#2401 |
Re: What did you do to your truck today!
#2402 | |
#2403 |
began cleaning the underside. Grease Lightening works good!!
#2404 |
walked in the shop and looked at it. then walked out shaking my head at the heat LOL
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#2405 |
Spent last night working some more on tuning the engine. I pulled the carb, due to a small vaccum leak I was having, and removed the old gasket materal. Put on a sealing plate from Holley, should keep it from doing that again. Also plumbed in a PCV valve, as I had not been running one before. Pulled the HEI and sut a advance curve kit in it, and slid it back into the motor. Just have to bolt the carb back down, and set my timing again, and I should be good to go. I was tired if it running so rich and fouling plugs, and you could just smell the excess gas coming out of the tailpipes. Should get a little more get up and go, little better mpg, and no more smelly exhaust!
#2406 |
![]() Join Date: Feb 2008
Several weeks ago as summer was approaching, I decided to get my factory ac up and running on my 72 blue Cheyenne Super daily driver. I noticed that on one of the hoses coming off the back of the compressor, it attached to the hose fitting at the "heater box" area with just a standard hose clamp. My first thought was there was no way that it was holding pressure so i decided to remove the hose and get it rebuilt correctly. While waiting on the hose, I decided to go ahead and remove the compressor, clean it up, re-paint it. Well, you can't put a cleaned up compressor on old nasty brackets so they came off next. This exposed an old rubber fuel line from the fuel pump that had bothered me for years so I rebuilt it with a hard line as well. As I am looking at the front of the engine now partly exposed, I was reminded of the on going cam problems that have haunted this truck since I got it about 4 years ago. The previous owner had re-built the motor and made a number of errors that needed correcting including the cam selection. I decided if I was ever going to get this motor right, I needed to replace it. I selected the Comp Cams 268H based on my freind JohnO's experience. So, I pulled everything apart and re-finished it in Chevy Orange. JohnO helped me put all back together and I must say, it runs better than I could of expected. Other than the waterspots in the pictures, it also looks like it now runs!
#2407 |
I replaced the plain side markers with deluxe side markers that I got for my birthday last night.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
#2408 |
JJanzen
That engine looks clean, I especially like the fuel line. Dano
![]() ![]() It ain't yours, if you didn't build it! |
#2409 |
Sheetmetal Psycho
Parked the '71 next to the house so I can see it every time I walk through the kitchen
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#2410 |
Thanks Dano. Now I just need to replace from the fuel pump to the tank. For some reason, the PO stuck it on top of the frame!
#2411 |
![]() Join Date: Apr 2010
Or is the question "what did your truck do for you today"? It took me for a ride.
![]() Last edited by mrbwtie; 06-22-2011 at 08:35 PM. |
#2412 |
RAT1968 '68 Cab/'71 Parts
Fine looking truck in your avatar, mbt. Tubbed? You have air in that sweetheart?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#2413 |
#2414 | |
![]() Join Date: Dec 2006
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 Last edited by Bennett68C10; 06-22-2011 at 09:57 PM. |
#2415 |
Went to the Pick-n-pull on my lunch today and scored a new Power Steering Box for $30. Degreased it and shot some paint on it when I got home. I will install it this weekend and see if it is gonna leak like my old one. It seems evertime I fix one leak I get two more. Blew a line on my front brake and it looks like my PS pump may be leaking now. ARGGGHH!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 06-22-2011 at 10:28 PM. |
#2416 |
Went and paid the Invoice, looked it over and the Wifes taking me to trhe shop to bring it home tomorrow!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#2417 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice looking ride ya got there..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#2418 |
An electric fuel pump will cure your vapor lock. put the pump as close to the tank as you can. Fuel under pressure raises the boiling point of the fuel. I put an electric fuel pump on my truck in Arizona never vapor locked again.
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#2419 |
Making progress on the engine compartment. Still have a ways to go, but we're getting there.
The top photos are what I started with.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#2420 |
Actually picked it up from the Shop after having the Exhaust Tucked up into the Frame, New Horns put on, and a new AC Relay put in.
#2421 |
Finished up putting the stars & stripes treatment on my tach.
Brad handshoe |
#2422 |
English Chevy Owner
That tach is cool! I finally managed to get the seized bolt out of the firewall main wiring harness plug so i can finally get on with rewiring the engine bay.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#2423 |
Redefining LowBudget
we need more pics of this!!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#2424 |
Loosened the bolts holding the seat so I can remove the water soaked carpet. Plan to clean and prime the floor prior to installing a LMC rubber mat.
#2425 |
worked on the bed ' all weekend . thinking about what a waste of time
