06-07-2013, 12:09 PM | #2351 |
Re: What Did You Do With Your Truck Today ?
Looking good !
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
06-07-2013, 07:43 PM | #2352 |
Few days ago ordered complete Porterbuilt set up for my 59. Got the first email today that some steering components are shipped. I dont come home from deployment for 2 more months its gonna be like Christmas when I get home. Cant wait to see the Porterbuilt stuff in person!!
Posted via Mobile Device |
06-07-2013, 11:17 PM | #2353 |
finished installing my windsheild with the deluxe trim, and started installing my doors (after getting the first one hung I realized I cant effectively adjust the door alone, will put that one off until i can get help.
06-07-2013, 11:30 PM | #2354 | |
PS: Thanks for serving. |
06-08-2013, 12:02 AM | #2355 |
I stopped by the truck (it lives at work, not home) and got the front calipers plumbed up, wheels bolted on & greased the freshly-assembled steering.
I also walked around the truck & threw out all the old parts boxes, misc. scraps, packaging etc and got the greasy rags into a single pile. Still have to plumb the rear brakes, find out what's dripping in the brake plumbing (!), bleed the system and attach intermediate shaft to column, then column to floor. Then the body work goes back on.Once that's all done, I'm leaving the truck alone till after I move this September. |
06-09-2013, 10:11 PM | #2356 |
I gave up on getting out the old kingpins and hired it out. I got the 57 back today and the steering is smooth, does not wander at 85. I think I trust it now to be the daily driver.
The spring shocks on the front were compressed and now the front suspension is tight. Maybe this is how the 57 drove when it was new? So far I have a straight axle, speedway disc brake conversion, sway bars, spring loaded shocks, and new kingpins all with a heavy 454ci. I must look at the front disc brake conversion (drum rears) as I step on the pedal it takes a long time to stop. I can pump the brakes and it stops faster. I changed to a 15" steering wheel and the steering is easier to control. |
06-10-2013, 12:43 AM | #2357 |
Thought about changing the oil but it got hot here and I hauled 6 people and the boat to the lake.
06-10-2013, 02:02 AM | #2358 |
Bought a 3 core radiator (designed for a chopped down '32 F!*#), a new flex plate and a bunch of chrome goodies for the truck today. Oh, and a drive line from Pickn'pull so I wouldn't have to pay to have the one I already had extended and balanced. Hard day for the bank account, but my shop will look like Christmas morning in about a week!
06-10-2013, 09:17 AM | #2359 |
Gotta love the burbs!
06-10-2013, 08:36 PM | #2360 |
Got off work early and trimmed the steering column down a bit, ground new 3/4 DD flats onto it & got the intermediate shaft installed. Then ground out & installed the floor plate. Still need to drill for grub screws to secure it, but when I turn the wheel the tires move. All thats left is one or two brake flares & hose mounting tabs, I'm done for the summer.
06-11-2013, 02:04 PM | #2361 |
Tim (dubie) - loving the look of the truck. That shop truck theme is a perfect theme.
Well my Thurs and Fri off from work turned into me taking Mon off also. Very busy weekend. Unfortunately no pictures right now, they are all on my camera. Wheels and tires mounted and bolted on Hood is on, but needs adjustment Headliner, insulator mat, and rubber mat are in Door glass in Door handles installed and locks keyed the same and installed Weatherstripping installed Wiring is 95% done This weekend I am building an exhaust and I swear I will drive this thing before Sunday at 7pm even if it is just out of the garage and back in.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
06-11-2013, 02:20 PM | #2362 |
Headed home to dump the tranny out of Big Bertha. Aparently the stock torque converter does not like the 454 and 18k pounds. Chuncks of the clutch plugged the cooler....twice. Made it home though. Tranny temp was at 298 when we checked it. So that ones a little fried. Headed out camping again this Friday. Lucky I got a spare tranny with 1000 miles on it. Now my buddy can use this one to build a better one. Should have it going again in a couple hours.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
06-11-2013, 02:25 PM | #2363 |
Worked on under dash wiring most of weekend .making sure I am not gonna torch the machine when I fire it up . Tying up all bundles and makin it neat . Then worked on my heater( yeah I know 112 here and I am messin with a heater) like
06-11-2013, 02:43 PM | #2364 |
we got damn near all of the wiring done, the cab is now carpeted and the seat has been upholstered and installed. The mini tubs have been welded and are ready to install and the aftermarket rad has been mounted. This week will consist of coolant line and fuel line plumbing, plugs, carb, wires, exhaust manifolds and then we'll look at bleeding the brakes and firing this ***** up
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
06-11-2013, 05:20 PM | #2365 |
06-11-2013, 06:31 PM | #2366 |
Check my build thread bud
06-12-2013, 10:21 AM | #2367 |
I got tired of the one step forward two steps back transmission dance and drug out my old Muncie M20. I spent most of Monday cleaning it between rain showers.
Yesterday I cleaned up a bell housing and started on the cross member. The idea is to make a cross member to fit a S10 T5 and with a bolt on adapter for the Muncie. That way I can swap in a Camaro/s10 T5 pretty easy later on. I want to get the frame done and painted in this summer. |
06-12-2013, 11:24 AM | #2368 |
Old tranny out and new one back in...only took 4 hours.....
06-12-2013, 11:31 AM | #2369 |
06-13-2013, 09:34 AM | #2370 |
The wife and kids wanting to go camping is most of the motivation.
06-15-2013, 04:37 PM | #2371 |
I made a new battery hold down. I bought an original style battery tie down but it won't go over the battery due to the extensions on the ends, so I used the rods that came with the set and a piece of aluminum angle sprayed with Rustoleum textured paint. At least it looks better than the plastic wrap-tie that I was using to hold the battery down.
06-15-2013, 05:34 PM | #2372 |
That looks great Russell, sometimes I wish I had left my battery in the engine compartment. Servicing the battery under the truck even with the drop down is a struggle
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
06-15-2013, 06:09 PM | #2373 |
Thanks D'ne. It does tidy up the firewall to move it, but I've had 1953 and 1956 Ford trucks with the battery under the floor (factory) and I prefer the under hood location.
06-16-2013, 12:52 AM | #2374 | |
I know you have back problems. My wife had surgery about a two months ago they installed a device that looks like a little leaf spring shackle between #s 5&5 vertebras. |
06-16-2013, 11:23 AM | #2375 | |
As for those "extensions" on the battery Russ? I just cut them off and used the stock hold down frame. Posted via Mobile Device |
