06-18-2021, 05:58 PM | #2201 |
Re: What did you do to your truck today.The 3rd chapter
Those dang strips that clip to the door are such a pain!
06-18-2021, 06:10 PM | #2202 |
Mr. Cheyenne
preaching to the choir pjmoreland!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
06-18-2021, 09:40 PM | #2203 |
Who Changed This?
I found the wing window gaskets among the stuff that my FiL had in the garage. Purchased long before he died, 14 years ago from the looks of them. They do seem pliable, though. Hmm...need a place to park the truck inside while that gets done, if ever.
06-18-2021, 10:01 PM | #2204 |
Ordered calipers, rotors, bearings, seals, wheel cylinders, shoes, and everything else needed for a complete brake jog. Next weeks project. Looking to stop on the proverbial dime and get 9 cents change. Much safer ride than it currently is.
Smitty '71 Short Fleetside Spring Valley, Ca. |
06-20-2021, 11:46 AM | #2205 |
How did I get this OLD!
Replaced my water pump. This one sprung a leak.
https://67-72chevytrucks.com/vboard/...1&d=1624203661
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
06-20-2021, 03:36 PM | #2206 |
70+ ( Old Skool Club )
Fed Ex Ground dropped of this last needed piece from Summit Racing for my front end rebuild.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-21-2021, 12:05 AM | #2207 | |
06-21-2021, 12:12 AM | #2208 |
Not today but on this past Thursday I reclocked the front coil spring on the passenger side of my C10. A little over a year ago I had a local shop replace my lower control arms with some new aftermarket ones. They didn't quite get the afore mentioned coil spring quite right. One of the coils on the spring was interfering with the crossmember. I drove it like that and one day while on an extremely rough patch of road the coil spring shifted. It constantly squeaked on rough roads. I finally had enough of the squeaking and shabby handling of the front end so I undid the suspension on that side and repositioned the spring correctly.
Wow, what a difference. Now the truck handles and drives so much better. I wish now that I wouldn't have waited so long to correct it. |
06-21-2021, 09:06 AM | #2209 |
Cleaned it really good for a cars and coffee event in Miami in two weeks
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
06-21-2021, 09:12 AM | #2210 |
Won a trophy
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-21-2021, 09:13 AM | #2211 |
Looks better this way..........
06-21-2021, 12:28 PM | #2212 |
Took him to dip his toes (and mine) in the river...
“The doctor said I wouldn’t get so many nose bleeds if I kept my finger outta there,” - Ralph Wiggum |
06-21-2021, 01:09 PM | #2213 |
Making progress on the LS swap into my '71
[IMG][/IMG] |
06-21-2021, 02:44 PM | #2214 |
06-23-2021, 03:39 PM | #2215 |
Got the springs for my 68 Golden 3” front drop 4” rear . Going to install the fronts today or tomorrow using the factory spindles to decide if I want it any lower before the conversion to disc.
06-23-2021, 11:11 PM | #2216 |
Nice Mark .Where did you get your springs?
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
06-24-2021, 09:34 AM | #2217 |
Fronts are western chassis the rears are ccp HD units . Let's me keep the weight capacity even though I dont load them up figure it couldnt hurt. Summit was the best place free shipping and the are usually at my door in 2 days
06-24-2021, 09:46 AM | #2218 |
I put in the drivers front with no problems. Passenger side not so much I buggered up the threads on the lower so I need to get a new one . Looks like they are original based on the rivits still in the uppers. But with the same tire I got a 2 7/8" inch drop not to much sag in the originals . It will go up a bit with the larger tires. Old tire 29" the one I'm using is 30.6" dia
06-25-2021, 12:13 AM | #2219 |
Active Member
Frame media blasted primed and painted. Now time to start rebuilding.
06-25-2021, 03:56 AM | #2220 |
Mine is back in the shop today that did the rearend rebuild and gearing upgrade so they can fix the whine/howl they ended up with last time. Adjustment of pinion or backlash is off. Can't wait to get it resolved for two big truck meets that are coming up here in Washington.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
06-25-2021, 11:54 PM | #2221 |
Final touches on my 71 Cheyenne interior. I used 1972 doors, door panels refinished in Rustoleum “Chestnut”, I Re wrapped the Deluxe woodgrain door inserts, Dark Saddle ACC carpet, Truck World Cheyenne Super Saddle seat upholstery, Deluxe gauge package with tachometer, GM tilt steering column, Comfort Grip Sport steering wheel. Cheyenne Super glove box door treatment.
3rd picture is what the interior used to be.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 06-25-2021 at 11:59 PM. |
06-26-2021, 12:23 AM | #2222 |
Looks great.
06-26-2021, 09:08 AM | #2223 |
Dropped . Also got a surprise changing out the ball joint went with the cheap Duralast instead of the TRW unit since I plan on adding discs and would have to change them again anyway . Well surprise I took out the ball joint and it was wrapped in TRW badging .
06-26-2021, 11:12 PM | #2224 |
I gave mine a bath. It rolled out of the shop for the first time 30" lower and in only 56 days. Still need the mufflers and the wood reinstalled. Some how I lost the sill plates in this ordeal.
06-27-2021, 02:44 AM | #2225 |
Put on a new seat cover, which meant removing the seat, all the floor coverings (original black rubber mat) cleaning the whole thing, installing some sound insulation (dynamat type product)
Then put it all back together. I have also recently replaced the original quadrajet with a 1978 build unit with APT. Put a kit through it from Cliff R, set it up as stock and also did an electric choke conversion. Truck has never run better. |
