Old 10-14-2017, 06:46 PM   #1
tate65
Speedo gear shaft shroud
Trying to replace the Speedo gear there is a shroud on the shaft I can't figure out how to get off. Tried to google it, but not sure what its actually called Last one I did nod not have this. It's an 1980 C20 but this is not origional trans.
photos here http://s155.photobucket.com/user/pkh...tml?sort=3&o=0
tate65 is offline   Reply With Quote
Old 10-17-2017, 07:44 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Speedo gear shaft shroud
Not sure what tranny you have but is this what your talking about? http://www.73-87.com/7387garage/drivetrain/yokeleak.htm There is an O-ring inside of it. Slide the sleeve foreword if you can to see the O-ring and remove it first, then slide It off the tail shaft. "Output shaft to slip yoke O-ring sleeve" https://www.transpartsonline.com/TRA...sPartsType=350
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-18-2017, 07:50 AM   #3
tate65
That is the part, the problem is that cup is not coming off the shaft. It will not slide I have tried a few things,gloves, leather strap both wrapping it and twisting and pulling , but I am afraid to damage it. It seems a soft "tin" so I do not want to beat it or pry it.
Old 10-18-2017, 08:46 AM   #4
Bigdav160
Bigdav160's Avatar
Plug the hole in your transmission yoke and you can throw the sleeve away. It just keeps transmission fluid from going down the splines and dripping from the weep hole in the yoke.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
