10-02-2011, 01:45 PM | #201 | ||
Moderator
Re: Improve mileage 350 with Quadrajet
@14-15 US mpg on gasoline is pretty good fuel mileage. You should get 34% less or... 9.2-9.86 US mpg on LP. I'd say you've arrived. |
10-02-2011, 02:01 PM | #202 |
hi HAtzie,
thanks for the reply. I have taken the thermostat from the car and tested it in water. heated it untill it cooked and in the mean time watched the thermostat open en then let the water cool and see the thermostat close. The thermsotat is just fine. That test is somewhere here in my posts. It's just my onboard T-guage that seems to be of by a little...
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
10-02-2011, 07:32 PM | #203 |
I have a '78 swb step side with a 250 straight six and 3.73 rear gears, it originally had a 3 speed that got 12mpg on the highway. After swapping in a T5 with a 0.8 5th gear my mpg jumped 40% to 17 mpg on the highway.
Have you ever thought of a TH700 trans? |
10-03-2011, 02:58 AM | #204 | |
and I have a TH400now that shifts perfectly...so I am a bit scared of swapping for a TH700...never know what you get and I hear a lot of bad talk about it...
10-03-2011, 09:34 AM | #205 | |
Conversion Truck Addicted
its only so bad because it let someone down because they dont maintain there cars and truck proberly
Thomas Quote:
10-16-2011, 01:41 PM | #206 |
oke, next chapter in this topic.
got my hands on a second hand MSD 6AL (model: 6420). Installed it yesterday. Engine is running fine now. dont really notice any big improvement. Need to open up the gap in the spark plugs a little... I'll be back with results in two weeks.
10-30-2011, 03:48 PM | #207 |
okay guys, some results...
after my first 80 miles I got a MPG of 8,16 and the second 96 miles I got a MPG of only 7,83 while before wit the normal HEI I got 8,7 - 8,9 MPG How is it possible that with a better ignition I get a lower mileage In between I even opened up the gap from .8mm tot 1.1mm for a better spark...but I get no improvement... If you guys dont have any tips I am gonna put the old HEI back in... please help!
11-02-2011, 03:27 PM | #208 |
continuing my search for improvement in mileage I found this pages and tips on
HEI Tuning Secrets http://www.73-87.com/7387garage/drivetrain/hei.htm I decided to make my own Timing Tape using the information of this url: http://www.crankshaftcoalition.com/w..._a_timing_tape I took measurements of my Balancer 2nite and found the circumference is 695mm (27,34 inch). So: 1 degree is (1/360)*695 = 1,93 mm 10 degrees is (10/360)*695 = 19,3 mm 20 degrees is (20/360)*695 = 38,61 mm 40 degrees is (40/360)*695 = 77,22 mm 60 degrees is (60/360)*695 = 115,83 mm
11-03-2011, 07:55 AM | #209 |
78K & 79C Jimmys
hmmm good info...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-03-2011, 08:01 AM | #210 |
how did you setup your timing?
initial? mechanical? vacuum? total @ ?? rpm?
11-04-2011, 08:03 AM | #211 |
78K & 79C Jimmys
i think i started at 8
I've played it back and forth not realizing the vac advance was still an issue(sticky) I've cleaned the vac advance a few times weights/vac rod were seized when i got the truck but this time was the last time ,ordering a new one (dist)next in my pic you can still see a mark where it was rusted solid I've moved it(rod) out of the way to clean/file the hole and flat area
11-04-2011, 05:15 PM | #212 |
Overdrive will help you a lot!!!
700 swap from a 350 Turbo is relatively easy and you just need a kit from Advance Adapters for about $150. Your problem is the output shaft from the 400 Turbo is larger and therefore the gear in the transfer case is too big for the adapter shaft and no one I can find makes a kit for this. You can change the gear in the transfer case and it will work great. Better, but more expensive is to install a 4LE-80 with an electronic controller. A Gear Vendor Overdrive is excellent, also. MSDs won't change your mileage unless you have a problem with your stock ignition, no matter what they say. Proper mechanical and vacuum advance, good secondary ignition parts and proper electrical supply to the primary side are all you need. The plug gap should be about .04" and won't help mileage to increase it. |
11-13-2011, 09:12 AM | #213 |
thanks robert....
