10-14-2017, 03:21 PM | #701 |
Re: 1991 V3500 Project Heavy Hauler
It’s that time of year where we are scrambling around here to finish work projects, finish home projects, finish truck projects because the white stuff is coming. Grabbed a mini ex and helped my father in law do some rock work around his place. They live up in the hills so getting a loaded equipment trailer then a loaded dump trailer up there wasn’t boring.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
10-14-2017, 03:25 PM | #702 |
I had to put the hubs in to get the load of gravel up the driveway and figured what the heck I’ll put it in low to make it easier on the truck. No go. Power to the front axle only. Tcase works as advertised besides this one issue. Do I have a shift rod out of adjustment or something more sinister? I dug a hell of a home in their driveway with my front left tire...
And we did not beat the snow...
10-15-2017, 12:40 PM | #703 |
definitely sounds like a shift rod misadjustment
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
10-17-2017, 03:48 AM | #704 |
I’ll have to pick your brain a little j-rod, when I get to a stopping point. Butts and elbows right now trying to get all the crap put away and plow truck ready for snow. Oh and it’s snowing! Thanks man, talk to you shortly.
10-17-2017, 09:32 AM | #705 |
Sounds good man, shoot me a text when you get a chance. Have fun with the termination dust.
10-24-2017, 12:53 AM | #706 |
Great truck Marcus, what brand/application are your side steps for? I've been searching for some for mine. I apologize in advance if you already if you already posted this. I'm only to your 454 rebuild section, saw you were online and thought I'd ask.
10-24-2017, 12:58 AM | #707 |
Appreciate it. No worries at all. N-Fab makes the steps. They say for a 2500HD but I forgive them since they actually make some steps for our trucks. Also are available for short and long bed regular cabs and sunurbans I think.
https://www.n-fab.com/products/sfID1...productID/1000
10-24-2017, 01:14 AM | #708 |
Thanks, found them. I tried searching that brand once even. Looks like I can save almost $50 ordering them through summit though.
10-24-2017, 01:36 AM | #709 | |
I know that the shafts for a twin stick usually have some of the detents machined or ground out. Front axle only is a strange one for sure. I would like to hear what you find. The truck looks awesome as usual and its great to see her putting in the work as intended!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-24-2017, 03:13 AM | #710 |
Thanks Chris. I’ll keep you posted on the tcase. Honestly it’s pretty far down on the priority list right now. The one car (wife’s) garage is full of truck parts, plow truck has no fuel tanks, crew cab has no topper, camper has no cover and it’s dipping below zero already!
Speaking of cold, here’s a reminder of why I prefer gas: gelled fuel happens to someone I know almost every year.
10-24-2017, 03:15 AM | #711 |
Kind of a fun mission since this same 9,000 lbs super duty died a few years ago when I had the tired tbi 350, and smaller tires, and I could not get it up the 12% grade on packed snow to the top where it lives.
10-24-2017, 03:18 AM | #712 |
Challenge accepted. Heavy throttle at first with lots of pedaling when the tires started spinning and we made it. Should have had the go-pro going it was loud and fast and impressive.
10-24-2017, 03:22 AM | #713 | ||
Still on of my favorite trucks here! Good luck with the Winter prep.
10-24-2017, 03:25 AM | #714 |
Credit goes to the siping done to the ST Maxx tires and additional horses.
10-24-2017, 03:31 AM | #715 |
Stupid upside down roads! Here is the view from the top. Thanks Chris it would be even more impressive on its lid haha!
10-24-2017, 09:39 PM | #716 |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
11-29-2017, 06:20 PM | #718 |
I missed the specs on the cam, I am planning a similar swap into my V10
79 Corvette- 406/7004r Holley EFI 87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4 |
11-29-2017, 07:19 PM | #719 |
Does your truck have any kind of lockers? I'm worried about my truck behaving in the snow with the detroit in the back.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-30-2017, 01:08 AM | #720 |
6>8 Plugless........
Nice you're getting more work out of it! Yeah, you have to be pro active when owning a diesel for sure. Luckily we haven't stayed cold here yet. Did you have any time to look into your tcase issue yet? The siping definitely makes a big difference in the snow for sure. We switched over to tires with siping on our fleet at work since they all have the traction control you can't disable. Best thing we've done yet.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-30-2017, 11:16 AM | #721 |
Just found your thread...very nice build! Love the stance and overall truck itself.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
12-17-2017, 03:02 AM | #722 |
Thanks guys. Sorry haven’t been around much.
I’ll have to go back and look at my cam specs. Are you going to swap a gen 6 big block in? Open diffs front and rear. Needs something. I’d like a pair of true-tracs. Maybe I’ll try one out on the plow truck... Haven’t diagnosed the tcase yet. 4hi works fine so I’m rolling with it for now. We run the same tires siped on all our work trucks and they aren’t half bad in the snow. Way better than not siped!
01-01-2018, 01:55 AM | #723 |
See page 4 for shift fork info.
This is the thread I followed to rebuild mine.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
02-01-2018, 02:15 PM | #724 |
Yeah I picked up a complete swap from a 98 with 180k on it for a song, just either have to convert the 2wd 4l80 to 4wd or find another. i already picked up a np208 and adapter/mount from a 3/4 with th400/208
03-16-2018, 12:50 AM | #725 |
Hey Kacy, I still owe you cam specs.
I finally got tired of taking my crappy radiator in and out to have the shop fix the latest leak it sprung. So I went to Napa and got a part number NR 2071 Napa brand radiator coming. No more spectra Chinese radiator! They only wanted $50 for freight and the price was right. Imagine my surprise when I picked it up today and it was a spectra CU774. Same freaking part number. This one is made in Japan though and survived the trip over the pond much better with no dings. So I thought Larry had one from Canada, and now I have China and Japan covered.
