05-02-2018, 06:58 PM | #1 |
gm create motor ?
https://sdparts.com/i-19928425-gm-en...te-engine.html
looking at this for my k30 project beater . will be th400/4.10 gear / 33.30 tire height . plow truck / trailer puller / work truck / dd use . whats your guys feedback on this unit ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-02-2018, 07:10 PM | #2 |
Re: gm create motor ?
Not bad for 2k. Dunno if its original or what, but my 98 Tahoe odometer says 253k, and with 3.42s it will get up and go. Slap a carb on it and will prolly run pretty good. Thinking this might be an option when time comes to replace my motor.
05-02-2018, 07:23 PM | #3 |
Much better motor than the other crates.
Good heads, compression and better matched cam. |
05-02-2018, 08:54 PM | #4 |
I have about 45000 on mine now in the 66. Mild comp cam, super victor intake, 670 street avenger carb. I have an in tank pump with an aeromotive return style regulator. works flawless.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-02-2018, 09:09 PM | #5 |
i was planning on slapping a holley snipper on it .
the balancer and cover that comes on it have a timming pointer and marks ? i cant tell in the pics . since i will be running a hei dist with vac advance .
05-02-2018, 10:45 PM | #6 |
If you want to wake that L31 up put a HT383 Crate/Ramjet 350 cam in it - part number 14097395.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-02-2018, 11:05 PM | #7 | |
its 196.00 for the cam . . . and its on my order list .
05-02-2018, 11:12 PM | #8 |
60-66 Nut
A L31 engine with the Ram Jet 350/HT383 cam is a great running engine. It makes great torque even with the 1.5 rockers.
05-02-2018, 11:17 PM | #9 |
well with all the feedback from here i think its time to make a few calls for the best deal and get it coming . need this truck rolling soon .
05-03-2018, 06:32 AM | #10 |
I had the sniper on mine and pulled it. Had a bad habit of just shutting off going down the hiway. Go on the holley forums and go through the sniper section. They are having some issues.
Jimmy
05-03-2018, 07:02 AM | #11 |
Looking at this engine for a swap too. Just keep in mind since you are not putting this in the specified vehicle the warranty is only going to be 12 months.
Jeggs has had this on sale in for somewhere around $1850 I think. |
05-03-2018, 10:32 AM | #12 |
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
05-03-2018, 11:06 AM | #13 |
Never Ending Projects
The GM L31 engine is one of the best values out there. One piece rear main seal, roller cam and Vortec heads. Great combo as long as you can deal with it not supporting a mechanical fuel pump. You need to use a Vortec specific manifold and flex plate/flywheel for a 1 piece rear seal but outside of that, they are great.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-03-2018, 12:44 PM | #14 | |
Yes, you can do a cam swap but then that voids the warranty. |
05-03-2018, 06:24 PM | #15 | |
05-03-2018, 06:25 PM | #16 |
Put that cam in it and you'll go up to about 330 HP and 390 Ft-Lbs.
05-03-2018, 06:57 PM | #17 | |
what engine ? there is a few links in here .
05-03-2018, 09:37 PM | #18 |
L31 engine with the Ram Jet 350/HT383.
05-03-2018, 10:03 PM | #19 |
ah got ya . thats what i was planning .
05-03-2018, 11:41 PM | #20 |
check out the GMPP 350 HO Crate engine...its the same L31 Vortec, rated at 330 HP 380 ft lb torque...
72 C20 Longbed 05 1500 Z71 |
05-04-2018, 07:28 AM | #21 | |
nice option but i dont think its for me and my build. i am doing a k30 work truck and dont need to get crazy . i have other trucks for that .
05-04-2018, 11:12 AM | #22 |
Yeah, it sucks that GM put a flat tappet cam in this engine, even though it's setup for a factory roller cam.
05-04-2018, 11:37 AM | #23 |
But if you buy the L31 engine and the Ram Jet 350/HT383 cam you'll easily get that much power, but it will be in a lower power band and you'll have a roller cam.
05-04-2018, 05:40 PM | #24 |
and for a big heavy truck you need the power band lower than up top .
05-04-2018, 07:29 PM | #25 |
so do i buy the engine and run it for what it is ?
or do i . . . . buy the cam and install it then run it and say to hell with the warranty ? that is the BIG question . . . .
