#2351 |
Re: What did you do to your truck today? Chapter II
Primed the underside of the bed while my bodyman was working over the rear fenders getting them ready for primer. Let dry a few hours and undercoated the underside of the bed. bodyman then laid down some high build DTM primer on the rear fenders, hood, grill, and cowl.
Came out real nice. Getting the bed stuff ready for color in a couple weeks.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#2352 |
Wow, I had to go back 5 pages to find this thread! Stop the slacking guys!
![]() I am behind: yesterday I put the last coat of paint on the newly derusted hood latch bracket. Today I paid for a Custom/10 emblem for my NOS front fender. I also called the media blaster, my parts are ready. OH! I had a look at my original cowling and it's really too badly rusted so I got the 1967 cowling down out of my dad's attic. If the hole for the antennae lines up with my original or the antenna fits it, I'll use it. |
#2353 |
finished putting together my side A/C vent speaker pods. Now to cut the dash. I am not looking forward to that. Measure 15 times and cut once will be my motto for this project. Also got the solid window with stainless installed. It looks so much better than the old slider without any stainless.
![]() 1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think Quadrajet 4 barrel 7043208, Th350 tranny, No A/C Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed. |
#2354 |
#2355 |
Those speakers look just awesome. Great job.
#2356 |
#2357 |
![]() Join Date: Feb 2009
Restoring under the bed while it's off. I "finished" getting the paint off the frame, though still have a little to go when the leaf springs, brakes, shocks, and exhaust come off, but it's close. Took about 8 hours with paint remover and lacquer thinner. Kind of a bear, but it's really not bad. Next weekend comes the axle and differential. After that it gets a bath and the real fun "phase two" begins.
Incidentally, this restoration business is a kind of a blast. Always something to make look new again.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-20-2015 at 10:20 PM. |
#2358 |
#2359 |
Replaced the old dash speaker with a replacement pair and installed the Retrosound Hermosa made for 67-72 GM Trucks
#2360 |
I replaced the rubber fuel line on my 400 sbc with 3/8" steel line instead. I have a late model serpentine setup so had to snake it between the timing cover and water pump which took a while to get the bends right. I still have a couple of short rubber connectors for the fuel filter but feel much safer without all that rubber touching the motor.
#2361 |
i had a blast yesterday and ended up with "some" clean parts that are ready for epoxy.
these dang latch&catches are kicking my butt. this is the forth time i blasted them and tried the eastwood metal blacking solution. each time they turn out like this. they look black and great right outa the solution but by the time they dry this is what i end up with. funny cause i've had good luck useing this stuff on other small parts. time too try something else on them.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#2362 | |
All I have done so far today has been to restart ERR on the hood latch and I wire wheeled the last of the rust off of the triangular fender-to-core support bracket. It's badly pitted but serviceable. |
#2363 |
I did a little more today.
I figured out the 1967 cowling I have isn't up to my liking to go onto my truck. :-( I also got all the rust off of the fender to core support bracket (it has lots of pits!) and coated it with NAPA Rust Treatment. This stuff is really just a primer so I'll paint it tomorrow. ![]() ![]() |
#2364 |
Took a wire wheel and stripper wheel to the bed floor, removing surface rust and dried glue/paint spills and preparing it for blasting. Gonna do the wheel wells tonight. Bed sides and back panel are already done, so I'm almost ready to hang plastic and start blasting.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#2365 |
New coat of paint on all parts
#2366 |
#2367 |
I lowered mean green and put some rallys I had on.
#2368 |
RAT1968 '68 Cab/'71 Parts
Played with the motorized bicycle today. It's going to be RAT's spare tire.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#2369 |
![]() Join Date: Sep 2003
I installed the newly rebuilt carburetor (7029214) that my wife surprised me with on Father's Day. It was from one of the professional quadrajet builders and I chose not to go with the show plating. Apparantly, she has been in contact with him for awhile trying to answer questions. She told me what she was up to and that I had to speak with him. When she told me I was shocked. He said he would have it finished by father's day.
#2370 |
On those door latches , all you needs do is make up a dilute Phosphoric Acid & water solution , when you're finished de rusting thrm , rinse them off and quickly dip them into the Phosphorus solution , it will *instantly* prevent the flash rusting you're struggling with now .
DO NOT use undiluted Phosphoric acid ! you can dip your fingers into it yes but it's not good for the steel . NO alloy / pot metal parts either ! . Brass , like completely rusted closed carby jets , will come out looking new as will old rusty chrome bumper bolts but pot metal or alloy things will be ruined . The best part is : you can strain and jug this solution for years of re use , making it very co$t effective . Nice to see all the hard works going on here , Spring must have sprung although heavy rain storms have dogged us all the way across America . I am surprised to see many folks simply pull off the road and stop , emergency flashers going instead of simply slowing down to safe speeds . The big rigs often flash past us in less than 1/4 mile visibility going 85 + MPH . 71CHEVYSHORTBED402 : have you tried a wire wheel for rust removal ? I go through them like crazy (buy by the box full) and have worn out $25 Harbor Freight drill motors but I like the resulting clean bare metal and no chemical burns . The (in)famous Rochester Qudrajet carby is in fact a sterling carby , you'll need to upgrade the fuel inlet and jet well plugs so they don't weep/seep/leak and cause engine fires but once repaired and properly set up they never ever go out of adjustment and provide good drivability plus power when you stamp the foot feed and open up the secondaries .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#2371 |
![]() Join Date: May 2012
#2372 |
Remove the little HO305, now I have a lot of cleaning to do for the other engine. FUN FUN FUN!!!
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#2373 |
Finally got around to dragging the original bench to my '72 out of the back yard, into the garage, and onto a stand so I could remove all the ancient vinyl and foam. The driver side bolts attaching the back to the base are rusted, so I'll have to drill them out tonight.
A bit of time with the wire wheel on the drill motor, maybe a quick blast with the media blaster when I do the bed this weekend, spray with some NAPA anti-rust black, then into storage until I get to the point of re-upholstering it.
#2374 |
![]() Join Date: May 2013
Dropped Ol' Crusty off at the muffler shop for new dual pipes and Flowmasters. Should be done in a few hours. Excited.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#2375 |
Mounted my freshly painted right side door and fender!! Finally!!
