Old 12-28-2019, 04:08 PM   #2051
smbrouss70
smbrouss70's Avatar
Re: How to: Ruin a perfectly good C10
I meant to ask about the Jeep fan last night when I was over there. How did you mount it, because I don't see the bolts that everybody else uses to hold the top arms to the inside of the shroud? Also, I thought the Jeep fans were a single speed fan?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-28-2019, 08:13 PM   #2052
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by cornerstone View Post
So glad to see these updates Gringo! This is the first I've heard of using the Jeep fan. I've been hoping to use my stock rad and shroud also, so now its clear as day how do handle it.
In answer to the question posed by C10_ustacould, I can shed some light on what I used for hoses for the Gen 5. The upper hose shows the part number. The lower hose is harder to see but it is a combination of the factory 2014 Silverado at the water pump and spliced to a 90 degree bend near the radiator inlet.
Check out this thread for more info on the Jeep fan: http://67-72chevytrucks.com/vboard/s...d.php?t=254617
Mounted per the above thread, I have cut the lower slot, but haven’t poked the top holes yet. There’s two versions of that same fan, I grabbed the Spectra CF13009 with 3-wire/2-speed
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-28-2019, 09:01 PM   #2053
gringoloco
A guy with a truck
gringoloco's Avatar
Getting everything prepped for the TKO, which should be here Monday. Chatting with smbrouss70 over beers last night, he talked about how much trouble he had getting his transmission to engage the pilot hole due to the sloppy tolerances of the plastic alignment tool.
In a rare genius moment, I decided to wrap the tool in foil tape to take up some of the slack. 2 layers worked perfectly! The new 26-spline clutch is torqued in place and hopefully allows the trans to slide in with ease.
-Chris
Old 12-28-2019, 09:11 PM   #2054
gringoloco
A guy with a truck
gringoloco's Avatar
Also spent a little time rebuilding my hydro throwout, as I got a little excited and accidentally forcibly disassembled it during removal of the Muncie. It got a new piston, seals, scrapers, and c-clip. Good to go.
Driveshaft also now has a new Spicer 1310-1330 conversion u-joint, ready to accept the 31-spline slip yoke for the Tremec. Fingers crossed I won’t have to shorten the shaft (it will be close).
-Chris
Old 01-02-2020, 09:52 PM   #2055
gringoloco
A guy with a truck
gringoloco's Avatar
After a few days spent having to do FedEx’s job for them, things just got interesting:
-Chris
Old 01-02-2020, 11:20 PM   #2056
TA_C10
TA_C10's Avatar
Boom.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-03-2020, 12:54 AM   #2057
smbrouss70
smbrouss70's Avatar
You're going to love it!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-03-2020, 09:48 PM   #2058
clay68c10
clay68c10's Avatar
I have a box like that in my garage! But I’m not nearly as far along as you. I’m going to be mocking everything up for fitment this spring.
Are you going to move the shifter to the mid position or just flip it around where it is now?
Make sure it shifts thru the gears, sometimes the shippers set the trans box on end and it puts the shift rods out of alignment. It will be in 2 gears at once. Mine was bound up, but it was easy to fix. There’s a YouTube video out there somewhere about it.
What clutch and throw out bearing are you using? Those are the last things I need. I’m using Capt Fab’s master setup, the Silver Sport bell, and I already have a flywheel.
Cool build, I’ve been following it for a while now.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-04-2020, 12:56 PM   #2059
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by TA_C10 View Post
Boom.
My feelings exactly
I sure hope so!
Thanks for the kind words!
I’m yet undecided on shifter location. I think rear-flipped will be fine, will see once I get it stabbed.
Clutch is an 11” big-block style, RAM 78125HD hydraulic throwout. Setup easy and worked great with the Muncie, should be similar with the TKO.
-Chris
Old 01-06-2020, 07:36 PM   #2060
knomadd
knomadd's Avatar
OH damn! I want one of those for my GTO!!!!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-06-2020, 09:18 PM   #2061
nlped
nlped's Avatar
I feel the same way! I want one for my Falcon
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-06-2020, 11:26 PM   #2062
gringoloco
A guy with a truck
gringoloco's Avatar
Had to check out your builds, nice cars both!
-Chris
Old 01-07-2020, 10:06 AM   #2063
clay68c10
clay68c10's Avatar
Thanks for the info, Gringo!
