spots.
Old 01-24-2017, 10:28 PM   #195
Jaysonb
Jaysonb's Avatar
Got the wheel wells undercoated, got the yellow stripe painted in the wheel well moldings, and got them installed, and cleaned up and installed the center caps. Should be able to take it for a spin this weekend!
Old 01-26-2017, 05:04 PM   #196
Jaysonb
Jaysonb's Avatar
Drove the truck to work this afternoon. 75 miles. It idles smooth, but under power it seems to run a little rough. Speedometer doesn't work, fuel gauge isn't reading accurate, and there is a bunch of wind noise from the passenger door. This little list of stuff will give me something to tinker with for awhile.
Old 01-28-2017, 12:01 AM   #197
Jaysonb
Jaysonb's Avatar
I advanced the timing a little and now it runs pretty good. On the 150 mile round trip I only got 11.5 mpg. Advancing the timing made a big difference in throttle response, and it didn't feel sluggish like it did before, I hope it helps the mpg.
Old 01-28-2017, 01:24 AM   #198
3drburb
Your truck looks great. Nice work.
I hope you get it tuned a little better. I had a 78 with a 250 in it years ago and I would get no better than 11 mpg.
3drburb is offline   Reply With Quote
Old 01-28-2017, 09:13 AM   #199
Greenlee
Greenlee's Avatar
I love how this thing turned out! Can't believe how quickly you got it done either. It took me about 5 years to do mine and I think you did more work. You have a better shop though.
Greenlee is offline   Reply With Quote
Old 01-28-2017, 10:28 AM   #200
jott_06
Camaro Club
jott_06's Avatar
make sure to spray some cavity wax or oil in those bedsides, cab corners, and rockers before you do to much winter driving. This truck turned out too nice to let it rust out again.
jott_06 is offline   Reply With Quote
