Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-26-2013, 11:55 PM   #2001
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130626_110117 by jarosaj, on Flickr
Found this hose wrap at the hydraulic shop the other day, keeps my wires together until i can wrap them up. Also, very easy to branch a bundle of wires out of the main harness
Made the clamp out of 1/4" tubing, hope i dont need that hole for the injectors
Measure twice, drill once
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-27-2013, 01:42 AM   #2002
Captainfab
60-66 Nut
Re: PO has me PO'd
Sorry to hear about your medical issue....sounds like it could be quite painful.
Your progress looks good
Old 06-27-2013, 10:21 AM   #2003
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, it was quite painful, just showed up one day. Tried working for two months with the pain, but finally realized i needed to see a doctor. Hard part was sitting and not working on my truck But, it did give me time to plan out the final steps of the build
Tank arrived yesterday, fuel line fittings should be here today! Tank appears to be a very nice repop, got the kit.....straps, sending unit, seems like a good deal for 200.00. S/B last of the large outlay of cash. Oh wait, still have to buy injecters, and three tires, anyway, that list is getting shorter
Thank goodness im past most of the wiring, a very difficult area for me, not my strong suit
Thanks Cap. for checking in
SAFETY FIRST
AS usual, off topic
Jim
Old 06-27-2013, 10:32 AM   #2004
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
The area around the map senser was a difficult area to squeeze everything in...fuel pressure gauge, air temp., adjustable fuel regulater, all had to fit in a small area. The item that made it work was a 90 degree rubber hose that was cut to fit. Found it while wondering around the parts store, many other attempts failed with brass fittings and such. Plus the fact that i had to move the map senser a 1/2" diagonally
SAFETY FIRST
AS usual, off topic
Jim
Old 06-27-2013, 08:49 PM   #2005
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130627_115429 by jarosaj, on Flickr
Now the age old question, change filler neck, or buy hose
SAFETY FIRST
AS usual, off topic
Jim
Old 06-28-2013, 02:04 AM   #2006
Captainfab
60-66 Nut
Re: PO has me PO'd
A new hose may or may not be easier, depending on the route from the filler to the tank. If you were to change the filler on the tank, as I'm sure you know, certain precautions need to be taken when working around old gas tanks with a flame.
Old 06-28-2013, 10:43 AM   #2007
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yes i do, but still worth repeating for the uninformed....my plan, if i go the neck route, would be to start a hole with a hammer and chiisel, and then follow up with tin snips or a nibbler. My tank has been empty for twelve years, but i still dont want to take the chance and blow myself into kingdom come.
There was an extremely funny story about a guy trying to solder a carb float over in the truck forum. All ended well, but it did show the importance of dealing with fuel in a contained space
SAFETY FIRST
AS usual, off topic
Jim
Old 06-28-2013, 12:08 PM   #2008
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130627_120311 by jarosaj, on Flickr
Corvette fuel rails use two 16 mm fittings, while camero use one 16mm and one 14 mm fitting. Make sure you get 1.5 thread size, as 1.25 is available
20130627_115908 by jarosaj, on Flickr
EDIT: HOLD OFF ON THE QUICK DISCONNECTS...just read where there is a chance they can come off, looking at the newer version
Using quick connect fittings to -6 at fuel pump, russell recommends installing plastic lock first to insure proper lock, then push on black aluminum adapter
SAFETY FIRST
AS usual, off topic
Jim
Old 06-29-2013, 01:32 AM   #2009
Captainfab
60-66 Nut
Re: PO has me PO'd
Sounds like a good plan.
Old 06-29-2013, 03:18 PM   #2010
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK, this is a NEW fuel tank, NEVER HAD FUEL IN IT!!! Tank depth is 13 5/16" where i am mounting pump, so the three rods have to be lenghtened to at least a 1/4" longer to apply pressure to the overfow tank
My wife always asks me, "why do you always spend so much money on a new part, only to spend time modifying it"
Used my dads old b&d jig saw to cut the hole for the intank pump
20130629_124619 by jarosaj, on Flickr
Now i have to make a aluminum retaining plate to pull the pump flange tight against the tank and seal
20130629_145641 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 07-04-2013, 02:58 PM   #2011
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
HOLY CRAP! BATMAN.....£€<«®¶]$o_OB-):-3%?? @sitting here reading my tablet, when a bomb goes off in my basement.. Wifey heard it all the way up on the third floor, she always checks on me when something untowards happens in the workshop!
Well after the immediate reaction of crapping my pants, and clearing my head, i decide to investigate. First the smell, one i was unfamiliar with, thought a ballast let go, but not quit right
Look over to my right, and one of my cabinet doors is open (where i store aerosols), you guessed it. A can let go! But, not paint. It was graphite, i determined this after i found the label, twenty feet away, can was destroyed
I have a bad habit of keeping old cans, probably have the largest collection on the this board, thirty years worth. Time to change old habits, and clean up this mess
Good news, that musty 125 year old damp basement smell is gone
SAFETY FIRST
AS usual, off topic
Jim
Old 07-04-2013, 10:10 PM   #2012
Dale99
Re: PO has me PO'd
I hadnt seen the fuel line pics as I was on vacation when you posted them. Looks good!