I already did some research on changing tansmission, but for a TH400 in a 4WD it isnt easy and no plug-n-play...I read somewhere that the 4L80E might fit nicely, but you still need an adapter and only a couple of companys make them so you dont need the electronics...and they are expensive.... I did the ignition timing today using the new timing tab....! made my own timing tape for my 8" balancer... 18mm per 10 degrees... My initial timing was set at 11 BTDC (without the vacuum advance). My total timing at unknown rpm was 32 BTDC. My Equus 3568 timing light is digital and isnt able to read RPM with the MSD 6AL connected. Because LPG is allowed a little more advance, I adjusted to 14 BTDC and total timing advanced to about 34. I then added the vacuum again and idle timing was something like 20-25? jumping al over the scale... for some reason sometimes when increasing the rpm's the the timing was stuck at about 15-20 rpm....I then had to re-increase the rpm's and then I was able to normally read the timing again....I think this is because the Timing light isnt always able to read the sparks correctly of the pickup... any body else have experience with this? the problem is, that now my car is running perfectly on LPG, but almost wont run on regular gas...what timing are you guys using for regular gas? I read somewhere that because my engine had all the smog-stuff connected that is might need different timing, because of lower compression? anybody know about that?
11-16-2011, 10:29 AM | #214 |
MSD and digital lights don't like each other. The MSD gives multiple sparks at lower rpm and the digital lights react so fast they can't decide which spark to count.
12-05-2011, 02:49 PM | #215 |
used the mr gasket timing advance kit and changed the weights and springs (black ones now).
car drives fine, no real improvement performancewise as far as I can judge....the springs that came out were stiff ass hell...the ones that went in were easy... I'll report back with mileage in a week or two. I had to get gas today (LPG) and I ran 127miles and had to get 67.49 liter of LPG. that makes like 7.0 mpg then I checked my tire pressure and noticed it was only 25 psi where I normally load the front with 44 and rears with 51. that probably influenced my mileage a lot... will check again the next few weeks.
12-17-2011, 08:14 AM | #216 |
alrgihty guys.
I took the choke plate out today, because it only restricts my airflow and I run on LPG for 99,9% of the time anyway. I need to get to know more about these quadrajets. I know the choke Pulloff prevents opening op the secondaires until the engine has warmed up through the mechanism at I. but how do the big plates at II open up? As far as I can see they do not connect to anything? I checked by opening the choke by hand and checking if I can open the throttle all the way...and it does...but these two big flaps at the number II dont open up. why? picture:
12-17-2011, 09:34 AM | #217 |
78K & 79C Jimmys
hows it goin,
there is a spring under that over hang your pointing at ajust with allen key,adds more or less "spring" to the bigger plates they open with vacume,but lower is a stop for the bigger plates till the choke is off i usally bend it out of the way,round end with a inch or so rod threw it i'll go grab one from the garage 2 show
12-17-2011, 11:56 AM | #218 |
I checked when I just came back from a drive. the choke pulloff blocks the secondairy flaps from opening, untill I turn of the engine. So I probably need to hook the choke-pulloff to a temperature controlled vacuum port on the intake manifold?
where do you have your choke-pulloff connected?
12-17-2011, 01:53 PM | #219 |
never mind!
solved it! I found that the chokepulloff activates by vacuum (so at idle and cruise) and then retracts and pulls the choke a little open (only necessary when choke is engaged). When you open up the throttle wide enough so you engage the secondaires, the manifold vacuum drops and will let the chokepulloff release the secondairy air valves. I read that is to make sure the engine doesnt BOG? when suddenly kicking full throttle.
12-19-2011, 07:46 AM | #220 |
78K & 79C Jimmys
found mine, one looks close
no idea what they are from,just cores really the shot with the writting, is from the bottom looking up you might even consider seeing if the secondaries could open a bit less, unless you get right on it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 12-19-2011 at 07:51 AM. |
12-19-2011, 12:11 PM | #221 |
thanks john!
12-19-2011, 01:30 PM | #222 | |
throw it it all away and put the stock wights in with the heavy springs from the kit
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-19-2011, 03:24 PM | #223 |
hi INSIDIOUS '86,
why would I do that? I run LPG 99.9% of the time. So I benefit from a fast and flat advance curve. Thats why I installed the lightest weights. Why would I install the old weights and heavy springs? can you explain that to me?
