Old 01-17-2019, 07:16 PM   #201
Thrill4130
Active Member
Thrill4130's Avatar
Installed new dimmer switch, headlight and reverse bulb on my longbed. Next is hunting down why the brights circuit is open. Buttoning up a new fuse block setup to mount pcm, Tac Module, obd2 and clean up wiring in my shortbed.
Thrill4130 is offline   Reply With Quote
Old 01-18-2019, 12:21 PM   #202
UNEASYRIDER
UNEASYRIDER's Avatar
Re: What did you do to your truck today.The 3rd chapter
Gave her a bath after getting her stuck !
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline   Reply With Quote
Old 01-18-2019, 12:28 PM   #203
elorenzof
HAHA we have all been there. (at least i have) nice truck!
elorenzof is offline   Reply With Quote
Old 01-20-2019, 03:27 PM   #204
AussieinNC
Moderator
AussieinNC's Avatar
Finally...some time on Old Blue...
truck has sat idle for a few years now while I worked on other projects, mostly for other folk...
Purchased this 1967 LWB 2WD V8 about four years ago...put it on the shop, ripped off the bed and doors and seat to clear out mice nests...and there it sat...until today.
Checked the oil and coolant...
Bypassed the ignition circuit and starter circuit by removing firewall plug...
Pulled carb and cleaned out the junk...no gasket set available so I reused the old ones...
Added a temporary fuel supply system and primed the carb....(original 2GC )
Turned her over a bit to get some oil circulating....
Connected power to Ign circuit and away she went !.....
No smoke
No blowby
Let her warm up for about 15 minutes...darned thing sits there and idles !
Some times it nice to work on something just for yourself...
Pics coming later...
Nearly time for football!!!!
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-20-2019, 03:33 PM   #205
NewBayColony
NewBayColony's Avatar
Put a NOS door latch from Riverside Truck and Auto Parts in Milliken, CO. I enjoyed talking to John and his assistant there while my part was being retrieved for me. Now my door opens and closes properly.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 01-20-2019, 06:32 PM   #206
nlped
nlped's Avatar
This!!!!
Getting ready for the first trial fit on the new Porterbuilt chassis.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-20-2019, 07:23 PM   #207
FL71C10
Ran some 10 gauge wire for my electric Boyd's fuel tank pump
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-20-2019, 07:56 PM   #208
RodnRudy
RodnRudy's Avatar
I finished up installing the new glass run channel and whiskers on the driver door and reassembling said door parts and refurbished vent wing per Randy 500's invaluable instructions. Low and behold now the door won't lock with the key so it's back out with the latch and again with one of Randy's tips I relieved the door lock pawl with my die grinder, first pic, hard to see the relief with all the lithium grease, and discovered the door latch pawl pin was loose to boot. Since there wasn't enough "meat" to re stake the pin, pic 2, I cleaned up the area and welded the pin to the latch body, pic 3. After reassembly the latch works like when it left the factory 51 years ago and the key works the lock effortlessly. Hats off to Randy500 for the posts he helps us with.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 01-20-2019, 09:33 PM   #209
bill3rail
bill3rail's Avatar
Not today but recently...
Started her up, moving out of garage she dies...
Cranking but no start condition.
Check and she is getting fuel.
Check spark, Non-existent.
Check coil and windings are both primary and secondary are open circuits.
Pull spare coil from tool box in bed, install coil and she starts right up.
Seems to run better than late in the season last year so the coil was probably going bad with an intermittent stalling issue.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 01-21-2019, 11:28 PM   #210
Metaldoc
Metaldoc's Avatar
Door jamb pin wedges for my 67
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 01-22-2019, 07:12 AM   #211
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
I'm making a new horn cap for the ramp truck. I have a corvette steering wheel I'm using and the hub, it's the same as the comfort grip wheels basicly.
