Old 10-07-2008, 12:11 AM   #201
Captainfab
60-66 Nut
Re: My 1965 build thread
I have to agree....that looks like much less work with most likely better results. I really enjoy watching your build....you do very nice work.
Old 10-07-2008, 03:20 PM   #202
joe231
joe231's Avatar
yes..much better
CHEVY ONLY
Old 10-07-2008, 03:28 PM   #203
4dranch
Shloooooong bed member #2
4dranch's Avatar
Very nice work Alan..
Haven't seen kleeco's since my Aircraft days..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 10-07-2008, 03:54 PM   #204
dolphman88
DDOV
dolphman88's Avatar
dam. nice work.. im just learning how to weld... and i thought i did good on my truck floorboards.. from the bottom my cab looks like a quilt... i absolutlely hate those LMC replacement panels.. very nice job.. teach me sometime when u get a chance..
dolphman88 is offline   Reply With Quote
Old 10-07-2008, 06:35 PM   #205
283 Man
283 Man's Avatar
[QUOTE=Alan's Classic;2919494]I wouldn't charge a million just 900K . Thanks for the compliment.
283 Man is offline   Reply With Quote
Old 10-07-2008, 11:39 PM   #206
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks Guys.
I was a jet mechanic for almost 12 years. Then became a body man. JK I love working on cars.
dolphman88 Re: My 1965 build thread
Come on down some time. It should only take 5 minutes to show you everything I know.
I went and picked up the Vintage Air kit today. I think I did good on it. It was new in the box, the guy changed his mind for some reason. Not pictured is the oval controller with 3 knobs and a slide. It's a Gen2 mini. I'm not going to use the polished compressor. I will be getting a serpentine belt kit that comes with the comp.
Man, it takes courage to let your neighbor (sdailey)to cut on your truck.
He did a great job and is some good help. I'm getting him prepped so he can do most of the work on his cab.
Yours truly in action. We got the left end plate welded on and lined up. Now I have to mount the dash around the column then work on the center section.
Alan's Classic is offline   Reply With Quote
Old 10-07-2008, 11:46 PM   #207
65ShortStep
Looking Good!
Lots of good Ideas.
65ShortStep is offline   Reply With Quote
Old 10-08-2008, 12:14 AM   #208
Hoffman65burb
Hoffman65burb's Avatar
looks awesome man, what kind of engine/trans combo are you thinking of putting in?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 10-08-2008, 12:48 AM   #209
dolphman88
DDOV
dolphman88's Avatar
how much did you pay for that kit? i bought one for $100 just like that..
and what look are you goin for, and what purpose?
original? or what?
and street/strip or show or somthin else?
If you don't like the way I drive, stay off the sidewalk
http://67-72chevytrucks.com/vboard/s...d.php?t=317070
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Old 10-08-2008, 05:04 AM   #210
283 Man
283 Man's Avatar
Alan good score on a/c.
Old 10-08-2008, 11:30 PM   #211
Alan's Classic
Thanks. I've got a 383/700R4. I was going to run 373 gears, but I think with a overdrive it will be safe to run a 411 gears down the highway.
original? or what?
I didn't get that good of a deal. You stole that kit. I just want something that can show and go. Mostly original with a few twists. I don't know what catagory that would be.
Thanks to everyone else.
I got a little done tonight. I got the center tied together temporarily until I pull the dash out so I can weld completely. As you can tell I got the top patch welded in.
I need a little input on this. I'm going to redesign the center section. I'm putting in a pop out DVD player and the oval AC control. I might put a eyeball vent there also or just make a custom panel under the dash to hold the vents. I'm not sure yet. I know the cardboard has squared off corners but I will maintain the rounded edges like the rest of the dash.
Old 10-08-2008, 11:32 PM   #212
Hoffman65burb
awsome! i just found out i had 4.11 gears today
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 10-09-2008, 01:40 AM   #213
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I would make a cover that matches the shape of the dash exactly, and then folds down to access the stereo.
maybe put a square ac vent where the original radio was.
Old 10-09-2008, 10:28 PM   #214
Alan's Classic
I thought I'd share something that can save you some $$. Bodyshops throw alot of metal away. So instead of buying metal there is alot of useable metal that can be used in fabricating stuff. If you know someone in a shop ask them to see if you can get some. Even if you don't know anyone ask the manager. You might get lucky. I picked this piece up today. It's a piece of uniside that wasn't used due to us sectioning the part. It has some good rolls and contours to it that I can use to form up my center section of my dash. I dont have a sheetmetal brake yet so this works pretty because the bends are there. It's also good when your on a tight budget.
Here is a pic of the Vintage air controller that I just got.
Old 10-09-2008, 11:36 PM   #215
Hoffman65burb
wow that looks sick!
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 10-10-2008, 06:29 AM   #216
Tim64
Tim64's Avatar
I can only imagine how cool that truck is going to be. You're one talented dude. My hat's off to ya!
Tim64 is offline   Reply With Quote
Old 10-10-2008, 08:24 AM   #217
sdailey
The Few, The Proud
sdailey's Avatar
If everyone would please refer back Page #6 to post #143.
Alan's "true" colors are finally coming out in this dash build. I told you the boy had skills.
Looking good Alan.
Shannon
sdailey is offline   Reply With Quote
Old 10-14-2008, 11:39 PM   #218
Alan's Classic
I've been a little lazy. I finally got back at it tonight.
I got a wood heater this weekend now I've got to install it.
I got the center area framed up. Don't laugh to hard at my fab skills. I don't have a brake. I could have formed with hand tools, but think this was the easiest way. I used the radius edges off of the uniside that posted a pic of a few post ago to make the frame. The corners of the frame blend right in with the curves of the dash to make the lines flow together.
Most everything is tacked in place. I've still got the right side panel to do. Once everything is welded in place I'm going to removed the brace running thru the center behind the radio to open the area so it will be easy to access.
I used another part of the 65 dash for the bottom of this enclosure.
Old 10-15-2008, 08:12 AM   #219
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
looks good to me, nice project dude
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 10-15-2008, 11:08 PM   #220
Alan's Classic
Thanks JR
I got a little more done tonight.
Old 10-15-2008, 11:18 PM   #221
jrsmith_2010
I like turtles...
thats very creative, wish i had that skill, looks great
Old 10-16-2008, 02:10 AM   #222
Frizzle Fry
Frizzle Fry's Avatar
I love the way you use other parts to make it all come together. I do that too because it's just easier to be resourceful than building from scratch. But I did finally order a sheet metal brake a few weeks ago. Still waiting for it to show up...
Frizzle Fry is offline   Reply With Quote
Old 10-16-2008, 10:21 PM   #223
Alan's Classic
Thanks guys. Hey Frizzle which brake did you end up going with?
I got some goodies today. I got these 2.5" drop spindles from CPP and also the tranny crossmember. I test fitted my ball joints as seen in the pix. Everything is for a 72.
Old 10-17-2008, 09:59 AM   #224
Frizzle Fry
I went for a generic version of this one (probably made by the same manufacturer): http://cgi.ebay.com/ebaymotors/Clark...QQcmdZViewItem
Old 10-17-2008, 10:14 AM   #225
sdailey
The Few, The Proud
sdailey's Avatar
Cool.
There's no better feeling than getting new parts in the mail.
Shannon
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