13 Tahoe LTZ
Old 01-11-2020, 10:25 AM   #2064
shearjs
shearjs's Avatar
Anytime I need inspiration for the Burb, it always brings me back to your thread. I appreciate your willingness to share your findings and expertise with all of us. I also decided to go the Terminator X route and can't wait to start on that part of the project! Keep up the good work!
shearjs is offline   Reply With Quote
Old 01-11-2020, 09:24 PM   #2065
gringoloco
A guy with a truck
gringoloco's Avatar
No worries, this is why we’re here
Thanks man, love that ‘burb. You’re gonna love termi-x, plug and play, fires right up, and gets better every time I drive it
-Chris
Old 01-19-2020, 11:28 AM   #2066
gringoloco
A guy with a truck
gringoloco's Avatar
Well, the TKO is “in”. The easy, heavy-lifting piece is done, but it still needs a new mount spacer ( have a 3/4” piece of scrap wood in there for the moment), driveshaft shortened, clutch bled, floor clearanced, fluid filled, etc, etc.
I made these handy alignment dowels out of a pair of grade ‘cheap silver cad’ bolts. Simply lopped the heads off, chamfered the end, and cut a screwdriver slit for ease of removal. Worked like a charm!
-Chris
Old 01-19-2020, 11:38 AM   #2067
gringoloco
A guy with a truck
gringoloco's Avatar
Due to the dropmember moving the engine up, the transmission is very high in the tunnel, but should still just fit under the high hump. Remains to be seen, still need to fill the Muncie shifter hole and cut a new one.
-Chris
Old 01-19-2020, 11:49 AM   #2068
gringoloco
A guy with a truck
gringoloco's Avatar
This also places the shifter ball in a very high position. Currently, I’m using a 16” long lever, which exacerbates the issue and contributes to a very long shift throw. I’ll look into using a shorter lever around 10-12”, and possibly a short-shifter base if needed.
-Chris
Old 01-19-2020, 02:49 PM   #2069
Inverter
Inverter's Avatar
My shifter base boot pokes through the hump slightly. Diff motor mounted 5/8” higher than stock and @ 3* pitch. I remember the level 3 DM’s have the pitch at 5* or so,, didnt catch what series you have. Watch that 3rd gear...
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 01-19-2020, 03:53 PM   #2070
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Inverter View Post
My shifter base boot pokes through the hump slightly. Diff/motor mounted 5/8” higher than stock and @ 3* pitch. I remember the level 3 DM’s have the pitch at 5* or so,, didnt catch what series you have. Watch that 3rd gear...
Thanks for the info. I figure it will stick through a bit, worse if I decide to do a short throw (taller base). I set the angles up at 3.5, which is certainly a contributing factor to how high it sits. I also raised the engine ~3/4” to help tuck the long tubes up inside the framerails. 3rd is a knuckle-buster for sure, I’m looking at different stick options...
This is the snowball I was trying so hard to avoid, but it sure is fun figuring out the puzzle
-Chris
Old 01-19-2020, 08:03 PM   #2071
TA_C10
TA_C10's Avatar
Interested to see if the clearance will be enough all the way around in the high hump like you said. I guess it won't move around too much but.....
Looks killer man.
"It's only money".
Old 01-19-2020, 08:30 PM   #2072
Inverter
Inverter's Avatar
Originally Posted by gringoloco View Post
3rd is a knuckle-buster for sure,:
Once you get the stick position worked out,, look up the palming procedure for high rpm quick 3rd gear shifts for these units. Makes all the diff.
TROY
Old 01-20-2020, 01:14 AM   #2073
gringoloco
A guy with a truck
gringoloco's Avatar
Looks killer man.
Thanks, man. I tossed the cover on and there appears to be a quarter inch or so all around. The trans is hitting the floorpan behind the hump, though, where the shift rail housing is tall above the output shaft. Looks like a little more cutting is in my future...
Thanks, I’ve done some reading and watched the YouTube video. Looks like the idea is to just push up and let the centering springs do the work
-Chris
Old 01-20-2020, 01:23 AM   #2074
Inverter
Inverter's Avatar
Thats it. These boxes are really notchy. Mines loosening up but not what i was expecting.
TROY
Old 01-20-2020, 10:30 AM   #2075
smbrouss70
smbrouss70's Avatar
Looks good, but wow it sits way higher than mine does. Like Inverter said, it is quite notchy at first, but after about 2,000 miles on mine it seems to have worn in enough to make it feel much better.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
