08-06-2021, 01:03 PM | #1976 |
Re: A '54 named Busty
that's a great picture on the left, she's got a great look
08-06-2021, 01:43 PM | #1977 |
Post Whore
08-06-2021, 01:45 PM | #1978 |
Post Whore
looks a bit wavy but it's just on there for trial fitment since I still have to make the handle, I'll hammer the rubber trim molding on flat laters
08-06-2021, 01:47 PM | #1979 |
Post Whore
I am blown away at the quality of the door handle pieces and how well the chrome held up, I mean they are nearly 70 years old
using 0000 steel wool to give them a bit of spit shine |
08-06-2021, 04:43 PM | #1980 |
Nice work!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
08-06-2021, 09:34 PM | #1981 |
Post Whore
thanks, so two things left
1. hinges 2. weather stripping difficult to see in the pics, but there is a difference between the top hinge which has a bracket that seems perpendicular and the bottom hinge which has a bracket that is slightly at an angle |
08-07-2021, 01:51 AM | #1982 |
Post Whore
so this is interesting I can't get neither the top or the bottom hinge out of the door frame, great!
also the top one was missing one of the circle springs that keeps the door from opening too far and staying opened (common I guess) and it also is missing the narrow vertical strip on the outside (where I point) but the hinge seems solid and has no wiggle play in it the juice running down the A pilar is sum WD-40 I sprayed in there to get some unstuckness going |
08-07-2021, 01:53 AM | #1983 |
Post Whore
the bottom hinge appears to be intact (no circle springs come on this one) but there is significant up and down wiggability play in it (may require a new oversize pin or bushings)
08-07-2021, 08:55 AM | #1984 |
I rebuilt the hinges on the 48. Getting them out on the 54 was a bear, the tops didn't want to come out. I did finally work them out. Have fun!
08-07-2021, 02:14 PM | #1985 |
Post Whore
thanks Robert, I appreciate the feedback, I'm gonna take the passenger door off today and see if those hinges will be willing to come out
08-07-2021, 06:00 PM | #1986 |
When I rebuilt all my hinges, I got new pins, springs and cover plates from the filling station. I actually took pictures of the whole process if you want me to text you the pics. One of my hinges wouldn’t come out because the factory pin was pulled out enough to stop it. I had to cut the pin off. It was a big pain. There is also a bolt hole on the inside of the hinge the factory didn’t use but there were bolts in mine.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
08-07-2021, 07:28 PM | #1987 | |
Post Whore
and I ordered my pins and circle springs from the Filling Station as well, to show my appreciation and support. Last edited by Gregski; 09-03-2021 at 10:52 AM. |
08-07-2021, 07:31 PM | #1988 |
Post Whore
reason #54 why I love working on trucks
08-07-2021, 07:34 PM | #1989 |
Post Whore
we had better luck with the texter side hinges, they pretty much fell out
however on this side the door sheet metal was catching on the hinge brackets where it was bolted to them but nothing a gentle pry with a flat screw driver couldn't fix, also I strongly recommend using some mayo to help the metal slide out easier |
08-07-2021, 07:36 PM | #1990 |
Post Whore
so this is what the empty hinge cavities look like
08-07-2021, 07:37 PM | #1991 |
Post Whore
and this is the top hinge in the wild
Note the missing circular springs both ones were absent |
08-07-2021, 07:38 PM | #1992 |
Post Whore
and the bottom one
08-07-2021, 08:51 PM | #1993 |
Post Whore
well folks, git yer pitch forks there's gonna be a hangin'
it looks like the PO (Previous Owner) somehow welded the hinges to the inside cavity sheet metal, it's bugger welded so maybe they used a stick welder cause I honestly don't see how they would have jammed a MIG in there but who knows anyway now I have to order longer burs for my die grinder to see if I can grind them out lower hinge shown below Cuss Level = Expert! |
08-08-2021, 07:24 AM | #1994 |
I’m with you on this one, Gregski. Stick welders are a great way to spew messy blobs of weld into deep, inaccessible spots. My truck had a dozen of those fixes and some of them were challenging to remove, but seeing how you have overcome all the other problems you have encountered we will watch and learn something as you attack those hinge pockets. In the meantime, my pitchfork stands ready!
08-08-2021, 10:08 PM | #1995 |
How did you get to edit your older posts? I thought they turned off that feature a while ago.
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
08-09-2021, 09:20 AM | #1996 |
On the 54 I have one that I had to file out a little of the cab to get the hinge spring to go into the hole. So that looks familiar.
On the drivers side, welding a hinge like that is just, well add all the adjectives you can think of and then say BAD. I hope the die grinder will cut out the weld so you can repair that hinge correctly. I too used Jerry and the Filling Station. I asked a question and he responded personally. A really nice guy.
08-09-2021, 10:28 AM | #1997 |
holy sh!t!! that suuuuuuuuxxxxx
08-09-2021, 10:42 AM | #1998 |
Post Whore
08-09-2021, 12:05 PM | #1999 |
Post Whore
08-09-2021, 01:42 PM | #2000 |
