Old 12-12-2012, 04:06 AM   #201
502ms
502ms's Avatar
Re: 2WD C10 Modern/Performance Alignments
Great info. So, for a bagged truck, alignments are done at stock/ operational ride height, correct?
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 12-12-2012, 09:37 AM   #202
BMERDOC
BMERDOC's Avatar
Yeah, I think you'd wanna do the alignment at the ride height its gonna be driven at most. I'd love to get a bagged truck on the rack to see what happens to the alignment as the truck is raised and lowered.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-13-2012, 06:16 AM   #203
502ms
502ms's Avatar
Thanks! Too bad you are so far away
Best Regards,
Leon M.
Old 12-13-2012, 07:41 AM   #204
jjzepplin
jjzepplin's Avatar
Subscribed
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-14-2013, 12:19 AM   #205
RdoubleU
RdoubleU's Avatar
First off : Major Thanks to BMERDOC for starting and supporting this thread
Wanted to share my experience and results from using this thread as a solid guideline for aligning my '68 C10
Here's a summary of this threads research (correct me if I'm outta line anywhere so I don't misinform someone else.)
RdoubleU is offline   Reply With Quote
Old 02-14-2013, 12:29 AM   #206
RdoubleU
RdoubleU's Avatar
For my truck I was able to achieve the below specs
  • Camber .3*+
  • Caster 6*+
  • Toe In .1*
Unfortunately I was unable to go negative Camber on the passenger side due to limitations of the stock crossmember on my truck. They were able to get the driver side negative. They fully removed all shims on the passenger side and milled the factory shim down to its least amount while still maintaining its integrity but could only achieve .3* on the passenger side. So I chose to have each side equal the .3*
For the impressive Caster numbers it was due to me investing in Porterbuilt's (Nate) Forward Arm series. And I am very very happy with this decision and the result it produced: http://67-72chevytrucks.com/vboard/s...d.php?t=537266
The truck tracks straight has good road feel now and is also very confident in its driving characteristics
Thanks again for the info in this thread, hope it helps someone else out as well
Old 02-14-2013, 01:20 AM   #207
BMERDOC
BMERDOC's Avatar
Well done! Nice chart! Very easy to read and understand. My toe specs were in minutes and not degrees so I'm concerned they may have confused degrees and minutes. I'm starting to prefer fractional toe specs for ease of memory. 1/8" toe in, 0 or 1/8" toe out. These are TOTAL toe specs (1/16" per side). 1/8" toe in and 0 for stock and most modified trucks and 1/8" toe out for Corner Carvers. I'm not sure how much undesireable wear comes from the 1/8" toe out so I'd stick with 1/8" toe in or 0 for most trucks.
Its a shame about that camber. It woulda been nice to get it negative but at least its still in stock specs which doesnt raise any concern. Are you running any kind of drop springs? IIRC, 3" drop springs dropped the camber into a nice zone with no shims needed (before evening side to side).
I see the Porterbuilt Forward Arm Series control arms worked out nicely for you. I have a list of stuff I'd like to order from Nate and his family myself!
Enjoy your improvements!! Post up some pics!!
Nick Carter
Old 05-29-2013, 10:55 AM   #208
BMERDOC
BMERDOC's Avatar
Ok Kids! I did a final alignment on my truck. I will continue with modifications but this is as good as it gets right now. Minimal shims, maximum angles. I started a different thread for that single alignment so that others could find it. Heres the linky...
http://67-72chevytrucks.com/vboard/s...d.php?t=582187
Nick Carter
Old 11-22-2013, 07:40 AM   #209
Street Smart
Street Smart's Avatar
Great thread guys! Thanks for all the real world specs!
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 11-22-2013, 11:37 AM   #210
BMERDOC
BMERDOC's Avatar
Glad you found the info useful! I'll be updating as soon as I get a double adjustable Panhard Bar and the Caster Mod done.
Nick Carter
Old 04-19-2014, 01:35 PM   #211
LEEVON
LEEVON's Avatar
Unfortunately I was never able to get my alignment where I wanted it before I had my own shop (which is recent). My best tech and I were able to tinker on our own time and get it where we wanted.
The truck just got all new front suspension with 2.5" spindles and Moog 6454 HD springs cut exactly 1 coil. Rear suspension is 4" springs and 1.5" blocks, with a double-adjustable panhard bar. With this combo, the a-arms are slightly above level, the tie rods nearly level and the upper ball joints are at an acceptable angle.
Thrust Angle: .13 (no change required)
Camber: -.50 to -.53
Caster: 2.7 to 3.2
Toe: .08 toe
Sorry, forgot the printout. Rides perfect though!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-21-2014, 07:56 PM   #212
BMERDOC
BMERDOC's Avatar
Leevon, Did you see my thread about "Match using Cross specs"? It looks like you have one of the latest Hunter machines and it should have that feature. You can find it in my sig as "Easiest Alignment Ever". Any shimmed vehicle can be aligned like this. Its so quick and easy. .13 for a thrust angle is great. I think mine is near .25. I'm sure I'll mess with it once I install my double adjustable bar on. The only I would be concerned about is getting the trailing arm bushings in a bind. There are so many mods that I want to do but I've been concentrating on aesthetics recently.
