Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-05-2011, 02:31 PM   #201
hopped up
hopped up's Avatar
Re: started working on the 65 suburban
whats parked next to it? badass burb by the way
hopped up is offline   Reply With Quote
Old 12-05-2011, 02:56 PM   #202
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
1970 superbird roadrunner thanks!!!!
gostranger is offline   Reply With Quote
Old 12-05-2011, 07:21 PM   #203
csa daddy
csa daddy's Avatar
Dave is the super bird yours or brother I laws either both are extremely cool projects
csa daddy is offline   Reply With Quote
Old 12-05-2011, 08:50 PM   #204
gostranger
gostranger's Avatar
i bought it 26 years ago gave it to my stepfather to put the money into it he passed last year now my mom owns it. i still want to finish it we will see what the future will bring it is a full frame off restoration and it is stock to the t!!!!!!!!!!!!!!!!
Old 12-06-2011, 11:20 AM   #205
csa daddy
csa daddy's Avatar
Nice!!
Old 12-07-2011, 10:24 AM   #206
kpc01
If I remember right you used the PB dropmember. Using this did you have to do any kind of driveshaft tunnel? I am starting to get all my parts together and looking at Zing my frame instead of the dropmember (short on money) but wondering what all buying a drop member will keep me from having to do. I think I'll have to do a little work to the tranny tunnel for the 4L60E but curious how much you had to do overall using the dropmember
kpc01 is offline   Reply With Quote
Old 12-07-2011, 07:32 PM   #207
gostranger
gostranger's Avatar
HYes i have the porterbuilt cross member.The only thing ihad to do to my tunnel was to change over tothe large hump tranny cover vs the small hump as you look at the motor pics in my build you will notice the engine sits very high i wanted to make sure the engine sits high enough that it doesnt hit the ground when it is layed out i am not positive if you will have clearence with the low hump with the engine in the stock position with the porterbuilt i think you might also the trans tunnel wouldnt be to hard to raise a few inches let me know if you have any other questions.
Old 12-08-2011, 11:49 AM   #208
kpc01
Thanks for the info...did you modify your tunnel or did you buy one? I'm not sure where to get them at but will probably need to modify mine as well no matter if I Z it or use the dropmember. Did you have to do any mods for the driveshaft or just the trans tunnel?
Old 12-08-2011, 12:10 PM   #209
gostranger
gostranger's Avatar
I didnt modify my driveshaft but i have a 2 pc and i have a slip shaft in the rear on so there isnt any binding as far as the tunnel i hooked up with a guy steve almeter 585-314-7907 he deals with used c10 parts also see if anyone on the board has a hi hump setup just dont foget it is 2pcs there is a smaller pc that will have to be cut to make the transition from the firewall to the high hump cover. if you dont get that you will have to fabricat it so to answer your question no modification except changing from low hum to a factory hi hump cover hope this helps let me know if you have any other questions.
Old 12-08-2011, 03:36 PM   #210
c.brown
c.brown's Avatar
are you going to cover that front seat or leave it stock,looking great
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 12-08-2011, 05:17 PM   #211
gostranger
gostranger's Avatar
Iamtrying to find a matching one for the passenger side also seatbelts!!!
Old 12-29-2011, 09:49 PM   #212
VeronikA
VeronikA's Avatar
Wow love your ride homie! Looks dope! I've always loved wagons and trucks. Yours has the attitude
Keep it up homie!!!!!!
VeronikA is offline   Reply With Quote
Old 12-30-2011, 01:25 PM   #213
gostranger
gostranger's Avatar
Thanks alot!!
More progress comming i got the compressor in and the rear valves are in just have to get the front in and wired then i will pull it out and get pics and maybe a vidieo of the airride in action i willtell you right now it is super fast!!!!!!!!!!!!!!
Old 12-30-2011, 07:42 PM   #214
csa daddy
csa daddy's Avatar
VIDEOVIDEOVIDEO Well what's takeing so long I'm waiting
Old 12-30-2011, 07:44 PM   #215
csa daddy
csa daddy's Avatar
What size line you runnin an valves glad to hear you making progress
Old 12-31-2011, 09:16 AM   #216
gostranger
gostranger's Avatar
No video yet want to have the front done and a few other things taken care of before i do one i am running 1/2 inch lines and valves man they are fast!!! And the oasis compressor is super fast! i am impressed! Hope to keep chipping away at it!!!
Old 12-31-2011, 09:28 AM   #217
northern 85
northern 85's Avatar
Luv the burb!
northern 85 is offline   Reply With Quote
Old 12-31-2011, 10:06 AM   #218
csa daddy
csa daddy's Avatar
Right well you will get there I started pulling my a arms apart to paint an install new bushings an ball joints an all. I went to help a friend the other day move a truck to his shop to work on it. An the owner of the truck knocked my trailer loose from the truck an trashed my dads back hatch o. His 01 sub so now I'm out 500 dollars so it will be a little bit before I can do any more to mine
Old 12-31-2011, 09:47 PM   #219
gostranger
gostranger's Avatar
Originally Posted by northern 85 View Post
Luv the burb!
Thanks!!! it has been a long build but it should end up good cant wait to get it a little further along.
Old 12-31-2011, 09:49 PM   #220
gostranger
gostranger's Avatar
That stinks after seeing pics of the damage i hope you are only out 500 bux! good luck!
Old 12-31-2011, 11:30 PM   #221
csa daddy
csa daddy's Avatar
Thanks me too . Got some work done on the 64 tonite I removed the inner fender an a arms still got to remove the crossmember an install my chopped member an bags with new a arm bushings an ball joints.
Old 01-20-2012, 08:08 AM   #222
gostranger
gostranger's Avatar
ok some updates tryed my cold air set up didnt work hood wouldnt close by ablout a quarter inch so i am going to run the filters further out and down to each side.
got all of my custom trim i have a complete set now!!!! i am happy
i also got my 22' rim for the rear will stay with the 20'' in the front
also got the hood hinges all done and working well also rear valves are in and the rear is done also the oasis compressor is hooked up and the 5 gallon tank man the oasis is fast!!!
more to come!!
Old 01-20-2012, 12:09 PM   #223
csa daddy
csa daddy's Avatar
Sweet
Old 01-20-2012, 01:39 PM   #224
gostranger
gostranger's Avatar
Sweet
Thanks!! Making some progress!!
Old 01-20-2012, 02:09 PM   #225
csa daddy
csa daddy's Avatar
I c if I could just find me a job I could make progress