So all your paint cans are in the basement rather then garage?
I will say there is quite a collection of cans in my garage. Sometimes I do wonder how nothing has exploded yet.
Dale99 is offline   Reply With Quote
Old 07-05-2013, 08:11 AM   #2013
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Dale....yeah, my 'basement' is my working space, with all the machinary, work benchs. Parts are worked on in there, then moved into the workshop for assembly. Basement is 60' long with a 12' ceiling, workshop is only 14' by 18',but connected, so there isnt much room in there once you stuff in a lifted truck...
Following along on your build, nice work
SAFETY FIRST
AS usual, off topic
Jim
Old 07-05-2013, 03:03 PM   #2014
Dale99
Re: PO has me PO'd
Wow, that is a small workshop, but big basement.
Thanks, its not turning out as well as I planned so far. But I still have alot to go.
Old 07-05-2013, 04:45 PM   #2015
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, when i built it, i was restoring english sports cars which fit in there very nicely, never thought i would be stuffing a a full size Jimmy in there. But, after thirty years of restoration to stock specs. I had an urge to modify something. My boys are into off road and rocks, so i thought id build something to tag along, nothing serious, just the green trails
On your truck you can always go back and make changes, after you get it done, if you dont like the way something turned out
SAFETY FIRST
AS usual, off topic
Jim
Old 07-07-2013, 05:54 PM   #2016
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130518_104719 by jarosaj, on Flickr
Heres where i stripped the paint off the fuel rails tubing, couldnt believe they would paint over cadium
Since it was a 100 today, decided to spend the day under the truck with a couple of fans on. Tank is out, so i took the time to start the derusting, permatex rust converter, then brush on undercoating
SAFETY FIRST
AS usual, off topic
Jim
Old 07-08-2013, 06:46 AM   #2017
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
2000+ replies and 80 pages! DAYUM!
Looks great!
Thx for the call, good catchin' up with ya ~
vtblazer is offline   Reply With Quote
Old 07-08-2013, 07:26 AM   #2018
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Looks great!
Thanks for looking, yeah, just like old times....i like the look of your intake
Glad to hear your doing well. Yeah, is a rather long thread, but this could be the year. Tank is the last area that i havent taken apart, so, it should be all reassembly from here on out
SAFETY FIRST
AS usual, off topic
Jim
Old 07-09-2013, 11:19 AM   #2019
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130707_130023 by jarosaj, on Flickr
Rust converter is still drying in the light blue ares, putting on the 3M shutz with a 1" brush that i cut the brissels in half to about 1" , lets you work the undercoating into the deeply pitted ares. If you leave the brissels long, the undercoating tends to just roll over these areas
Try to cover up as much as possible, this stuff has to wear off, and use plenty of ventilation, i have two fans going with the door open
New 56" springs bought from Special K, thanks Tim, will install down the road to get rid of the 4" lift blocks
Seems that i have to relocate my tank 2" forward, to clear a cross brace, and have the fill tube clear a body mount better
SAFETY FIRST
AS usual, off topic
Jim
Old 07-13-2013, 09:59 AM   #2020
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130711_125904 by jarosaj, on Flickr
New problem with the tank install, is anything ever going to go easy on this build. I doubt that i will be able to find these pieces, so i will make them out of aluminum.
Ive determined that moving the tank forward 2" will give me the best all around clearance. Just have to bend the brake hose bracket alittle
SAFETY FIRST
AS usual, off topic
Jim
Old 07-13-2013, 10:05 PM   #2021
dujobu
Re: PO has me PO'd
What are those parts? Just spacers/shims? I had mine cleaned up and powder coated and reinstalled them, but was never sure what their function was.
dujobu is offline   Reply With Quote
Old 07-14-2013, 09:47 AM   #2022
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I think they are more then spacers, with the tabs in both the tank and the spacer, i believe they help lock the tank from shifting forward and reverse. Not sure just my thoughts....
SAFETY FIRST
AS usual, off topic
Jim
Old 07-15-2013, 08:15 AM   #2023
Dale99
Re: PO has me PO'd
Sad part, I tried selling some of them earlier in my project. I think I ended up scrapping them.
Old 07-15-2013, 09:02 AM   #2024
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for thinking of me anyway, sadder part, i threw out my bucket seats and factory gas tank skid plate, thinking they werent worth anything.
SAFETY FIRST
AS usual, off topic
Jim
Old 07-15-2013, 09:22 AM   #2025
Dale99
Re: PO has me PO'd
ouch
