Old 12-17-2017, 12:42 AM   #201
thetucks
Re: 1972 Chevy Pickup Project.
Originally Posted by Jason7121 View Post
Lol if I was closer I would come help you out where I could haha
Yep that would be sweet. If only...
1972 chevy pickup/ 2004 chevy tahoe merge...
My build -http://67-72chevytrucks.com/vboard/s...d.php?t=731246
thetucks is offline   Reply With Quote
Old 12-17-2017, 06:49 PM   #202
thetucks
So back to the salvage yard this morning I went. I picked up a new wiper switch. I brought it back looking up and the wipers are working like it supposed to now. I tried to find a clock Spring while I was there but everyone has already taken all of them. So when I got back I wanna head and took my clock Spring out and took it apart and sure enough it is ripped at both ends.
Old 12-18-2017, 01:56 AM   #203
Jason7121
Jason7121's Avatar
Well glad that fixed the wipers. New clock spring and you should be set!
Jason7121 is offline   Reply With Quote
Old 12-18-2017, 05:41 PM   #204
thetucks
Well here is what I have decided. I picked up a different steering wheel yesterday and I put it on the truck. This morning I ordered a new 7" touch screen with navigation. I think I am going to like this route a lot better
Old 12-18-2017, 06:14 PM   #205
Jason7121
Jason7121's Avatar
That should be super nice!
Old 12-18-2017, 07:46 PM   #206
thetucks
Ok I just found another problem.....I took the truck for a drive (man was it fun) and the issue is when I put the shifter into park it clicks the clicker for the blinkers. It dont flash any lights but I can hear the clicker click 4 or 5 times. I can duplicate the results anytime I put the shifter into park. even without the engine running. anytime you shift back to park it clicks. any ideas? thanks
Old 12-18-2017, 07:51 PM   #207
Jason7121
Jason7121's Avatar
Have you replaced the multi function turn signal switch/wiper switch
Old 12-18-2017, 07:54 PM   #208
thetucks
Yes thats how I fixed the wipers. That was my thought as well that it was causing the problem but I put the old one back on and it does the same thing. everytime its put into park it clicks.
Old 12-18-2017, 07:57 PM   #209
Jason7121
Jason7121's Avatar
Does it click both signals or just one side? Is hazard switch stuck?
Old 12-18-2017, 08:07 PM   #210
thetucks
it actually dont light up any lights, it only clicks the clicker that in the fuse box. Its the same clicker that clicks when the trun signals are presed.
Old 12-18-2017, 08:24 PM   #211
Jason7121
Jason7121's Avatar
Let me look it up for you
Old 12-18-2017, 08:33 PM   #212
thetucks
thanks
Old 12-18-2017, 08:38 PM   #213
Jason7121
Jason7121's Avatar
Are you running the Tahoe body control module
Old 12-18-2017, 08:55 PM   #214
thetucks
yes
Old 12-18-2017, 09:03 PM   #215
Jason7121
Jason7121's Avatar
Do you have door switches hooked up and wired to bcm so it knows when doors are ajar
Old 12-18-2017, 09:07 PM   #216
thetucks
No there are no door sensors hooked up.
Old 12-18-2017, 09:09 PM   #217
Jason7121
Jason7121's Avatar
Does it click five times after the key is shut off or with the key still in the running position
Old 12-18-2017, 09:17 PM   #218
thetucks
While it is still on. As soon as you put it into park it does it.
Old 12-18-2017, 09:21 PM   #219
Jason7121
Jason7121's Avatar
I don't know if it will fix that problem or not but you definitely need door switch signals going to the body control module. If your truck does not have door ajar switches it is not that hard to install I did it on my project
Old 12-18-2017, 10:08 PM   #220
thetucks
Do you know which wires from the bcm are for the door adjar?
Old 12-18-2017, 10:50 PM   #221
Jason7121
Jason7121's Avatar
I'll look at a wiring schematic for you. You can also wire it so your dome light comes on when door is open. Your door switches will provide a ground when door opens.
Old 12-18-2017, 10:54 PM   #222
thetucks
I found the wiring diagrams for the bcm I believe. It seems I need to show the rear doors closed as well as the rear hatch. Now that I think about it my instrument cluster keeps saying replace lift gate fuse. but i find no such fuse.
Old 12-18-2017, 11:14 PM   #223
Jason7121
Jason7121's Avatar
Yeah just trick bcm to think there closed except for front doors.
Old 12-19-2017, 12:31 PM   #224
thetucks
i grounded the wires from the bcm that are for the rear doors and the rear lift gate. Now the instrument cluster says those 3 doors are open. Which wire goes to the dome light? I need to hook it back up so I can test if its on?
Old 12-27-2017, 12:11 AM   #225
Jason7121
Jason7121's Avatar
Any luck with the wiring issues you were having