But I am doing a custom horn button for it. Still need to paint the ring though. Haven't decided what color yet.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-22-2019, 09:14 AM   #212
RodnRudy
RodnRudy's Avatar
Nice job on those pin wedges Metaldoc
Phil
Old 01-22-2019, 09:20 AM   #213
70STOVEBOLT
70STOVEBOLT's Avatar
Does anyone know what year GM started putting the flat boss on the cab for the courtesy light switches? My 70 has them.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-22-2019, 12:51 PM   #214
Metaldoc
Metaldoc's Avatar
I think it was 69 and up
Old 01-22-2019, 12:52 PM   #215
70STOVEBOLT
Thanks Metaldoc
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 01-22-2019, 02:27 PM   #216
Chris_oz
Chris_oz's Avatar
New rims and tyres.
Wheel Vintiques 16 x 6 for the front, 16 x 8 for the rear.
215-85 r16 and 265-70 r16 tyres.
Rides so much better than the out of round 16.5" that were on there.
Just need to drop the rear about 4" (maybe more)
My Disc brake and drop spindles also arrived, I checked it for clearance on the 16 x 6 rim (4" backspace) it is fine.
They will go on very soon, along with a new booster, master cylinder and proportioning valve from CPP.
Chris_oz is offline   Reply With Quote
Old 01-22-2019, 03:24 PM   #217
Auroch
Auroch's Avatar
Installed the carpet, three point seatbelts and put the seat in finally! Three years almost, sitting on an apple box.
Auroch is offline   Reply With Quote
Old 01-22-2019, 03:53 PM   #218
Beau2a
Beau2a's Avatar
Replaced my below eyeline mirrors with some sport mirrors.
Beau2a is offline   Reply With Quote
Old 01-22-2019, 04:17 PM   #219
Dad's72
Dad's72's Avatar
Removed the doghouse and pulled the motor and trans to clean up the front third of the frame for paint.
How hard was it to pull the doghouse off? I have looked for detailed steps online but couldn't find anything. I need to pull mine off to put the motor and trans back in easier. And to clean things up a little. I have an 8 ft garage so the lift will not get high enough to clear the grill.
Dad's72 is offline   Reply With Quote
Old 01-22-2019, 06:33 PM   #220
70STOVEBOLT
Dad's72, I unbolted it piece by piece because I don't have good place to store the assembled doghouse inside. If you can just remove the hood and front bumper, and unbolt the fenders from the cab, it is much easier, however, you will need some extra muscle to move the whole thing after it's unbolted. My garage also has an 8' ceiling, so I built a frame out of 8' 4x4 posts and used a come-a-long to remove the engine. I unbolted the trans first and removed that separately, as the wooden frame would not support the weight of the big block and TH400 trans together. Here is a pic of the frame I built.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 01-22-2019, 06:35 PM   #221
72c20customcamper
72c20customcamper's Avatar
I got my upper bed moldings. They were delivered to my rental property as that's where my truck is stored. But with the ice and cold Im sitting it out next to my woodstove with a nice glass Tullamore Dew. But I'm going to Buffalo this weekend to look at a big block 68 .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-22-2019, 11:24 PM   #222
rechinca
rechinca's Avatar
New hood hinges, the others were shot and even had bolts instead of rivets in a couple spots. That little tool they sell to pull the springs made it easy (plus the college football player is home for a couple of days so I cheated). Also pulled the RH inner fender and the heater box. Some PO had the heater core in upside down, goofy ground wire installed wrong, only half the bolts holding it in as well as a HUGE mouse nest on the inner portion. Also unbolted both exhaust manifolds and found those bolts loose with gaskets behind the ram horn manifolds. Well, at least putting in the correct plug wire stands, shields and new plugs will be way easier!
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-23-2019, 06:41 PM   #223
RodnRudy
RodnRudy's Avatar
Nothing to the truck today but I did hang this wall art up in the garage. Got it at the Home Show the wife drug me out to yesterday. Wasn't too bad after all.
Phil
Old 01-23-2019, 08:44 PM   #224
rechinca
rechinca's Avatar
That’s a nice looking little piece of art you picked up!
Old 01-24-2019, 08:13 PM   #225
66clow
66clow's Avatar
Started the teardown to hopefully get this puppy painted soon. I'm going to hate not being able to drive it for a bit. But it will be worth it in the end.
66clow is offline   Reply With Quote
