Closed Thread
Old 06-26-2011, 03:56 PM   #2426
BMERDOC
BMERDOC's Avatar
Re: What did you do to your truck today!
Added JC Whit "soundmaster" chambered muffler and a shiny turn down. $24 muffler, $8 turndown. All very temporary until I can get it to work and start phase two.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 06-26-2011, 04:25 PM   #2427
Bennett68C10
Bennett68C10's Avatar
Got my 700r4 cleaned up and painted along with my transmission pan. Also put in my new chrome oil dipstick and spark plug wire looms.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 06-26-2011, 06:28 PM   #2428
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Finally reassembled the TH400 today after it's rebuild....oh! & fixed the oil leak on the pan....getting closer to being back on the road.
^^Nice paint job Bennett^^
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline
Old 06-26-2011, 06:33 PM   #2429
vectorit
What?
vectorit's Avatar
Pulled all three benches out, and re carpeted the floor front to back.
Installed my last piece of body trim - a little 7" piece that I have been hunting for for many years. (Thanks MAR-K!)
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-27-2011, 08:02 AM   #2430
Bishop73
Bishop73's Avatar
Installed a set of LMC 3 point seatbelts and a new center lap belt. Well, that was actually Friday but I haven't been on to post it.
Bishop73 is offline
Old 06-27-2011, 07:44 PM   #2431
GMC69
GMC69's Avatar
Went and picked up and installed a new fuel sending unit. Now I can actually tell how much gas I have, lol.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline
Old 06-27-2011, 08:31 PM   #2432
mdaven@aol.com
Took out the seat, removed the carpet, started cleaning the cab floor in preparation for the new rubber mat. Need to patch a couple rust spots first, then new door seals, etc. Does it ever end?????
mdaven@aol.com is offline
Old 06-28-2011, 01:20 AM   #2433
ItsRandy
ItsRandy's Avatar
Replaced a rocker panel, lower "A" pillar and inner cowl panel.
ItsRandy is offline
Old 06-28-2011, 01:47 AM   #2434
Dano69c10
Dano69c10's Avatar
Put a new carb on th '70 last week. Tonite "threw a tune-up" on the '70. Now I need to replace the front seal on the tranny, it's leakin' like crazy.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 06-28-2011, 09:53 AM   #2435
Brock
upgrading to an older model
Brock's Avatar
I actually DROVE it...first time its moved under its own power in the 4 years since I've had it...who knows how long before that.
68 stepside, short-box, multi-colored (for now)
Brock is offline
Old 06-28-2011, 11:59 AM   #2436
dougminton
dougminton's Avatar
I drove it to work on drag radials.
In the rain, What a ride that was a couple of times.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline
Old 06-28-2011, 01:22 PM   #2437
Low & Slow
Figuring out why my front brake res was empty lastnight after discovering no brakes pulling out of the driveway.
Low & Slow is offline
Old 06-28-2011, 07:38 PM   #2438
67Slider
67Slider's Avatar
Installed a new power steering gear box, trimed and painted the inner fender well, tightened up the leaky tranny pan, looked at the blown out brake line and wondered if I would ever get another one(been waiting a week to get two from Autozone) and pressure tested the new gear box. So far no leaks. Time will tell tho.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-28-2011, 08:54 PM   #2439
GMC69
GMC69's Avatar
I load tested the battery on the truck after it didn't want to start. Compared it to the battery in my Buick SUV and discovered that my Buick needs a new battery.
Maybe the starter in the Chevy has a bad ground causing it to not want to start. I'll have to do some digging. Or I may have some kind of parasitic draw killing my battery.
Mike
2019 Silvedrado 4x4
GMC69 is offline
Old 06-29-2011, 01:49 AM   #2440
Tomahawk30
Tomahawk30's Avatar
Did a little work on the father / son project (my 14 year old's first rig). Pulled the recovered bench seat and visors from the donor cab. Cleaned them all up and sprayed a couple fresh coats of vinyl dye. Started going through the ductwork. Repaired some questionable headlight wiring. Then showed my son how to shift through the gears in the 4 speed. That was the best part!
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 06-30-2011, 06:52 PM   #2441
wwotr
wwotr's Avatar
Well I went by "The Shop" (my 2nd home), to just B.S. with the Owner and his Son.
The Conversation got around to the Tired Engine in my 72 GMC,
and how I had bought a GM Crate Engine back in 2004 (ZZ383/425),
for my 67 C-10, and that I paid $5600.00 for it at the Time.
Well that type of Income is in the past, so we got around to talking about engines, and I told him if anyone ever came into the shop with a "Well Worn" 350, that was in better condition than MINE, to give me a call.
Anything is better than my 185 HP 350. So he says that he's got a 32 Chevy Delivery Sedan, that has a stroked 350/383 from the P.O.
He says it's approx. 350-390 HP.
He said that I would have 1st Dibs, when he puts his NEW engine into it!!!
This Guy not only has great Customer Service, but treats me like part of the Family too!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 06-30-2011, 06:56 PM   #2442
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
thats so cool my fab man shop is the same way the money part is not the most important part of the build ,but to make sure im happy with the build and his family works with him and i feel part of that family too
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline
Old 06-30-2011, 09:19 PM   #2443
Rob H.
Rob H.'s Avatar
Hauled another one home!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 06-30-2011, 09:48 PM   #2444
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Gotta admit I only walked by mine today..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-02-2011, 10:28 AM   #2445
iceship
Drop done needs ...... all fliped out
Befor
After
iceship is offline
Old 07-02-2011, 11:02 AM   #2446
colin_havens
colin_havens's Avatar
Took mine to a local cruise in last night, and hung out with some friends and looked at a few hotrods. First time I have really drove it since I recurved the distributor and changed the timing, and jetted the carb. It runs better than it ever has, and no more extremely stinky exhaust. Gonna go to a show tomorrow too, and enjoy cruisin in the 67 as much as possible this weekend.
colin_havens is offline
Old 07-02-2011, 11:17 AM   #2447
Bennett68C10
Installed my Converter Lockup Wiring kit from TCI, installed my tranny pan and my Milodon Dipstick and swapped my 700r4 into the frame.
Keith
66 Suburban
IG: bennett68c10
Old 07-02-2011, 02:16 PM   #2448
FRENCHBLUE72
PROJECT 7DEUCE
I bought some door poppers to finish off the shaved door handle job..
MEMBER #6377
Project "7DEUCE"
Old 07-02-2011, 02:26 PM   #2449
Keller
Keller's Avatar
Installed a TransGo Shift kit into my turbo 350
Now my truck does this!
1972 C10 Longbed 350/350
Keller is offline
Old 07-02-2011, 03:32 PM   #2450
BMERDOC
BMERDOC's Avatar
Cleaned and painted two of my temporary wagon wheels Rustoleum Dark Bronze and mounted the tires (255/60 F, 255/70 R). My co worker still has the other two rims. Just wanted to see what it looks like. Man, its gotta be lowered!!
Nick Carter
BMERDOC is offline
Closed Thread
