Closed Thread
Old 07-03-2011, 12:43 AM   #2451
ItsRandy
ItsRandy's Avatar
Re: What did you do to your truck today!
Applied a few coats of bed liner to the underside of my cab. Started the body work. The body work would be easier if...I had a clue about what I am doing!
ItsRandy is offline
Old 07-03-2011, 02:28 PM   #2452
redmonster
redmonster's Avatar
drove it to the store for a gas fill up
WITNESS
Dont be like me be better than me
redmonster is offline
Old 07-03-2011, 08:04 PM   #2453
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Knocked off some bondo and sand sand sand.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-03-2011, 08:14 PM   #2454
wwotr
wwotr's Avatar
I changed my Front "Indicator/Running Lights" over to LED.
Reverse Lights are next week.
Then besides the Headlights, every light on my Truck will be LED.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 07-03-2011, 10:16 PM   #2455
2500HD
2500HD's Avatar
i drove mine to the golf course...... left the keys in it on accident. i wasnt that worried about it. I live in a really nice area. I was just glad i didnt loose the keys on the course. I noticed they were not where i normally put them on the 12th hole.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline
Old 07-03-2011, 10:20 PM   #2456
BMERDOC
BMERDOC's Avatar
Stared at it through the front window of my house wondering if or when I'm gonna get this titling snafu remedied with DMV!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 07-04-2011, 04:36 PM   #2457
AustinScott
AustinScott's Avatar
Drove to the Home Depot today to get some replacement sprinklers...
Just so happen to park right next to a pretty clean Black 69-72 truck.
Anyone here own this pretty sweet truck, took a sneak peak under the truck and noticed it had some Bright Red cherry bombs welded up under there.
Location Home Depot off 1431 in Cedar Park TX
AustinScott is offline
Old 07-04-2011, 04:59 PM   #2458
bosco200
bosco200's Avatar
Lubed my speedo cable....no more bouncy bouncy!
bosco200 is offline
Old 07-04-2011, 05:01 PM   #2459
mdaven@aol.com
Installed my door mirrors, sprayed bedliner on floorboard, installed a LMC rubber floor mat. Slowly making progress in this Texas heat.
mdaven@aol.com is offline
Old 07-04-2011, 08:02 PM   #2460
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Got my new lug nuts on the new wheels. Started to clean it out. Chasing down an electrical problem. Hope to have her back on the road in a week or so.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline
Old 07-04-2011, 08:43 PM   #2461
vectorit
What?
vectorit's Avatar
Installed my OEM AM radio and speaker "system" in 100+ degree heat with high humidity, and bolted down my front seat onto new carpet and sound deadening.
Radio doesn't work, and I am hot and miserable...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-04-2011, 11:51 PM   #2462
ItsRandy
ItsRandy's Avatar
Mixed more bondo...made more dust. I wish they would have called this body fun, not body work!
ItsRandy is offline
Old 07-05-2011, 08:20 AM   #2463
willys72fleetside
willys72fleetside's Avatar
Sanded the bed sides, now there ready for primer. Trying to get it painted before winter. I can only hope and pray
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 07-05-2011, 09:01 AM   #2464
ges55
BLACK SATIN
ges55's Avatar
I was driving in the 3/4 ton to pick up a sink & vanity yesterday & I noticed that the gas gauge was only less than a 1/4 tank. I had over 1/2 a tank the day before. I got home & found gasoline on the white rock where I park it. So I crawled under & found that the rubber gas line from the tank was kaput. Replaced & all is good except for losing about $20 worth of gas. At least it was an easy fix. I love easy fixes. Oh yeah, I also put windshield sealer up on the driver's side upper corner where I found that it was leaking the other day when I was driving on the highway in the rain. I don't think I had done that much with this truck, because I hadn't noticed it before.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline
Old 07-09-2011, 07:08 PM   #2465
67Slider
67Slider's Avatar
Installed a headlight relay upgrade from Classic today. Only cost me $30 bucks shipped. Installed simply but I had to put wiring loom over the whole thing. The yellow wrap they put on it was nasty! I am looking forward to pulling her out of the garage tonight to see if the lights are much brighter. Also installed my E-brake cover. About as much as I want to do in the 95 degree heat out here.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 07-09-2011, 07:28 PM   #2466
bruin_d
bruin_d's Avatar
Smoothed my firewall today.
bruin_d is offline
Old 07-09-2011, 07:30 PM   #2467
vectorit
What?
vectorit's Avatar
Still prepping for tomorrows Brothers truck show.
So far today, wash, wax, vacuum, and wash windows.
getting ready to detail, just as soon as the heat settles down outside.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-09-2011, 08:26 PM   #2468
GMC69
GMC69's Avatar
Brought the truck to the first car show since I've owned it. Since I've only owned it for about 1.5 months. Cruise Nights don't count.
I REALLY need to buy some license plate frames with the year on them. #1 question I get asked is the year, driving or stopped. Had 2 people just today as hat year it was as they were driving next to me.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline
Old 07-09-2011, 10:27 PM   #2469
project 67 sub
project 67 sub's Avatar
same as Vectorit, prepping for the brothers show tomorrow. and through a quick fresh coat of paint on the rims to make them look better, and not like crap. will be cleaning the windows etc. here in a little bit
project 67 sub is offline
Old 07-09-2011, 10:30 PM   #2470
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Got the new Sanden compressor in the GMC, going to the AC shop monday....Everything is ready now.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline
Old 07-10-2011, 12:40 AM   #2471
ItsRandy
ItsRandy's Avatar
Mix bondo, sand bondo, make dust, repeat as necessary. In other words I continued doing the body work. I am sure I will need therapy after this.
ItsRandy is offline
Old 07-10-2011, 12:54 AM   #2472
Bull72
Bull72's Avatar
Just wished I had more time on the weekends to complete the rebuild of my engine =)
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline
Old 07-10-2011, 01:21 AM   #2473
bc gman
71 bb longhorn
Started to put the bedwood back onto the truck ( what a pain in the ass ) I must of made 200 trips up and down trying to set everything another set of hands would of made it much easier and then I noticed that i am one small bed bolt and one large bed bolt too short.
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline
Old 07-10-2011, 02:43 AM   #2474
profe56
sway bar installed
wiring cables for my electric seats
wiring cables to tranny shifter in order to make start the engine only on P and N
new driver rear brake cable
install hidden knock switch
all in the last three days.
I'm on the way to polish the rims
profe56 is offline
Old 07-10-2011, 08:46 AM   #2475
FRENCHBLUE72
PROJECT 7DEUCE
I am also in the mode right now im sure my neighbors hate me..
MEMBER #6377
Project "7DEUCE"
Closed Thread
