Old 08-16-2021, 02:18 PM   #2026
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
a little spin on layinrocker65 idea of welding on the washers to keep the C lips from coming out, I decided to weld some on to the pins rather than attempting to mushroom the ends
Gregski is offline   Reply With Quote
Old 08-16-2021, 02:19 PM   #2027
8man
That works!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 08-16-2021, 05:25 PM   #2028
Gregski
Post Whore
Gregski's Avatar
fellow truckers, lemme see if I can explain this situation so maybe you can help me
how tight are we supposed to make these hinges, I think I collapsed the pin on the rebuilt one just the way I found it so there is about 1/16 of an inch gap in the clam shell if you will, so is it supposed to be that loose or is it supposed to be zero lash ?
Old 08-16-2021, 08:01 PM   #2029
Gregski
Post Whore
Gregski's Avatar
then it was time to repair the driver side top hinge
second verse
same as the first
but a whole lot messier
and a whole lot worse
Old 08-16-2021, 08:04 PM   #2030
Gregski
Post Whore
Gregski's Avatar
this one required more brainstrology
Old 08-16-2021, 08:06 PM   #2031
Gregski
Post Whore
Gregski's Avatar
so we procured the rustiest square a tubing we could find, this was gonna give us that right angle stopper piece
its wet cause I used water to cool it off after all the cutting
Old 08-16-2021, 08:07 PM   #2032
Gregski
Post Whore
Gregski's Avatar
and since no one will ever see this piece and never know what the repair looks like, I decided to spend many many hours making it as original as possible
Old 08-16-2021, 08:08 PM   #2033
Gregski
Post Whore
Gregski's Avatar
there, not too shabby, and once we spray it with some rust, no one will be the wiser
Old 08-16-2021, 08:10 PM   #2034
Gregski
Post Whore
Gregski's Avatar
and here I am drilling a pressure relief pilot hole in hopes of persuading that rusted pin out
Old 08-16-2021, 09:49 PM   #2035
layinrocker65
layinrocker65's Avatar
My hinges were at "zero" lash when I did them. I wanted everything to be as tight as possible.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 08-16-2021, 11:41 PM   #2036
Gregski
Post Whore
Gregski's Avatar
thanks bud, appreciate the feedback
Old 08-16-2021, 11:42 PM   #2037
Gregski
Post Whore
Gregski's Avatar
and the carnage begins
Old 08-17-2021, 08:47 AM   #2038
8man
Nice work on the hinge repair. Good luck on drilling out the pin.
8man-aka Robert
Old 08-19-2021, 09:06 AM   #2039
daddyjeep
daddyjeep's Avatar
second verse
same as the first
That sounds a whole lot like the Little Red Wagon song that we sang in Cub Scouts
Anyway... I would think you want those hinges pretty tight. That little bit of slop at the hinge will turn into a lot more at the latch.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-23-2021, 11:51 PM   #2040
Gregski
Post Whore
Gregski's Avatar
so got crackin on the hinges some more, and things were going backwards quick
Old 08-23-2021, 11:52 PM   #2041
Gregski
Post Whore
Gregski's Avatar
a little blood, sweat, and spilled beers
Old 08-24-2021, 12:00 AM   #2042
Gregski
Post Whore
Gregski's Avatar
When I rebuilt my hinges, I welded washers on the end of the springs to prevent them from coming out in the future. Some preventative maintenance
great tip, I took your advice
Old 08-24-2021, 12:02 AM   #2043
Gregski
Post Whore
Gregski's Avatar
and texter side done! feeling cute may shoot some paint on them later, IDK
Old 08-24-2021, 12:04 AM   #2044
Gregski
Post Whore
Gregski's Avatar
and in true Greg like fashion once again I got 3 out of 4 pieces done and decided to take a break!
Old 08-24-2021, 12:25 AM   #2045
layinrocker65
Those should work 👍🏻
‘53 GMC COE stock
Old 08-25-2021, 12:17 AM   #2046
Gregski
Post Whore
Gregski's Avatar
yay me got the fourth one done
Old 08-25-2021, 12:19 AM   #2047
Gregski
Post Whore
Gregski's Avatar
I tell you what doing things half @ss sucks, it just takes too long, all that sanding, wire wheelin' the rust, vacuuming it out, blowing it out, what happened to good ol' quality half @ss work, ha ha
Old 08-25-2021, 12:20 AM   #2048
Gregski
Post Whore
Gregski's Avatar
so after wire a wheelin' these bolts what do we use on them, loc tight or anti seizure?
Old 08-25-2021, 12:13 PM   #2049
layinrocker65
I used the “anti seizure” stuff
‘53 GMC COE stock
Old 08-25-2021, 12:32 PM   #2050
Gregski
Post Whore
Gregski's Avatar
ha ha, thank you
