Old 04-29-2015, 04:23 PM   #2101
brimc
brimc's Avatar
Re: 1972 Chevy 4wd Longhorn Project: Never Ending Changes
Everything looks great. What did you do for prep on the wheels and how did you paint them. I need to do this to mine also but haven't decided what to do yet.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 05-08-2015, 03:49 PM   #2102
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I had them sand blasted and then I cleaned them with degreaser. I used a wash primer, then epoxy primer, then sprayed gloss black on them. They turned out pretty decent.
I still haven't mounted the tires because I've been contimplating buying 35's still. Well, I think I'll just run the 33's for now because I've found another nicer LH longhorn bed side, and I have a new addiction. Hydro dipping..... I need to finish buying a/c pieces and small stuff more than I need taller tires that will probably just take away from mileage any how. Haha
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-08-2015, 09:02 PM   #2103
COS399
COS399's Avatar
That valve cover looks SWEET!!!
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-12-2015, 03:34 PM   #2104
Dieselwrencher
Thanks!
I got the Longhorn to our new house and it is now in it's own garage. For now.
These new to it wheels really brought the rear end back in to the bed sides too. Good thing I didn't hold out for 35s. It never would have fit in the garage. It barely fit under the door with the air bags dumped.
Ryan
Old 05-12-2015, 08:44 PM   #2105
watahyahknow
watahyahknow's Avatar
i allready was looking at that height of the garage door when i read youre comment about it
think the bigger wheels wouldve made the truck look a bit too mush like a cartoon as whell
these are exactly what the truck needs
hmmm wats with the exhaust so far back in the bed and the aluminium ting with the hoses sticking out of it .... are you building a remote turbo intercooler setup ?
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-13-2015, 08:18 AM   #2106
mcbassin
Still Learning
mcbassin's Avatar
Nice! The truck has his own bedroom How cool is that....congrats on getting the new place.
mcbassin is offline   Reply With Quote
Old 05-13-2015, 02:37 PM   #2107
brimc
brimc's Avatar
Those tires and rims look great on there!
BRIAN
Old 05-13-2015, 04:59 PM   #2108
Dieselwrencher
The exhaust in the bed is the unfinished tail pipes I started making. I need to cut my air bag upper braces so I can run the exhaust like I want it. The object in the bed with the hoses going to it are actually the truck's fuel tank right now until I get the new one made to go under the bed.
Ryan
Old 05-13-2015, 05:00 PM   #2109
Dieselwrencher
Thanks. Maybe some time soon I'll actually be able to work on it.
Yeah, they look better than I thought they would.
Ryan
Old 05-13-2015, 07:26 PM   #2110
watahyahknow
you could do a real seventies thing and put a big rig round aluminium tank sideways against the cab in the bed , saves tyou stopping at the gasstation twice a week
Old 05-13-2015, 10:27 PM   #2111
Dieselwrencher
I'm out on that. My last truck had a 40gal step tank in the bed and it made it a real pain to haul anything big.
Ryan
Old 05-14-2015, 11:24 AM   #2112
Motorfist
I can't recall in your thread if you are running the bed/saddle tanks or not? I'm running them and the cab tank in my LH and pack about 60 gallons of fuel for longer trips. It's awesome!
Your truck looks fantastic BTW
67 c30 Cab and Chassis (ex motorhome truck)
68 c10 LWB
70 c30 Cab and Chassis 133" converted to Longhorn
72 K10 LWB Rust Bucket Hunting Truck
Motorfist is offline   Reply With Quote
Old 05-14-2015, 12:05 PM   #2113
watahyahknow
you could do saddle tanks and one of those rearmounted blazer style tanks
there all under the bed
for a long trip you could basicly set a oildrum in the bed straped to the rollcage and have an electric transferpump hooked up to pump the contens intoo the bottom tanks
my guess is youre back will quit and beg for mercy before youre running out of fuel
Old 05-14-2015, 02:22 PM   #2114
Dieselwrencher
Thanks. I have saddle tanks I once was going to use on it. But I don't know if they'd even fit with the air ride brackets on the frame now. I have a 20-30gal transfer tank that is only about 8" deep that I may put up front in the bed and I will still have nearly an 8' bed still. I'm trying to keep bed space open because this is the only long bed truck I have now.
You're right on that.
Ryan
Old 05-14-2015, 08:01 PM   #2115
ryanroo
ryanroo's Avatar
Mine will end up with about 38 you can use in the tank and another sixty in the transfer tank. Figure I should have about 1800 miles of range, possibly more depending on actual mileage. Are you fabing a tank for it, mister?
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-15-2015, 02:38 PM   #2116
Dieselwrencher
Kind of. I may cut/bend the material and have Kyle tig it for me. We shall see. For now I can use the transfer tank.
Ryan
Old 05-15-2015, 08:25 PM   #2117
ryanroo
ryanroo's Avatar
What are you making it from?
72 K20 12v build
Old 05-18-2015, 03:00 PM   #2118
Dieselwrencher
SS or aluminum. Not sure yet.
Ryan
Old 05-18-2015, 04:42 PM   #2119
ryanroo
ryanroo's Avatar
I would avoid aluminum. My vote is 304l
72 K20 12v build
Old 05-20-2015, 09:03 PM   #2120
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looking good!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-22-2015, 07:50 PM   #2121
Dieselwrencher
Originally Posted by 1985-GMC View Post
Looking good!
Thanks! How are your projects going?
This week I got my front bumper brackets re-configured. Now I need to put the bumper back on the truck and drill the mounting holes. I also got my grill filler panels in, as well as the radiator top plate cover. I'm working on saving pesos up to get a cruise control kit now. This weekend we start our yard fence project. Once that's done, I hope to get some truck project time in.
Ryan
Old 05-24-2015, 11:13 PM   #2122
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Other than collecting parts the GMC has been on pause for the last few years while I decide what direction I want to go with it. I'm finally to a point to where I can start making some good progress on this suburban project I started a few months back so now it should start moving along pretty quickly.
Tony
Old 05-26-2015, 08:59 PM   #2123
Dieselwrencher
Nice burb project! Where's the build thread at?
Ryan
Old 05-26-2015, 09:06 PM   #2124
ryanroo
ryanroo's Avatar
I had those same things run through my head...
72 K20 12v build
Old 05-26-2015, 10:26 PM   #2125
0311Chevy8152
Just enjoyed going through the past 7 years of your life over the past couple days. Awesome looking truck! I will definitely go back through your build and use it as a resource for my build. I'm not doing anything close to yours but you definitely have info and resources I will need. Thank you for documenting your build.
Nathan
0311Chevy8152 is offline   Reply With Quote
