Closed Thread
Old 05-22-2013, 02:05 PM   #2276
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
Not reading the original post, I would say probably having the cab and radiator support in place. That will let you place it front to back so you do not hit the firewall (or know where to modify) and check radiator clearance. Side to side depends on header configuration and clearance to steering stuff. Up and down, upper clearance is usually not a problem except where the bellhousing hits the firewall/floorpan. Lower depends on pan location. Set the intake manifold carb mount level with the frame, that puts the engine/trans back down about 3-4 degrees.
OrrieG is offline
Old 05-22-2013, 02:56 PM   #2277
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i meant more like keeping the mounts lined up right with each other. i guess i can just build a jig for that
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline
Old 05-22-2013, 03:00 PM   #2278
1-ton of fun
polishing a turd
i guess i need to order the raditator and dizzy to know how much it needs to/can move back
Old 05-22-2013, 05:36 PM   #2279
OrrieG
OrrieG's Avatar
The frame has alignment holes left over from original construction on the line. I think the rails were set in to a pinned jig, then the crossmembers placed and riveted. Frame shops use the same holes for straightening. Make sure your frame is square (they do move) then pick two points on each side (shackle rivet, body mount hole center, alignment hole) and use that for reference. I would use a block similar to yours to check before final welding.
OrrieG is offline
Old 05-22-2013, 07:21 PM   #2280
Daze57
Daze57's Avatar
http://youtu.be/yJ4hmKGKjbM
guys !!!! i know we are all truck and car fans - but i think we may have some competition for fans of a v v cool car/truck
enjoy
Daze57 is offline
Old 05-23-2013, 11:40 AM   #2281
skymangs
skymangs's Avatar
Drove mine to work today.
skymangs is offline
Old 05-23-2013, 07:39 PM   #2282
mknittle
mknittle's Avatar
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 05-24-2013, 12:30 AM   #2283
blue57
blue57's Avatar
I got my windshield wipers all mounted back up with the new electric motor from brothers. Also got the tailgate mounted with the Mar-k trunions, hidden hinges and almost have the latches in.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline
Old 05-24-2013, 10:26 AM   #2284
mknittle
mknittle's Avatar
enjoy
That is funny! the Benny Hill theme is perfect!
Mark
My GMC build.
mknittle is offline
Old 05-24-2013, 01:16 PM   #2285
OrrieG
OrrieG's Avatar
bent lower door hinge (helped a little, may need more) and replaced the door regulator rollers. Hope my door ws arrives today so I can get the doors done this weekend, if not, will finish up the welding on the gas door.
OrrieG is offline
Old 05-24-2013, 09:35 PM   #2286
Bubba54
I did a little rust repair on the passenger side rocker panel. I was able to do a little recycling in that the patch came from the drivers side rocker panel. The driver side had both ends pretty much gone, but the lower middle was in good shape.
Bubba54 is offline
Old 05-25-2013, 07:52 AM   #2287
FarmerSid
FarmerSid's Avatar
Nice repair! How do you like those panel clamps? I find the gap a bit too big.
FarmerSid is offline
Old 05-25-2013, 07:59 AM   #2288
Bubba54
They work well. What i do is fit the panel tight and mark where the clamps go, then i open that spot up a little more. If the seam is ever too tight i run my body saw blade between tacks to get a little gap.
Bubba54 is offline
Old 05-25-2013, 08:15 AM   #2289
Bubba54
Another note about the clamps. Keep an eye on the the alignment. the clamps are not always made square.
As the clamp on the right.
Bubba54 is offline
Old 05-25-2013, 12:07 PM   #2290
Daze57
Daze57's Avatar
are these clamps american made? if not - it figures --- if so - it figures
sorry folks - i am concernened about quality control
especially when it come to parts for these old trucks - we try to make somethin nice
but ''newer' parts wont let us
Daze57 is offline
Old 05-25-2013, 01:39 PM   #2291
lowdownstar
big guy
lowdownstar's Avatar
nice repair no body work needed !
Ray
lowdownstar is offline
Old 05-25-2013, 10:53 PM   #2292
Atommik
Atommik's Avatar
I bought my truck almost exactly 2 years ago...today I fired it up for the first time!!
http://www.youtube.com/watch?v=mf9fe...ature=youtu.be
Atommik is offline
Old 05-25-2013, 11:24 PM   #2293
Coach529
Coach529's Avatar
Drove it.....finally!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline
Old 05-26-2013, 12:54 AM   #2294
arturo7
arturo7's Avatar
Installed the front axle, assembled the rear.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 05-26-2013, 09:28 AM   #2295
mknittle
mknittle's Avatar
good news! that is one nice truck!
Mark
My GMC build.
mknittle is offline
Old 05-26-2013, 09:31 AM   #2296
Bubba54
Ray
Thanks, Thats what I always shoot for, but doesnt always come out that way. I just keep trying.
Bubba54 is offline
Old 05-26-2013, 09:35 AM   #2297
Bubba54
Some came from Eastwood some from Harbor Frieght. Quality is about the same, big difference is the price.
Bubba54 is offline
Old 05-26-2013, 09:38 AM   #2298
lowdownstar
big guy
well i had the best day, i spent some time in the morning block sanding my rear fender getting it ready for paint and then spent the night watching my oldest son get married to a perfect young lady who i think is an angel. great day....
Ray
Old 05-26-2013, 10:03 AM   #2299
mknittle
mknittle's Avatar
Ray
Congratulations Ray!
Mark
My GMC build.
mknittle is offline
Old 05-26-2013, 11:32 AM   #2300
dubie
dubie's Avatar
Sweet Jesus that turned out slick! How was the maiden voyage? What a sweet ride
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Closed Thread
