Old 08-13-2022, 03:49 PM   #201
SCOTI
SCOTI's Avatar
Re: A '62 has to get back on the road
Originally Posted by Braunschweiger View Post
That's right, building a 4Banger is very expensive, in the Netherlands there is a very experienced engine builder who builds many Model A engines, including the Burtz engines. Here in Germany there are strict approval regulations, it is now very difficult to approve hotrods with other drive trains, or chopped or slammed. You need a specialist who knows his stuff and does the approval so that the authorities don't shut down your car, hard times for Roder. And I'm fascinated by the 90-year-old technology.
I was all on-board for the new Burtz motor. We went to a Model-A National convention in June & he was one of the speakers. What I didn't expect was that despite the engineered updates, the motor still made no more power vs an original. I'm not spending >$6500 for a non original Ford set-up that made no more power vs the 90yr old babbit bearing 3-main motor currently in it.
Heck, a bone stock 305 out of a late 70's GM car was double the power @ a fraction of the cost. Same w/the trans gearing. Later model stuff has much better gear splits & synchonizers @ a lower cost.
We'll keep the Cabriolet close to Oe (OE block, Brumfield hi-compression head, FSI 12v ignition, '39 synchronized 3spd, Mitchell OD). If I find a coupe... V8 w/a 5spd.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-13-2022, 04:27 PM   #202
Braunschweiger
I don't want to afford a Burtz motor, it costs around €12,000 assembled in Europe, no way. The original engine, rebuilt with new bearing shells and gaskets, different cylinder head with 6:1, camshaft, carburetor and exhaust manifold, should put out 60-70hp, enough for 50-60 mph on small country roads. I dream of road trips with overnight stays on small country roads, quite comfortably. We will clarify that in the autumn. Sure a little flathead or a 289, I'd even have that lying around, that would be the easier way and a lot cheaper, I'm tempted to build the car with a 4Banger, It's gonna hurt my wallet
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 08-18-2022, 07:09 AM   #203
Braunschweiger
Done, the Hood is now painted, I sanded the mistakes wet and polished them again, there are still light scratches from wet sanding in the neon light, you can't see any of that in daylight, let's see if I can fix it.
Greetings Harald
My 62 build thread
Old 08-18-2022, 09:06 AM   #204
SCOTI
SCOTI's Avatar
Nice. You're making some good time getting the sheet-metal from old to new.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2022, 12:02 PM   #205
Duncan K
That hood looks great! Your project is really coming along!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 08-18-2022, 12:34 PM   #206
pdxhall
pdxhall's Avatar
Very nice. I hope I can get my hood to look that good.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-18-2022, 12:50 PM   #207
Braunschweiger
Thank you for your words, I always have to walk longer distances to reach my goal, but the goal is within sight.
Greetings Harald
My 62 build thread
Old 08-19-2022, 06:12 PM   #208
Grizz1963
Grizz1963's Avatar
You really do knock iy out the park Harald.
Looks beautiful.
Just to hijack the thread a bit….
My friend Dennis built his 66 on a 2015 Nascar truck with all the bits.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 08-20-2022, 02:43 AM   #209
Braunschweiger
Thank you, yes I was already looking at the pictures with envy, a completely different level, beautiful truck, very nice details, say hello to me.
Greetings Harald
My 62 build thread
Old 09-17-2022, 11:03 AM   #210
Braunschweiger
It goes on, I wrote that the Hood still had fine Scratches from wet sanding, it didn't let me rest, it didn't get better with polishing, I wet sanded it again with 1500, 3000 and 6000 and then polished it once, now I am satisfied and will polish the hood when it is assembled. At the moment it's very sluggish, my mom was sick and we were always driving back and forth, I had promised my wife to help remodel her sewing room. But I started with a side panel of the truck bed.
Annoying is the quarter panel doesn't fit, the flange edge is about 50° wrong, which I had to correct and the corners don't fit properly, that was also adjusted.
Greetings Harald
My 62 build thread
Old 09-17-2022, 11:06 AM   #211
Braunschweiger
There was still a patch for the lower wheel arches.
