Old 12-28-2007, 02:09 AM   #201
vtblazer
vtblazer's Avatar
Re: Went to a Bigger Blazer
Cut off the door bottoms as well, so with the tube door quick hinges I fabbed earlier, I can still change out the doors.
vtblazer is offline   Reply With Quote
Old 12-28-2007, 02:20 AM   #202
vtblazer
vtblazer's Avatar
Moving on...
How about line locks for the rear axle?
Couldn't find any real info on it, so I went ahead and installed two elec. solenoids on the rear axle, one to each disc to aid in those front digs.
Mounted the momentary contact switches in my center console lid.
Not positive the push button style is the easiest but they definitely hide the best.
Thinking about installing one on/off toggle so I could also use the line-lock set up as a parking brake.
Old 12-28-2007, 02:51 AM   #203
jaros44sr
jaros44sr's Avatar
Nice work! Good clean fabrication, looks like your idea will work out... J.
That diff. cover looks bulletproof
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-28-2007, 02:54 AM   #204
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
That looks bad a$$, did you weld up the door bottoms?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 12-28-2007, 03:15 AM   #205
vtblazer
vtblazer's Avatar
Not yet but that's the intent, have old speaker holes to fill in the doors too.
It worked out so that when I weld a piece of flat stock to the top of the DOM floor support, I can still run a stock door seal.
Old 12-28-2007, 04:01 AM   #206
desertrat
desertrat's Avatar
nice work VT
desertrat is offline   Reply With Quote
Old 12-28-2007, 06:03 PM   #207
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Originally Posted by Angelse68cal View Post
Hey VT how much would you charge me to make the winch frame you got?
Originally Posted by vtblazer View Post
Dunno, let me ponder it.
I want one too.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 12-29-2007, 02:31 AM   #208
vtblazer
vtblazer's Avatar
Originally Posted by RED72blazer View Post
I want one too.
The issue I see with trying to make the winch mount for others is that all these trucks are different in some fashion. (tweaked or whatever)
Then there's the winch variations too.
Would you want it as a 'whole' ready to weld in or in parts/pieces to make up and fit between the frame rails?
How many should be made, what would be the real interest?
Let me know, it's an interesting thought.
Old 05-18-2008, 12:53 PM   #209
vtblazer
vtblazer's Avatar
The dash repair got it's turn.
Being an off road ride, I decided function ruled over form as in 'stock'.
The aluminum plate offers a quick/easy/functional repair with room to grow when I have the need to add gauges, switches and such.
Nothing real fancy but it works.
Old 06-04-2008, 10:18 AM   #210
FormerMember
Heh, it really is... one of the other ones made has been shot at
Why not put the check engine light and ALDL port in the aluminum center section?
I HATED that cut job, it was done by the PO for a Sony EQ.
FormerMember is offline   Reply With Quote
Old 12-22-2008, 06:37 AM   #211
vtblazer
vtblazer's Avatar
Only 6 months since the last post, guess I didn't break anything major this year.
Gotta wheel to break though and that didn't happen much at all this year with fuel prices and all the home renovation's that took place...
Have some winter plans for it though.
Hope to do a rear taper soon, have some swb bedsides and am currently looking into finding another fuel cell.
The custom made one under the frame is coming out due to future plans to lengthen the wheelbase, the new cell will be mounted in the bed.
The cell being pulled has an internal pump which I prefer but for this ride, a frame mounted pump should work fine.
Old 12-22-2008, 11:29 PM   #212
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Ur gonna boat tail it??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-23-2008, 06:24 AM   #213
vtblazer
vtblazer's Avatar
Yeah, about a foot on each side.
Old 01-03-2009, 06:13 PM   #214
vtblazer
vtblazer's Avatar
Parts are coming in...
Got the new fuel cell today and sent out a M/O for the frame mounted pump.
Both parts are new/used from board members.
Old 01-03-2009, 06:17 PM   #215
FormerMember
That reminds me, I have a fuel cell up there I could use on the C/K30 project.
Old 01-03-2009, 07:51 PM   #216
vtblazer
vtblazer's Avatar
lol, you have a lot more than that up here...
Old 01-03-2009, 07:54 PM   #217
FormerMember
Yes, I know. I am focusing on the C/K project as it's closest to done and sale-able.
Old 01-16-2009, 07:06 AM   #218
vtblazer
vtblazer's Avatar
Decided to bring it inside for some repairs.
Right now it's fix what was busted from the last time out and getting it prepped to do some snow wheelin'.
Need to move the front brake line hard connection, the tire ripped the braded line right off the frame but you'll have that when you stuff a tire into the firewall I guess.
Next time in, it'll be to do the taper.
Cut down the cage, install the fuel cell in the bed & mount the swb bedsides.
Old 01-16-2009, 07:17 AM   #219
Chevyman63
Chevyman63's Avatar
Didn't know you were changing bedsides too. You're a very ambitious young man.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 01-16-2009, 07:18 AM   #220
jaros44sr
jaros44sr's Avatar
I remember that day, I think it was on your side...nice bedside hangin' on the wall. Like the Champion sign too
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2009, 07:26 AM   #221
vtblazer
vtblazer's Avatar
Yep, my side.
Tore it off, repaired it once and repeated the exact same performance within about 10 minutes...
In reality, it needs some work done in the front end to cure the 'megga stuff' problem.
Old 01-16-2009, 07:31 AM   #222
jaros44sr
jaros44sr's Avatar
Yep, my side.
Just saw some cool stop blocks on TV, I think they are filled with fluid to absorb some of the force when you hit the stop
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2009, 07:35 AM   #223
vtblazer
vtblazer's Avatar
Yeah, some might call it ambitious, some might call it something else.
I don't want to shorten the frame or move the bumper and with the swb bedsides being longer than a blazer's, I won't have to.
The tailgate, the fuel cell & the flush mount gas door will all be donated to the other blazer once the taper on this one is done.
Old 01-16-2009, 07:39 AM   #224
vtblazer
vtblazer's Avatar
...lots of really cool bump stops out there but have you seen the price of em?!
The front axle moves around a lot due to the flexy spring pack, it's great to have flex but in this case it's to much.
Even some sort of track bar to keep the axle in place might be a valid cure.
No sense in installing high zoot bump stops if you can't get the axle to land on them, right?
Old 01-16-2009, 07:56 AM   #225
jaros44sr
jaros44sr's Avatar
No, didnt see the price...didnt realize an axle could move in those directions, thought it was strait up and strait down...learn something new everyday, if ya live long enuff
SAFETY FIRST
AS usual, off topic
Jim
