08-10-2021, 01:19 AM | #2001 |
Re: A '54 named Busty
That makes sense
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
08-10-2021, 12:11 PM | #2002 |
When I rebuilt my hinges, I welded washers on the end of the springs to prevent them from coming out in the future. Some preventative maintenance
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
08-10-2021, 12:16 PM | #2003 |
Post Whore
that is hella smart! thank you for sharing
08-10-2021, 08:16 PM | #2004 |
Post Whore
100° F
package arrives game on! Last edited by Gregski; 08-10-2021 at 08:23 PM. |
08-10-2021, 08:22 PM | #2005 |
Post Whore
they say size doesn't matter!
08-10-2021, 08:45 PM | #2006 |
Post Whore
say hello to my little friend
08-10-2021, 08:47 PM | #2007 |
Post Whore
one beer later
08-10-2021, 08:50 PM | #2008 |
Post Whore
Fun Level = 2
not only are you grinding semi blind but you can't really get the angle as well as you would like |
08-10-2021, 08:51 PM | #2009 |
Post Whore
a bit of repair will be required to the hinge, here's a stare and compare of the East side with the West side
08-11-2021, 07:45 AM | #2010 |
08-11-2021, 10:14 AM | #2011 |
Glad it came out with only one beer. That worked. Now for the easy part. Are you going to weld a tab on to replace what the PO cut off or are you going to just get a new base? I stuck with the original arms as I was told they can be different.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
08-11-2021, 11:48 AM | #2012 | |
Post Whore
I was thinking adjustability or something by pulling the hinge in and out but the hinges only adjust up and down so I don't know |
08-11-2021, 12:06 PM | #2013 |
I don't know what the hole was for, but it may have been used on other GM products that did use it.
I used the vent hole on the R side and made a small hole on the D side and put a bolt in it to help make sure the door doesn't move.
08-11-2021, 05:01 PM | #2014 |
Post Whore
yup, less than 10 minutes of use, not abuse, just allowing the tool to do the work
08-13-2021, 12:10 AM | #2015 |
Post Whore
the top hinge was a bear
08-13-2021, 12:12 AM | #2016 |
Post Whore
one wine bottle later
08-13-2021, 12:16 AM | #2017 |
Post Whore
so this one got mangled in the extraction process as well and will need some gentle tickling
08-13-2021, 12:18 AM | #2018 |
Post Whore
looks like the new hinge springs and pins arrived just in time
08-13-2021, 12:26 AM | #2019 |
Post Whore
next up was the task of aparting the hinges, I decided to start with the bottom ones since there is less math involved (ie less moving pieces, these don't have them C clip spring looking thingies)
well the pin was rusted shut so after trying the BFH and the shop press I decided that Escape from Alcatraz was the sound method of separating things up |
08-13-2021, 08:37 AM | #2020 |
Ahhh, the fun of removing the pin! You got this whipped now.
08-13-2021, 10:41 AM | #2021 |
Post Whore
thank you brother I knew this was going to be a bit of an ordeal that's why I ignored it and put it off as long as I could, but looking back I should have done them first when I was painting the cab, like you did
08-14-2021, 01:38 AM | #2022 |
Post Whore
so it was time to fix the driver side bottom hinge
08-14-2021, 06:55 AM | #2023 |
Man, you are awesome!!! Thanks for the updates.
08-14-2021, 08:03 AM | #2024 |
Looking good Mr. Greg.
08-14-2021, 10:28 AM | #2025 |
Post Whore
