11-01-2014, 03:18 AM | #2426 |
Re: PO has me PO'd
Thanks for posting the wire wrap site, got it saved.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-01-2014, 12:58 PM | #2427 |
Re: PO has me PO'd
You re welcome, just thought i d pass along some interesting product data...
Sorry to read about some of your pitfalls in your build, but like the rest of us, it were easy, everyone would be doing it Sitting here on a rainy, chilly, saturday....heat cranked up. Man, i love my workshop!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-01-2014, 09:16 PM | #2428 |
Re: PO has me PO'd
Started to work on all my 12V switched (pink) wires to the OEM distribution block, when i was done i wanted it covered so no one hits it with a tool and shorts it out. So, i used a old regulater and took out the guts, just ground down the rivets, and it all popped out
[url=https://www.flickr.com/photos/97391199@N06/15684395921/]20141101_134004[/ 20141101_205000 by [url=https://
11-01-2014, 09:22 PM | #2429 |
Re: PO has me PO'd
With old cover, some day i ll paint it
20141101_205445 Another step closer...... Found out from FAST what the step1 step2 and step retard wires are for....something to do with the ignition while sitting at the christmas tree, sorta like lineloc, i was told. Since the only trees i will be seeing are pine, oak, maple, and a dogwood sometimes, i ve tucked them outa sight
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-01-2014 at 09:33 PM. |
11-02-2014, 09:05 PM | #2430 |
Its lookin' like a Blazer!
Re: PO has me PO'd
Just got through flippin' through a few of your pages, Jim I gotta say that is a lot of wires, you are a better man than me. Its lookin' good man.
11-03-2014, 09:34 PM | #2431 | |
Re: PO has me PO'd
Main issues now, are dist. wiring and crank trigger, gotta find 50 degrees BTDC to set both them up
11-11-2014, 11:44 AM | #2432 |
Re: PO has me PO'd
OK, my brain hurts from the electrical system.....need a break, so i m going to work on the coil mounts, the OEM brackets are getting in the way every time i turn to the next part of the build. So, i m building my own sooner than latter, but i want to retain OEM chase
Pretty simple....1/4-20 set screws, drilled and tapped into the vertical aluminum piece, whichis drilled and tapped to the hoizontal mount on the v/c, with spacers on the coils to maintain proper offset. I ve also rotated the coil 90 degrees Coil mount is backwards, for clarity. But actually this is for number 7 cylinder 20141109_114511 20141109_114344 by james_jaros, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-11-2014 at 11:53 AM. |
11-11-2014, 04:06 PM | #2433 |
Re: PO has me PO'd
Pretty slick.
11-12-2014, 12:39 PM | #2434 |
Re: PO has me PO'd
Thanks Tully, the vertical piece is held on with 6-32's, not really trusting that. So, after i take a welding class i ll tig a fillet along that seam
11-20-2014, 02:22 PM | #2435 |
Re: PO has me PO'd
Final variation of CNP using some of the OEM bracket and electrical chase. I can now go back and use my PCV and oil fill cap
20141120_125504
11-21-2014, 10:42 AM | #2436 |
2WD Jimmy
Re: PO has me PO'd
Your workbench looks like mine. lol
11-21-2014, 12:03 PM | #2437 |
Re: PO has me PO'd
Yeah Tom, neatness takes time, and that is in short supply i guess we d lose the work bench of the month contest. Funny thing is, i know where everything is located....
Your truck is amazing, lots of nice work there
11-30-2014, 01:00 PM | #2438 |
Re: PO has me PO'd
Had a couple hours to play with my truck this morning.....wanted to re-loom and re-pin coil connector, went pretty smooth! Now to work on passenger side
Trying to firgure out if i want to anodize or polish coil mounts 20141130_114941 by [url=https:
12-20-2014, 07:14 PM | #2439 |
Re: PO has me PO'd
Two steps forward, one step back.....poor planning on my part. BFH or speed bump?
Hard to tell from the pic., but, the snout of the coil is an 1/8" from firewall. Well, noone ever said it would be easy 20141220_175711 At least i m past the crank trigger, now on to the distrib. or at least what s left of it. Just using it for cam referance and to drive my oil pump 20141220_175839
12-20-2014, 07:43 PM | #2440 |
Equal opportunity joke ofender
Re: PO has me PO'd
Jim,
Couldn't you slide the coil pack towards the radiator on the valve cover rail to clear the firewall or would that put the coil packs to close together? Seeing what you are going thru is why when it comes time for my motor I will just stick with rebuilding the 307 lol. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-20-2014, 08:04 PM | #2441 | |
Re: PO has me PO'd
I hate to whack into the body work at firewall, but i don t think i m left any recourse I m still thinking....but, i m leaning towards a speed bump BTW, how are you feeling?
12-20-2014, 08:32 PM | #2442 |
Re: PO has me PO'd
Its kinda hard to tell from the pics and all but maybe leave it in the same location but offset towards the intake? Don't mind me though just bored and thinking out loud even if not clearly
I am doing somewhat better. thanks for asking. I have my business moved back home now so that takes up a lot of the shop space but I am still collecting parts. Richard
12-20-2014, 11:42 PM | #2443 | |
Re: PO has me PO'd
Glad things are looking up Today was the 1st day of retirement, gotta luv an afternoon nap
12-21-2014, 01:24 AM | #2444 |
Re: PO has me PO'd
Looking good Jim. Congratulations on your retirement!
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
12-21-2014, 08:33 AM | #2445 |
Re: PO has me PO'd
Thanks JJ, your paint came out awesome, i think greys and silvers work the best on our trucks. Not to bad, only a month in paint prison
Back in the 70 s my Dad had a gun metal Chevy, really liked it then, still do When you re retired, every day is a Saturday.
12-22-2014, 12:47 PM | #2446 |
Re: PO has me PO'd
With a combination of Richards idea of moving towards intake 1" and rotating to 80 degrees rear coil pack is mounted
Nice to have motorheads looking over your shoulder 20141222_114019 Used a holesaw on the drill press to bore a hole to mount K&N breather....careful with holesaws, they tend to grow from the designated size. Make a test touch on the aluminum and measure, this will be your final bore size
12-22-2014, 01:17 PM | #2447 |
Re: PO has me PO'd
Looks like it worked out pretty good.
Oh and congrats again on the retirement
12-22-2014, 03:44 PM | #2448 |
Re: PO has me PO'd
Are you running a cam trigger too, or is this a wasted spark setup?
12-22-2014, 05:54 PM | #2449 | |
Re: PO has me PO'd
[quote=richard2717;6967328]Looks like it worked out pretty good.
Yeah Richard, sometimes you get to eat the bear Oh and congrats again on the retirement[/QUOTE Thanks, first day of not reporting to work, spent the day buying presents for the wifey, grandson....plus one from santa, BRIDGEPORT Quote:
I m using a FAST dual sync distr., but, i m only using the distr. to get a cam referance to my XIM, which had to be repinned for the crank trigger
12-22-2014, 05:56 PM | #2450 | |
Re: PO has me PO'd
I m using a FAST dual sync distr., but, i m only using the distr. to get a cam referance to my XIM, which had to be repinned for the crank trigger You guys were soooooo close to getting the prize for 200,000 views
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-22-2014 at 06:04 PM. |
