Old 11-22-2013, 11:11 PM   #1
aotte1
1965, L6 292 Engine Power Steering Pump Set-Up
Have reviewed and reviewed posts for which years you can use to add an original looking power steering pump set-up to a 1965 292 engine. This is a question not an answer. Is it correct to say the brackets, pulleys, pump, etc. need to be from a 1973 or older 292 engine only?
This is my take from many post such as those by "71 SWB 4X4" and others.
Thank you for your patience as I know their have been many, many posts on this subject.
There are reported interference issues with using PS from 1974, and newer 292 on the older engines.
Les
aotte1 is offline   Reply With Quote
Old 11-23-2013, 11:34 AM   #2
sigshooter
sigshooter's Avatar
Re: 1965, L6 292 Engine Power Steering Pump Set-Up
Here was my original 292 setup that I just sold
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 11-23-2013, 11:36 AM   #3
sigshooter
sigshooter's Avatar
More
1966 Short stepside
1964 long bed
Old 11-23-2013, 11:38 AM   #4
60-66
60-66's Avatar
Heres a 1963 292 with PS and AIR . Need to check part numbers on brackets, not sure what years are the same.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-23-2013, 11:57 AM   #5
60-66
60-66's Avatar
OK, Parts book is stating 1963-1971 on the six cylinder main bracket 3877430 then 63-71 support bracket 3891598. It just states 6 cylinder, not clearly 292
67-72 292 bracket 3914992 Again not clear but heres the pages from the parts book.
Old 11-23-2013, 12:02 PM   #6
60-66
60-66's Avatar
http://www.ebay.com/itm/Chevy-6-Cyli...r#ht_42wt_1363
Old 11-23-2013, 02:01 PM   #7
factorystock
factorystock's Avatar
Here is a pre 1973 292 setup that was on ebay a while back. Pay particular attention to alternator, water pump and crankshaft pulleys used for proper belt alignment.
factorystock is offline   Reply With Quote
Old 11-23-2013, 02:03 PM   #8
sigshooter
sigshooter's Avatar
That looks like the exact setup I posted pics of still installed on the engine.
1966 Short stepside
1964 long bed
Old 11-23-2013, 02:15 PM   #9
60-66
60-66's Avatar
Sig, your setup is from the 67-72 vintage, not saying at all it wont work, but I can see the inner fenders etc. Great pictures and info Sig.
Im curious now about the correct or originals for 63-66. The pulley on my setup is odd the way it sticks out but I have another factory 63 292 setup with the same pulley . I have more brackets I need to get out and compare.
Old 11-23-2013, 02:23 PM   #10
sigshooter
sigshooter's Avatar
Smile Re: 1965, L6 292 Engine Power Steering Pump Set-Up
Mine was off a 1970, I saw the difference in the two of ours.
It was period correct "looking", meaning it was not custom built and had the correct style pump and cast pulleys.
If someone was wanting power and just to look correct I think the 67-72 type would pass... These are rare and few would have ever seen one.
But no for the purist there are differences.
Great thread going for those who have a 292 and want power steering, lots of good info.
1966 Short stepside
1964 long bed
Old 11-23-2013, 02:27 PM   #11
sigshooter
sigshooter's Avatar
Is that brake booster in your pics correct? Did they not use the wedge adapter in 63? I have seen that vertical mounting before but only on cars?
Anyone else have a 60-66 with the booster mounted this way?
1966 Short stepside
1964 long bed
Old 11-23-2013, 02:38 PM   #12
60-66
60-66's Avatar
Its actually 1963 ONLY . 1964 1965 1966 used the aluminum wedge. Heres an NOS 1963 Brake kit.
Old 11-23-2013, 03:24 PM   #13
aotte1
More great information, thanks. Looks like I have the crank, water pump, and alternator pulleys on my 65' 292 engine already that I need to add power assist steering.
Now I need the power steering brackets, pump and pump pulley. I am going to try and and get the original pump pulley if I can find one.
Below are pics of my pulleys. Have not figured out tablet to let me post more then one image at a time.
Old 11-23-2013, 03:26 PM   #14
aotte1
Another pulley pic
Old 11-23-2013, 03:27 PM   #15
aotte1
More pulley pics
Old 11-23-2013, 03:27 PM   #16
aotte1
Alt pulley
Old 11-23-2013, 03:28 PM   #17
aotte1
One more
Old 11-23-2013, 03:34 PM   #18
aotte1
Not sure what that white is around water pump pulley???
Old 11-23-2013, 03:35 PM   #19
aotte1
Need to push upload button!!!
Old 11-23-2013, 03:39 PM   #20
aotte1
Last pic of 1965 292. Will do more research and get info on engine date.
Agree great info.
Les
Old 11-23-2013, 04:22 PM   #21
60-66
60-66's Avatar
The PS pulley number 3906398 on your pump posted Factorystock is listed as 1967-1972 292 only. The 1963-1966 292 only ps pulley is 3894044. This is only for reference, it is not criticism . Just interesting to learn and research.
Old 11-23-2013, 08:04 PM   #22
aotte1
footnote/reference: to my above pics, the alternator is a newer style replacement.
Les
Old 11-24-2013, 10:07 AM   #23
60-66
60-66's Avatar
Les, check the way that alternator is mounted, I think its supposed to be a little further forward to line both grooves of the pulley in line with the crank pulley. It looks likew they added a nut or something to space the adjuster bracket.
Old 11-24-2013, 10:16 AM   #24
60-66
60-66's Avatar
These are the two main brackets for power steering on all 63-66 trucks 230 250 and 292. The difference with a 63-66 292 is the pumps pulley. These same brackets were used on all passenger car sixes also, Camaro Nova Chevelle and Impala and were in use on 230-250 trucks till 1970 according to the parts books.
This is a 1969 250 six C10 I have out back with the same brackets but different pulley. Again these are not correct for 67 up 292 but are correct for 63-66 292.
Old 11-24-2013, 08:01 PM   #25
aotte1
60-66
You are right they did add a nut so that PS pulley is offset, will remove tomorrow.
Thanks for clearing up the information on the PS pump brackets. It is a great help!
