Old 07-04-2014, 04:33 AM   #201
chewychevy67
Re: 67 GMC super custom build
I had chicago carburetor do the carb. The rear diff is a dana 44, commonly used in gmc rear leaf setups and the alternator is a 20dn type 150 alternator. They were optional on trucks in 67.
chewychevy67 is offline   Reply With Quote
Old 07-04-2014, 12:25 PM   #202
nlped
nlped's Avatar
Just read the whole thread and this is ONE beautiful truck. Love your meticulous attention to detail. Subscribed!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-04-2014, 11:50 PM   #203
chewychevy67
I got the passenger side finished up today. Here's what it looks like. I think that this exhaust manifold is cracking so I will need to get another one. Does anyone know what coating is on the smog tubes from factory? Anything out there that will last on these?
Old 07-07-2014, 08:26 PM   #204
chewychevy67
sorry for all the motor pics guys but I do this for myself so I can see these anywhere I go rather than running home to my computer all the time. sure you guys don't mind. rebuilt carb on now, dizzy and plug wires. Never had a set of pre-made wires fit so well out of the box. now to tear it apart and rebuild it all. still would like to know where the Smog signal hose goes if anyone knows.
Old 07-08-2014, 05:43 PM   #205
67chevy1series
67chevy1series's Avatar
Even though the engines old and crusty I still want to say it's looking good. And keep the progress comin!
67chevy1series is offline   Reply With Quote
Old 08-02-2014, 10:09 PM   #206
chewychevy67
took my smog pump apart tonight. Going to have the aluminum case colored as the fuel pump is. clean up and de-vein it.
Old 09-08-2014, 06:38 PM   #207
chewychevy67
good and bad today. got my smog pump together but found out the bondo in my cab is cracking in both kick panels under finished paint. the body shop I used was a mistake. I have since parted with them but I have paid for crappy work which I will pay for again. I believe I am going to have the cab brought back to the metal to see what else hides under the primer. don't trust their work at all. The next shop I use I will get references. lesson learned but the build will go on. I would rather have this happen now at this stage than when it is all assembled and finished.
Old 09-09-2014, 09:03 PM   #208
gdavis
gdavis's Avatar
went thru your build again. you have come a long way. You are doing a great job and sorry to hear about the body shop. That is why I did all the work myself. 98 % anyway. Was the guy that did your webbing a fellow board member? I need a set done for me.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 09-09-2014, 09:45 PM   #209
chewychevy67
A company named Snake Oyl did my seat belts. Did a very nice job too. You can find them on the web. I wish my welding skills were better. I would do my body work as well.
Old 09-29-2014, 04:18 PM   #210
chewychevy67
well since I am going to redo my cabs body work I am going to add power vent windows and locks to the truck. I think I know how I am going to do it. anyway I finally found the correct era style switch for the vent windows to match my other switches. I am not sure the locks are really worth it as the lock pops up when you close the door but I already have them and the switches so Ill add them in. ill keep you posted when I fab up some stuff for the windows. here is what the metal switches look like.
Old 12-04-2014, 12:30 AM   #211
chewychevy67
A little change in plans. I got a Brothers Deluxe oak bed wood kit local for a really good price so i decided to use it on this build. Got it stained up this evening. I tested a small piece and cleared it to see what it will look like.
Old 12-04-2014, 08:14 AM   #212
darkhorse970
darkhorse970's Avatar
That bed wood looks very nice!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-04-2014, 09:13 AM   #213
mcbassin
Still Learning
mcbassin's Avatar
Sorry to hear about the body shop problems. That's a pretty common problem when it comes to finding a good quality shop to work old trucks. Nice work on the wood floor and engine.
mcbassin is offline   Reply With Quote
Old 12-04-2014, 10:52 AM   #214
chewychevy67
I cleared the oak once this morning!
Old 12-04-2014, 10:04 PM   #215
swamp rat
swamp rat's Avatar
What stain did you use?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-04-2014, 11:49 PM   #216
chewychevy67
I used a color called arrowhead. It is the same as the stain on the maple i was going to use earlier in the build. I had my cabinet guy mix it up for me.
Old 12-17-2014, 11:05 PM   #217
chewychevy67
I was tinkering with this 70's Cadillac thermometer and this is what I came up with. Not sure if I am going to keep this just a tinker. has Celcius and Ferinheit and is fairly accurate. It lights up and will mount to the mirror arm. I wiped off the Cadillac decal and if I do use this I am going to have a GM decal made for the end. What do you guys think, cool or quirky?
Old 12-18-2014, 05:14 AM   #218
swamp rat
swamp rat's Avatar
I missed your reply on the stain color, i really like it as it something you don't see every day.
Per the temp gauge i say you got nothing to loose if ya try it, you can always take it off and weld up the holes and re paint it if you don't like it.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-14-2015, 02:58 PM   #219
chewychevy67
I got my 67 impala steering wheel all restored but it got painted black instead of red. I do kind of like it in black but unsure if I want to paint my column black with a full red interior. what do you guys think? black column and wheel or red?
Old 01-14-2015, 03:20 PM   #220
Lee H
Lee H's Avatar
Very nice!! I'll vote for red.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-15-2015, 01:30 AM   #221
gdavis
gdavis's Avatar
still looks ok I see you painted the column also sweet
Check out Patches
Old 01-15-2015, 01:23 PM   #222
chewychevy67
the more I look at it the steering wheel/column needs to be red. The black just stands out too much. Black looks good in the newer stuff but looks awkward to me in 67 68 trucks. it doesn't have a supporting cast like black dash pad, rug and belts is what I think does this.
Old 01-15-2015, 05:48 PM   #223
swamp rat
swamp rat's Avatar
yep, it looks good!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-15-2015, 10:18 PM   #224
Orange67
Orange67's Avatar
I vote red, but I may be biased... The pic with the buddy's is what mine should look like. Amazing build, hope mine will be half that nice!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 02-27-2015, 04:59 AM   #225
chewychevy67
Well I sold the power door locks but ordered the power vent window motors this morning. Hope I can get them working properly. ive never seen power vent windows done in a 67 72 truck. Will be neat!
