Old 08-16-2019, 12:01 PM   #201
nlped
nlped's Avatar
Re: 1987 R10...aka Belushi
I’m also contemplating putting a serpentine setup on Belushi to downsize the clutter on the front of the motor.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-17-2019, 06:18 AM   #202
Desert1957
Desert1957's Avatar
Originally Posted by nlped View Post
Nothing really happening here anymore, but I did upgrade/repair my sliding back glass lock. The one in the truck when I got it was broken so I bought the standard plastic Dorman replacement part from the local parts store. Went on fine and seemed to fit the bill, but I was out driving the truck last Sunday and noticed in the rearview mirror that the window was slightly open. Somehow the POS Dorman piece had broken...I never touched it after I installed it and it broke. So, I went in search of a metal replacement. Didn’t take long and I found one. So here are some pics and it does seem to be a much better option.
Where did you purchase the metal kit? I need one.
Desert
Desert1957 is offline   Reply With Quote
Old 08-17-2019, 09:54 AM   #203
nlped
nlped's Avatar
Amazon. Just search ‘DVL2 latch’ and it’ll be the 2nd or 3rd result.
Carter
Old 08-19-2019, 04:28 PM   #204
nlped
nlped's Avatar
Well, I think I’ve got the engine bay detailing done...at least for now.
Carter
Old 08-19-2019, 04:30 PM   #205
nlped
nlped's Avatar
I’m done... at least for a little while. Time to get back on the Falcoon
Carter
Old 08-20-2019, 08:50 PM   #206
TKCR
TKCR's Avatar
Looks good
Old 08-21-2019, 07:32 PM   #207
nlped
nlped's Avatar
Originally Posted by TKCR View Post
Looks good
Thanks Tina!
I also decided to clean, polish & wash the underside of the hood and install new hood insulation.
Carter
Old 08-21-2019, 08:30 PM   #208
nlped
nlped's Avatar
I also decided to install the rear wall carpet piece. I don’t really care for it, but maybe the little extra insulation factor will make it quieter inside?
Carter
Old 08-21-2019, 09:13 PM   #209
TKCR
TKCR's Avatar
I like both. I went with something a little different. I saw this and wanted it ever since. Got it after the OEM hood was painted.
I had the cardboard tool tray, but I carpeted over it. It seemed like it made the cardboard tray a bit more durable.
Old 08-25-2019, 07:17 PM   #210
nlped
nlped's Avatar
I ordered up an Eaton posi and an aluminum diff cover today. Hopefully, I get them installed next weekend.
Carter
Old 08-29-2019, 07:48 PM   #211
nlped
nlped's Avatar
Got the posi, diff cover...& a matching set of valve covers. I’ll start the install of everything this weekend. Hopefully, I’ll be laying down two fat black lines by Sunday.
Carter
Old 08-30-2019, 09:29 AM   #212
SCOTI
SCOTI's Avatar
Is that carpet 'wall' from the supplier or just bulk material that you made work? Fit looks nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-30-2019, 10:06 AM   #213
nlped
nlped's Avatar
It’s made by ACC. It does fit pretty well, cleaned up the back wall and it did seem to quiet down the exhaust note when sitting still. Oh, and it was relatively inexpensive and easy to install.
Carter
Old 09-01-2019, 01:45 PM   #214
nlped
nlped's Avatar
Well, I ended up with a pretty serious mishap. My differential that I ordered showed up, but.... It is the wrong one. Unfortunately, I didn’t get the differential until after I’d disassembled the rearend. The packing list says it’s for an 8.5”, but the new differential is an 8.2”. I’m dead in the water
Carter
Old 09-01-2019, 02:04 PM   #215
nlped
nlped's Avatar
Well, it just keeps getting better... NOT. Pulled the new valve covers out of the box and...
Time for the pool and
Carter
Old 09-01-2019, 02:26 PM   #216
mongocanfly
Post Whore
mongocanfly's Avatar
looks like some of my luck is finally rubbing off on you....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-01-2019, 02:48 PM   #217
nlped
nlped's Avatar
Hahahaha, this is just par for the course for me.
Worst part is that the lift is tied up until I get the diff installed. I was going to get the diff in today and then get started on swapping out the transmission in Martha tomorrow...
Carter
Old 09-02-2019, 10:20 AM   #218
nlped
nlped's Avatar
Just so I can always confirm it has a 3.73 in it. Part # on the ring gear is 26035826 11-41 GMK. 41/11=3.727
Carter
Old 09-03-2019, 09:50 AM   #219
rustyfive-seven
nice truck! just curious what size 18" tire your running? I have a similar set of ridlers. thanks! Russ
rustyfive-seven is offline   Reply With Quote
Old 09-03-2019, 10:39 AM   #220
nlped
nlped's Avatar
I’m running Toyo Proxes ST II’s. Fronts are 18x8 with 255/50r18 and rears are 18x9.5” with 295/45r18’s.
Carter
Old 09-03-2019, 11:08 AM   #221
nlped
nlped's Avatar
So sad just hanging there...
Carter
Old 09-03-2019, 04:41 PM   #222
nlped
nlped's Avatar
They are shipping a Yukon Duragrip posi next day air and giving me a substantial refund due to time lost.
Carter
Old 09-04-2019, 12:25 PM   #223
SCOTI
SCOTI's Avatar
That helps.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2019, 08:31 PM   #224
nlped
nlped's Avatar
That helps.
Yes it does!
Well, it did show up as promised and It’s the correct part.
But I have my Falcon on the lift because I’ve got to get the trans pulled out of it. Hopefully I’ll finish pulling it tomorrow night after work. Then I’ll start back on Belushi.
To many PROJECTS!!!
Carter
Old 09-05-2019, 10:50 PM   #225
nlped
nlped's Avatar
I couldn’t STAND it. So I finished up installing the diff tonight. Ended up having to ‘shim’ up the pinion a tiny bit as it was a bit sloppy (&it needed a new seal anyway). It is quiet as a mouse, but no more right tire spin from a stop. I didn’t do any touch up painting as I was just amped up to get it back running, but here’s a shot. I promise that I’m going to clean it up paint the housing this weekend
Carter
