Old 10-26-2011, 06:53 PM   #2326
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread
hmmmm.....hadnt thought about that ! if you come up with idea for the hinge let me know !
67cheby is offline   Reply With Quote
Old 10-26-2011, 07:33 PM   #2327
68 TT
Still plays with trucks
68 TT's Avatar
I'm thinking an aluminum insert in the tail gate that fits over a Delrin sleeved pivot pin on the stock bed side bracket base with the stock outer portion removed. Shim the side brackets as needed to remove side to side slop once the tail gate is installed.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-26-2011, 09:07 PM   #2328
heymoe
heymoe's Avatar
Hey Cheby,
Going back to your dilemma with the tube steel. We have to do this all of the time at work. Do you have a metal fab table? We call it back bowing the piece to help keep it the steel from curling up like a banana. You might still be able to back bow it by clamping it down to the table and warm it up slowly.
I would most definitely clamp or weld it down to a table before welding the rest of it up. Have you ever used a product called Heat sink? Most of the welding shops have a form of this and it will help keep the piece cooler while working with it.
Hope all goes well!
My build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=371235
heymoe is offline   Reply With Quote
Old 10-27-2011, 09:37 AM   #2329
67cheby
67cheby
67cheby's Avatar
68TT....i like that idea !! Heymoe thanks i will check that out and yes it will be clamped down to try to get the bow out and then clamped down before welding anything else !!
Old 11-02-2011, 11:56 AM   #2330
67cheby
67cheby
67cheby's Avatar
pg 91 post 2262, thanks Nathan
Old 11-02-2011, 11:56 AM   #2331
67cheby
67cheby
67cheby's Avatar
well bought my 3rd set of metal to try this back brace thing again today !!
Old 11-02-2011, 12:01 PM   #2332
longbed67
longbed67's Avatar
I gotta give you props your not givin up on this one to do it another way!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 11-02-2011, 12:03 PM   #2333
67cheby
67cheby
67cheby's Avatar
its just a piece of metal...surely i can outsmart a piece of metal.....granted it is taking me a few jabs at it but somehow i am going to beat it !! LOL
Old 11-02-2011, 12:06 PM   #2334
watahyahknow
watahyahknow's Avatar
mwoah if you cant weld it maibe you can file it out of a solid 1 x 1 inch barstock
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-02-2011, 12:08 PM   #2335
67cheby
67cheby
67cheby's Avatar
hmmmmmm.....back up plan #4
Old 11-02-2011, 02:42 PM   #2336
69CST-V
69CST-V's Avatar
cheby,
Another idea is to just stitch weld it with a one inch weld or so every two to three inches then spot face weld between those on the front side. Grind all those welds smooth and use metal filler between the stitch welds and work it for a fully smooth look. That will keep the heat down and still be strong. Just an idea.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-02-2011, 02:48 PM   #2337
67cheby
67cheby
67cheby's Avatar
thanks i am open for any ideas..just left my friends fabrication shop , took over both of the ones that have built and that have warped on me and all of the new metal, we are going to work on it this weekend at his shop on a real heavy duty welding table where we can really clamp it down and he might even tig weld it to try to hold down on heat a little.......my fingers are crossed we will see what happens !!
Old 11-06-2011, 11:48 PM   #2338
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
I haven't finished reading thru your whole build yet, But I have to say your doing a very nice job! cool ideas, and attention to detail.
Subscribed!
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 11-06-2011, 11:49 PM   #2339
67cheby
67cheby
67cheby's Avatar
thanks man... fixing to start picking up on the progress again !!
Old 11-07-2011, 04:08 AM   #2340
71Sleeper
71Sleeper's Avatar
Well, how did the welding go this weekend? Were you successful?
71Sleeper is offline   Reply With Quote
Old 11-07-2011, 10:18 AM   #2341
67cheby
67cheby
67cheby's Avatar
weekend ended up to busy...going to try tonight !
Old 11-08-2011, 10:11 AM   #2342
67cheby
67cheby
67cheby's Avatar
well ....bed brace attempt #3....it still warped a little, but we are going to put it in his press and try to straighten it, it did warp much less !! LOL
Old 11-08-2011, 10:19 AM   #2343
raull
raull's Avatar
keep chopping at it , seems like you are almost there !!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 11-08-2011, 10:29 AM   #2344
longbed67
longbed67's Avatar
I think the saying goes... "So close, yet so far away" You'll get there eventually!!! lol I admire your persistence!
Adam
(608) 214-8706
Old 11-08-2011, 10:32 AM   #2345
67cheby
67cheby
67cheby's Avatar
i am just stubborn enough to keep fighting it....i will WIN !!
Old 11-08-2011, 11:14 AM   #2346
67cheby
67cheby
67cheby's Avatar
i just got a text from my friend Charles Mayhew and he sent a pic of my brace on the press and he said it is STRAIGHT once again....LOL , if nothing else we will beat it straight !!
Old 11-08-2011, 11:32 AM   #2347
67chevy1series
67chevy1series's Avatar
AMEN! keep at it mike!
67chevy1series is offline   Reply With Quote
Old 11-08-2011, 12:48 PM   #2348
big_al_71
big_al_71's Avatar
Persistance beats resistance all day long....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-08-2011, 12:51 PM   #2349
67cheby
67cheby
67cheby's Avatar
LOL....i just got to think ...surely i am smarter than a piece of metal, still not done yet ...but i got a couple good punches in , now to go ahead and take him to the mat..LOL
Old 11-08-2011, 01:21 PM   #2350
watahyahknow
dont put too mush heat intoo it when youre grinding down the welds it might warp again
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