Nick Carter
Old 04-21-2014, 08:04 PM   #213
BMERDOC
BMERDOC's Avatar
For you guys paying attention I wanted to share a thread that 19GM71 posted. Its another great mod to get your steering and suspension done. I priced out this set up for my truck and I think it came out to about $85. Totally worth it!
http://67-72chevytrucks.com/vboard/s...d.php?t=620584
Nick Carter
Old 07-23-2014, 11:42 PM   #214
Lattimer
Lattimer's Avatar
Bump for alignment stuff.......
Had my Chevy in twice so far to get the front end alignment, and it just wasn't good enough. Same shop just did my Tundra 3 times and still couldn't get that right. They used to be good........
Anyways, I got kinda peeved at the "that's as good as we can do" line, so I went and bought a QuickTrick alignment kit. Expensive bugger for what it is, but it works pretty decent.
Spent the last weekend working on the front end trying to get it where I want it. Truck is lowered 2"/2" with just springs, all new front end wear parts, otherwise stock. First time I have ever attempted any kind of alignment myself------but I am a mechanical engineer, and I have taught people for years how to laser align pumps and compressors. Took a bunch of trial and error and head scratching, but I finally got everything going the right way and managed to not destroy anything.
By the time I was done, I had to remove half of the rear self aligning washer on the right side, and had a single 1/16" shim on the front of the left side. Nothing else.
Now I have:
L Camber -.7 degrees
R Camber -.7 degrees
L Caster 1.8 degrees
R Caster 2.4 degrees
Total Toe 3/16" in.
Only downside to the Quicktrick is you can only do total toe, getting the wheel set straight is trial and error.
Today I got the chance to get the truck out and drive it to work and back. Ran it up to 90 mph, drove some side streets, took a few hard corners. Feels pretty good. Nice and stable, doesn't wander or pull at all. Steering is pretty "normal", not dead and not twitchy. Seems pretty good. Return to center still as lazy as it has always been, but I'm used to that.
I know now I can get a little more caster on the left if I want to, but the right is maxed out without doing the lower control arm mod. I'm on the fence at this point whether that is worth the effort or not. Not real sure how to quantify any improvement I would get.
Next I need to try to fix the alignment on my lifted Tundra. That should be a riot.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-24-2014, 12:27 AM   #215
BMERDOC
BMERDOC's Avatar
Really good job! That stinks that the equipment will only do total toe. As far as the Caster Mod is concerned I feel its totally worth it and no I haven't done it to mine yet but I am confident that with 5° or more return to center will greatly improve and higher speed stability will be even greater.
Nick Carter
Old 07-24-2014, 09:38 AM   #216
Lattimer
Lattimer's Avatar
I'm still debating between doing the LCA castor mod and just saying screw it and buying the tubular control arms. Probably do all of it at once when I do the disc brakes, which won't be for a at least a year or so.
Shawn
Old 07-24-2014, 01:44 PM   #217
BigDaddyV
BigDaddyV's Avatar
Sub. Thanks I'll be using this info in the near future.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 07-24-2014, 07:15 PM   #218
Greywolf200
Now I have:
Total Toe 3/16" in.
Since you can do it easily, I'd suggest changing to toe out. I made this change and the difference in turn in is amazing. Everything else remains the same. At 1/8" toe out, it is not twitchy and makes it far more responsive.
Hope this helps,
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 07-24-2014, 07:32 PM   #219
Lattimer
Lattimer's Avatar
Hope this helps,
I had it 1/8" out and it felt weird.
Shawn
Old 09-19-2014, 06:56 PM   #220
lit549
If I posted my alignment sheet on my 85 swb c10, could anyoNE tell me if its a good setup??
lit549 is offline   Reply With Quote
Old 09-19-2014, 07:12 PM   #221
BMERDOC
BMERDOC's Avatar
Sure! Post it up.
Nick Carter
Old 04-20-2015, 09:22 AM   #222
pablo101
pablo101's Avatar
Need to get some Shims so my work can do an alignment. They don't have shims for my 71 c10 (new subaru dealership)..What is the Bolt size 9/16 or 5/8 so I can get some. Thanks in advance
pablo101 is offline   Reply With Quote
Old 04-20-2015, 09:38 AM   #223
BMERDOC
BMERDOC's Avatar
You can get a shim kit for under $10 from Harbor Freight if you have one nearby. I use that kit and it works great. If you don't have one close you can order it online.
Nick Carter
Old 04-20-2015, 09:45 AM   #224
pablo101
pablo101's Avatar
Ok great but from what I can find there are two bolt sizes 9/16 and 5/8.I dont know which I'll need
Old 04-21-2015, 06:15 PM   #225
BMERDOC
BMERDOC's Avatar
The frame bolts that retain the upper control arms are actually 1/2". The part number for the HF shim kit is 67585 and works perfectly.
