Old 01-27-2010, 07:02 PM   #201
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1964 Suburban Pics
Originally Posted by ruffrida2005 View Post
What did the Hydro come out of?
I picked it up new from a guy who bought the wrong one. It was supposed to be for a 3/4 ton Blazer.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-27-2010, 09:09 PM   #202
70stroker
70stroker's Avatar
nice burb. Whats the plan for the bbc
70stroker is offline   Reply With Quote
Old 01-27-2010, 10:21 PM   #203
protrash64
protrash64's Avatar
Clean it, paint it, hook it up, attach all the accessories, and burn some gas
Old 02-01-2010, 10:49 PM   #204
protrash64
protrash64's Avatar
Here's a little progress. A clean and painted engine for the swap. A nice shot of some brackets getting the degreaser treatment.....and for anyone considering a BBC swap, here is the measure you need. With the clam shell mounts on the block you will need your mounts approx 16.75'' apart. This is the centerline of the holes in the clams.
Lastly, the engine is just about in one piece again with a bunch of Felpro gaskets.
Old 02-01-2010, 11:46 PM   #205
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
What brand of paint did you use? and did you primmer it first?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 02-02-2010, 01:22 AM   #206
protrash64
protrash64's Avatar
I used Duplicolor Chevy Orange Engine Paint #1620; rattlecans. They do make a primer, but it doesnt specifically say to use it. I cleaned the crap out of the block and then wiped it down with wax and grease remover before finally spraying. It was on the cold side, so I did about 3 med/thin coats.
Old 02-02-2010, 08:38 PM   #207
ruffrida2005
I was just wondering, I sandblasted mine and used wax and grease remover. I used VHT orange. I did it in July and it's been sitting since. I was just worried about it rusting for some reason. Are you gonna put anykind of clear on it to protect the paint?
Paul
Old 02-02-2010, 11:58 PM   #208
protrash64
protrash64's Avatar
No, no clear....I thought that the oil leaks were supposed to protect it
Old 02-03-2010, 02:17 AM   #209
Captainfab
60-66 Nut
Coming along nicely. Did you have any luck finding some 3/4 ton frame brackets for the motor mounts?
Old 02-03-2010, 11:24 AM   #210
jason65
Registerd User
jason65's Avatar
Looking good Jeff.
jason65 is offline   Reply With Quote
Old 02-03-2010, 12:07 PM   #211
MacAttack
283 Drama Queen
MacAttack's Avatar
Okay, Jeff - what's with the fancy all-thread rods to measure off of? What, twisted together coat hangers too ghetto for you?
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 02-03-2010, 12:07 PM   #212
jchav62
1962 C-10
jchav62's Avatar
NICE!!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-03-2010, 12:14 PM   #213
protrash64
protrash64's Avatar
......just the first thing I had available!!!
I have found some, but I dont see much difference in them compared to what I have already. Do they have a different slope or angle somewhere that helps out? I was looking at mine and thought I would trim the lower 'foot' and they are almost a perfect triangle for mounting.
Old 02-03-2010, 12:15 PM   #214
protrash64
protrash64's Avatar
Originally Posted by jason65 View Post
Looking good Jeff.
Originally Posted by jchav62 View Post
NICE!!!
Thanks guys.........good to see ya cruisin' the board!!!
Old 02-04-2010, 01:43 AM   #215
Captainfab
60-66 Nut
The '73-'87 C20's frames are closer in height to our trucks frames than the '73-'87 C10 frames. I have yet to install a set, but I have measured the frames and compared them. There was another member that originally brought this to my attention.
Old 02-05-2010, 11:09 AM   #216
protrash64
protrash64's Avatar
Well, I guess I'm going to find out here shortly and put the matter to rest. I will try to post as much BBC install info I can in doing this swap.
OK, everybody wave....................
Old 02-05-2010, 11:23 AM   #217
jason65
Registerd User
jason65's Avatar
Old 02-07-2010, 02:28 AM   #218
protrash64
protrash64's Avatar
I guess only Jason wanted to wave goodbye. Well, pulled the engine and tried the mounts. Looks like they fit good to me. The frame will be trimmed back roughly 1/2'' to use the factory holes up top and I will drill the lowers. I measured my mount holes and they were 16 3/8''. By the time I lean back the mounts into the factory holes they should be perfect. I will be pulling the trans forward a bit; maybe an inch. I used the mounts in the frame to judge length and then measured the 454.
For those who mentioned putting material under the top of the mount; this is only neccessary if you use the factory lower holes.....at least as far as I can tell.
........here's the pics.
Old 02-07-2010, 12:42 PM   #219
Dinos63
chevy only
Dinos63's Avatar
sh-t to late to wave..... will looking good ,that sub is going to be fun with that motor
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-07-2010, 05:00 PM   #220
protrash64
protrash64's Avatar
Originally Posted by Dinos63 View Post
sh-t to late to wave..... will looking good ,that sub is going to fun with that motor
.....damn straight..................
A mid-day update as I know many are on the edge of their seat!! Here are the mounts and some more measuring. Off the core support, directly in line with the frame, my mounts are going 18.5'' back to the front edge. I have also surmised that I have a newer X-member that I was not aware of. I think that is why the mounts fit so nicely.
I notched the frame back roughly .5'' to fit the mount in place. I also redrilled the 2 lower holes which are directly below the factory holes. This puts my mount holes at exactly 16.75 inches to center. I will put a thick washer(1/16th) under the front lower hole to act as a spacer as there is a little rocking of the mount.
Now I just need to blast 40+ years of grease and dirt and move a brake line and my trans lines. Also getting a coat of black rattle to pretty things up.
Old 02-07-2010, 06:42 PM   #221
jason65
Registerd User
jason65's Avatar
Good job Jeff. Can't wait to see that shiny new motor tucked in there.
Old 02-08-2010, 01:19 AM   #222
Captainfab
60-66 Nut
Once you get that engine set in there, you might want to check the carb flange on the intake for level and also check to be sure that your trans output is in the same plane as the pinion in the rear end.
I did a little measuring regarding my previous post on the C20 motor mount brackets. In the area of the motor mounts, the '63-'66 frames measure about 5 3/8" tall. The '73-'87 C20 frames measure about 5 1/2" tall. The '73-'87 C10 frames measure about 6" tall. Just a little FYI.
Old 02-08-2010, 11:09 AM   #223
protrash64
protrash64's Avatar
I'll confirm that measurement on my frame; I'm sure it's the same, but what the hay!! I think you're right, Cap'n.....if I used the mounts in the factory holes the mounts would be roughly that high above the frame. Notching eliminates some of that height as it rotates the bracket outward. I chose that and to lower the bottom bolt holes. The C20's would definitely be a good fit. I just lucked out with the 73+ X-member having the correct contour for the brackets.
It looks as though the engine will sit down in the bay nicely. Long tube headers are definitely a no go, at least if one is lowered or bagged. I think my choice of headers will work well, too. I'm gonna find out anyway, as I have my new brake line made and I still need to do the trans lines.
Old 02-15-2010, 02:08 AM   #224
Captainfab
60-66 Nut
Any progress Jeff?
Old 02-15-2010, 01:58 PM   #225
protrash64
protrash64's Avatar
Any progress Jeff?
Well, my frame is 5 3/8th's inches high. But no, not much. I have just been cleaning up parts and tracking down a couple things I need. I need to clean up my inner fenders and figure out how to hook up my TV cable to the carb correctly. I am also putting my serpentine system together and need one part.
My parents are visiting so I am not doing much work on it for a couple days. I do have the mounts in and my brake line relocated. The fire wall also has a fresh coat of black. I'll get a pic.
