Old 10-07-2017, 01:54 AM   #201
520-k5
520-k5's Avatar
Re: project orange crush 76 crewcab build
I'm sure as soon as I fix this one a nice clean one will pop up cheap! lol but I got the driverside in epoxy tonight. I'll scuff it and shoot the polyester primer this weekend
520-k5 is offline   Reply With Quote
Old 10-18-2017, 06:19 PM   #202
Crcrft78
Crcrft78's Avatar
Any updates on this build?
Crcrft78 is offline   Reply With Quote
Old 10-18-2017, 07:16 PM   #203
520-k5
520-k5's Avatar
Just doing the bodywork now. Been taking what I can to work to strip and bodywork while it's slow and priming at home.
Old 10-19-2017, 02:16 PM   #204
Crcrft78
Crcrft78's Avatar
Looking good. I can't wait to see some color on this.
Old 12-29-2017, 01:42 AM   #205
520-k5
520-k5's Avatar
Haven't done much to the truck with the holidays and all. I did bodywork and epoxy the front door and welded up the mirror holes since I'm going to the smaller style sport mirrors. Took the bed back off again so i can bodywork the rear of the cab and that's about it. There's the last spot of rust on the whole cab ill address that when i bodywork the roof
Old 12-29-2017, 01:45 AM   #206
520-k5
520-k5's Avatar
Picked up a cool vintage camper for free too. Its in rough shape but at least itll keep my parts dry and the pack rats out of the bed during winter
Old 12-29-2017, 01:53 AM   #207
520-k5
520-k5's Avatar
I have done alot to the red truck on the otherhand. Its drivable now with just a few minor things left to do.
I bought a parts truck with a goodwrench 350 and what looked like a solid pass fender. The fender turned out to be full of mud and in worse shape then mine bodywise so I'm still looking
Old 12-29-2017, 02:02 AM   #208
520-k5
520-k5's Avatar
Here's the goodwrench 350 cleaned up and mated to a th 400. The Driveshaft was already set up for a truck style th400 so i got lucky there. I rebuilt an older edelbrock 600 and added a new mini stater,fuel pump,finned valves covers and air cleaner,msd plug wires etc etc etc also bought a bb radiator and top mount. I also had to go thru the brake system and replaced the master cyl, brake hoses and rear wheel cyl's
Old 12-29-2017, 02:12 AM   #209
520-k5
520-k5's Avatar
Also picked up some 17" rallys for it too. The offsets wrong and they tuck in way too much in the rear they could really use another 3" offset to bring them out but cant complain too much for what i payed for them. All the lights even work as they should!
Old 12-29-2017, 02:22 AM   #210
520-k5
520-k5's Avatar
As it sits right now. I have some wiring work to clean up inside the truck and time to start tackling the interior work. The exhaust needs to be lengthened a little bit to meet the headers from the parts truck and that's about it. It'll be daily drivable then and ready for it's new owner
Old 12-29-2017, 05:47 PM   #211
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on your crew and the red crew. If you need a patch for the roof on your crew, I have a 88 cab I'm using for patches and I could cut a piece off it for you if you'd like.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-29-2017, 06:34 PM   #212
520-k5
520-k5's Avatar
Thanks for the offer but I've got 2 donor roofs already from cabs I've cut up in the past. They make good tables lol
Old 12-30-2017, 07:40 PM   #213
jkk
jkk's Avatar
Needs some bigger wheels
jkk is offline   Reply With Quote
Old 07-11-2018, 01:28 PM   #214
520-k5
520-k5's Avatar
It's been a while but I'm still here lol. Finally sold the red crewcab last month after sitting on it for months. Ended up redoing alot of the interior in black texture and put brand new carpet ,insulation in with dynamat also. Also put 15x8 rallys with new tires rings and caps that I kept after I sold it. Using those on the new project now
Old 07-11-2018, 01:36 PM   #215
520-k5
520-k5's Avatar
Then I picked up this 77 dually back in feburary for 850 bucks couldn't pass it up. I wanted to build a shortbed dually out of it but after moving it around my yard a couple times I got over it and just wanted it gone.
Old 07-13-2018, 01:21 PM   #216
520-k5
520-k5's Avatar
So I traded my buddy for this 78 c30. He threw in a 4.8 ls and new wire harness kit to sweeten the deal.
Old 07-13-2018, 01:27 PM   #217
520-k5
520-k5's Avatar
So I didnt waste any time getting started on this one. I stripped the gas tanks,exhuat, running boards,rear bumper,home made trailer hitch garbage,front hitch and any add on accessories the previous owners installed. Then I unbolted the frontend to store ag home for now
Old 07-13-2018, 01:32 PM   #218
520-k5
520-k5's Avatar
Then we got it into the shop and prepped the frame for the shortbed conversion. We took 14" out behind the cab and cut 3.5" off the rear of the frame.
Old 07-13-2018, 01:39 PM   #219
520-k5
520-k5's Avatar
With it all welded up I ground the outsides of the frame and welded up the inside and prepped the inside for the fish plates which I still need to make and weld in
Old 07-13-2018, 01:44 PM   #220
520-k5
520-k5's Avatar
Then I dropped all the old 1 ton suspension and started cleaning the frame with a wire cup to remove the grease,under coating and scale build up.
Old 07-13-2018, 01:48 PM   #221
520-k5
520-k5's Avatar
The frame cleaned up pretty good I think.
Old 07-13-2018, 01:54 PM   #222
520-k5
520-k5's Avatar
Next I had enough parts left over from parts truck to piece together a c10 suspension clip including drop spindles and drop springs I picked up. I prepped the c10 crossmember with the same wire cup and painted it and the frame area with some rattle can black
Old 07-13-2018, 02:01 PM   #223
520-k5
520-k5's Avatar
I painted the spindles sway bar and center link too but I'm still waiting for the front suspension rebuild parts to arrive before I can clean, paint and rebuild the a arms. For now I'll just assemble it so I can make it a roller. I also got the old spring pad mounts and shock mounts cut off the 12 bolt. I picked up some new spring pads locally and was able to get the 12 bolt flipped and mounted on top of the springs.
Old 07-13-2018, 02:07 PM   #224
520-k5
520-k5's Avatar
And with everything mounted it's a roller now.
Old 07-13-2018, 02:12 PM   #225
520-k5
520-k5's Avatar
Sure looks good outside with the 5/5ish drop and the rallys left over from the red crewcab. The front suspension parts should be here this weekend so I can get the rest of it rebuilt and hopefully get the fenders mounted again and the rest of the front frame painted.
