12-06-2010, 12:04 PM | #2176 |
Re: What did you do to your truck today?
rebuilt master cylinder, put tires on the front and she is back on the road again
'65 long-bed with 327/3spd '05 SRT-10 quadcab '69 Superbee clone '66 Charger w/ 36k og miles and a handful of bimmers |
12-06-2010, 12:16 PM | #2177 |
Who Me?
I did the Tractor Supply Trac Bar mod this weekend.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
12-06-2010, 01:07 PM | #2178 |
Senior Enthusiast
For me the biggest advantage would be closing the doors easily with the vents and windows shut. My doors close super easy with just a vent window open, but when they're all closed it's so air tight it's hard to get the doors shut without slamming them.
12-06-2010, 07:02 PM | #2179 |
got some stuff finished in the engine bay with my helper and got her running finally. Now just need to figure out my headlight problem!
12-06-2010, 07:13 PM | #2180 |
12-06-2010, 07:28 PM | #2181 |
Man that gold motor looks sweet with all the black accents.
Are you going "Heater Delete"? Last edited by lakeroadster; 12-06-2010 at 07:29 PM. |
12-06-2010, 08:19 PM | #2182 |
picked up a super straight bed for the 63! traded a pos 64 falcon parts car and $100 bucks i figured it was a good deal didnt cost to much and got a car outta my backyard guy wanted $300 at first
12-06-2010, 08:41 PM | #2183 |
12-06-2010, 09:54 PM | #2184 |
i like them! and i like all the labeled storage tubs in the background good idea!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
12-06-2010, 10:45 PM | #2185 | |
Senior Enthusiast
12-06-2010, 10:46 PM | #2186 | |
12-06-2010, 11:25 PM | #2187 |
[QUOTE=blackmopar;4335003]got some stuff finished in the engine bay with my helper and got her running finally. Now just need to figure out my headlight problem!
Whats wrong with the headlights. If they don't work check the plug that is at the radiator support. If that is clean inside maybe you have a bad highbeam switch. Make a jumper wire to check that one out. Most of the problems with the headlights is the connector at the radiator support.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
12-07-2010, 02:50 AM | #2188 |
pulled it back in out of the snow,pulled the left fender off and cut off the bottom,pulled the glass from the doors,looked at it a while,took the doors and fender into town for repair.
12-07-2010, 03:22 AM | #2189 |
CLASSIX Truck Club
Painted my bumper.
12-07-2010, 10:23 AM | #2190 |
Installed my "CaptainFab Power Steering Adapter Plate" and moved the 64 and 66 outside for shop cleaning/organizing. The PO installed power steering, but the geometry was all wrong. Problem solved! The install was super easy, especially since the steering shaft was already cut down to the proper length and two holes were correct. Drilled two more holes in the correct position and mounted her up. Stitch welding will come when I tear the truck down for a frame off. Early 2011 I will start the process. I want to get the title work done before I do too much to her.
Daniel 66 Chevy C10 LWBSupport our troops! |
12-07-2010, 04:12 PM | #2191 |
Senior Enthusiast
12-07-2010, 06:28 PM | #2192 |
Spray bombed the interior (<$10). Much better than the flat black the PO shot on it, it is close to original and good enough for my beater shop truck.
Didn't do the doors yet since they need fuzzies and glass channel weatherstripping. So tell me gang, where is the OEM paint cut line at on the doors where it transitions from fawn to the cab color(s)? Last edited by lakeroadster; 12-07-2010 at 06:45 PM. |
12-07-2010, 06:47 PM | #2193 |
Senior Enthusiast
That looks great.
12-07-2010, 08:13 PM | #2194 |
whats the little boxes on the back wall for?
12-07-2010, 08:16 PM | #2195 |
Vents
now I want to leave early and work on my truck! but instead I'm going to have to sit here at my desk and watch the Big Lebowski on netflix Last edited by StevieC; 12-07-2010 at 08:17 PM. |
12-07-2010, 08:36 PM | #2196 | |
12-07-2010, 08:54 PM | #2197 | |
Camaro dash will be the same color shown in above photo. Gauge panels will be black, as well as the steering column, seats and console. |
12-07-2010, 09:20 PM | #2198 |
Lakeroadster, how many cans so far?
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
12-07-2010, 09:44 PM | #2199 |
Put on a fender to see how it would look and check clearence.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 12-07-2010 at 09:47 PM. |
12-07-2010, 09:52 PM | #2200 |
I finally put power steering in my truck.