Greetings Harald
My 62 build thread
Old 09-17-2022, 11:53 AM   #212
Grizz1963
Grizz1963's Avatar
Mann, ich bin soooo sauer auf die schlechte Qualität von Patch- und Reproduktionsartikeln. Wir alle wissen, dass es genauso viel Arbeit ist, einen guten Artikel zu machen, wie es ist, einen schlechten Artikel zu machen. Manchmal möchte ich den Unternehmen Blut abnehmen, die diese Produkte herstellen, die dann viele Stunden zum Aussortieren benötigen. Sie werden es jedoch sicherlich alles richtig machen. Wie immer liebe ich es, Ihre Arbeit und Arbeitsmoral zu beobachten.
Rian.
Old 09-18-2022, 03:38 AM   #213
Braunschweiger
Thanks for your kind words, I agree, it's annoying to adapt the bad parts, but there are no alternatives, we all manage to build awesome trucks out of them over and over again.
Greetings Harald
My 62 build thread
Old 09-29-2022, 09:41 AM   #214
Braunschweiger
It's slowly Progressing, I had to make a new Spacer Strut, because where the Strut was welded to the side part, the Wheel Arches are also rusted through, so Patches are also needed.
The Quarter Panel is Welded in, the weld seam I lead filled this time, well.... the rest was smoothed out with "Lead" on 2K Epoxid Basic.
Now I can put Epoxy Primer on it tomorrow.
Greetings Harald
My 62 build thread
Old 09-29-2022, 09:45 AM   #215
Braunschweiger
Vorbereitung für Epoxid Grundierung.
Greetings Harald
My 62 build thread
Old 09-30-2022, 11:21 AM   #216
Braunschweiger
Applied the epoxy primer today.
Greetings Harald
My 62 build thread
Old 09-30-2022, 12:49 PM   #217
Grizz1963
Grizz1963's Avatar
Oooohhhh My Word !!
That looks amazing Harald.
Well done.
Old 10-03-2022, 10:33 AM   #218
88Stanger
88Stanger's Avatar
damn! looking great!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 10-04-2022, 12:05 PM   #219
Braunschweiger
The Hood is assembled, I had to exchange the Hinges for new ones, the old Hinges pushed the Hood up, after it was closed, now everything fits.
Greetings Harald
My 62 build thread
Old 10-04-2022, 11:35 PM   #220
62bagger
62bagger's Avatar
Looks great. The body work is impressive.
62bagger is offline   Reply With Quote
Old 10-05-2022, 04:43 AM   #221
Grizz1963
Grizz1963's Avatar
Well done.
These last photos look almost like a model set up.
Old 10-05-2022, 12:41 PM   #222
Braunschweiger
It could almost be a model.
Today I wanted to sanding the primer, it hasn't dried through yet, maybe it's a bit too thick, tomorrow I'll put the infrared heater over it.
Greetings Harald
My 62 build thread
Old 10-06-2022, 02:26 PM   #223
Braunschweiger
Today there was a Setback..... I put the Infrared Heater over the Panel. After some time there were Bubbles on the edge of the Bodyfiller, the Temperature was 50°/ approx.125 degrees Fahrenheit. This happened in 2 places, I could simply peel off the areas with the spatula. The rest was fine, something was wrong with the hardener and filler. I started all over again and filled with new Bodyfiller the spots.
#@€#% happens.
Better now than later.
Greetings Harald
My 62 build thread
Old 10-07-2022, 04:50 AM   #224
Grizz1963
Grizz1963's Avatar
Unfortunately as you say….. this happens.
And rather now, than later in a year or more.
Good luck with correcting it.
Old 10-07-2022, 10:19 AM   #225
Braunschweiger
I'm sure I made a mistake when mixing the Hardener and Body Filler, so today we made something nice for it.
My Buddy Sold his 60 Apache to Hamburg and took it to the Buyer, I drove with him and took it back, nice Road Trip and great Weather.
Greetings Harald
My 62 build thread
