10-19-2017, 08:50 PM | #1 |
Cam help needed
I'm looking to do a vortec head swap and looking for some advice on parts. First, I'm having the heads cleaned and checked over. Aside from valve seals, anything on the heads I Need to have replaced?
I'm trying to keep the heads stock due to budget, what is the max lift of cam I can use on these heads? Any recommendations on what cam to use? The goal is to add some umph to my stock 72' 350. Looking for torque above anything. Any advice is appreciated. Thanks
1972 GMC C20 Custom Camper 350/TH350 |
10-19-2017, 10:38 PM | #2 |
Fabricate till you "puke"
Re: Cam help needed
I would suggest an XE-262 Comp cam, as the max....but do use the Comp springs suggested, with the kit...not chev stockers! .462/.469 lift, should be in the realm of the vortec heads, & the cam should have a hint of a lope @ idle, but still run a stock converter. With the vortec conversion, you will the intake swap to go, as well as the rockers. If I missed anything, the rest of the good guys can help longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-19-2017, 11:22 PM | #3 |
60-66 Nut
Re: Cam help needed
I agree with Longhorn. That will be a nice cam in a basically stock 350. Even with the recommended springs for the cam, the retainer to seal clearance should still be checked. If I remember correctly you should be able to reuse the stock Vortec retainers and locks with the 981 springs.
If all of that is just totally out of the budget, have your machinist check your retainer to seal clearance and then you will know just how much valve lift you can get away with running the stock Vortec springs. However I can tell you that going with the XE262 cam will be more impressive that what you will be stuck with running stock springs.
10-19-2017, 11:52 PM | #4 |
Re: Cam help needed
I read this article about the comp cams new beehive style springs that are made to use without machine work. Anybody heard about these? Any thoughts on them?
If I installed these, would the cam choice change? I am trying to be budget friendly, but I'm also a "do it right the first time, save money in the long run" kind of guy. https://www.summitracing.com/parts/cca-26915-16 https://www.google.com/amp/www.hotro...g-upgrade/amp/
10-19-2017, 11:53 PM | #5 |
Re: Cam help needed
Also, if it helps, I'm going to use the Edelbrock performer rpm intake. Unless you guys would suggest something that might work better with a select cam
10-20-2017, 07:11 AM | #6 |
Re: Cam help needed
I have the L31 crate engine and it is a vortec head. I have the XE-262 in the engine and ran the duel plane for a while. Now I have a super victor on it with a holley 670 street avenger and it runs really good. The duel plane suffered some issues with a couple of holes being a tad lean and the engine not liking much timing. Also had some vapor lock issues with the thunder avs eldelbrock on it. All that improved with the super victor.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-20-2017, 11:31 AM | #7 |
Re: Cam help needed
was thinking of switching to this cam but they advertise 477/480 lift. Im guessing this is a ball park figure from comp?
10-20-2017, 05:59 PM | #8 | |||
"I ain't nobody, dork."
Re: Cam help needed
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-20-2017, 07:51 PM | #9 |
Re: Cam help needed
I have the L31-R crate engine with stock cam and a Summit stage 1 duel plane intake. It doesn't like a lot of timing but it runs great. I don't believe any vortec engine likes a lot of timing from what I have read.
10-21-2017, 12:48 AM | #10 | |
60-66 Nut
Re: Cam help needed
Using the beehive springs is nothing new. But for a mild build and mild cam, they are not necessary. Plus the cost will be considerable more that just using the 981 springs that are recommended for the XE262. You did say that you were wanting to keep the heads stock due to a budget. Using the 981 springs are about as close to stock as you are going to get and still run a better cam.
10-21-2017, 10:26 AM | #11 |
Re: Cam help needed
Do you have a full part number for the 981 springs? I didn't find any suggested springs for that cam when I looked it up. Do you have to do any machine work to use those?
10-21-2017, 10:51 PM | #12 |
60-66 Nut
Re: Cam help needed
The number 981 is the part number, but if you want a full set it is 981-16. Some will say that the outside of the valve guide bosses need machined, but I have installed them without any machining. Also machine work may be necessary if there is not enough retainer to seal clearance for the lift of the cam. The machine work should not be that expensive. just talk to your machinist before you just assume. Go here and click on 'suggested parts'
https://www.summitracing.com/parts/c...38-2/overview/ Here are the springs https://www.summitracing.com/parts/cca-981-16
10-22-2017, 09:11 AM | #13 |
Re: Cam help needed
Isn't there a cheap kit to fix the .480 lift issue? I thought it was just different retainers but it may have been beehive springs and retainers.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-22-2017, 09:19 AM | #14 |
One of the First
Re: Cam help needed
I'm glad this thread popped up. I have a new crate L31 sitting on a engine stand waiting to go into 70 C30. I was contemplating a CAM change to get a little more out it. This might be the answer...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
10-22-2017, 10:51 PM | #15 |
60-66 Nut
Re: Cam help needed
Yes the beehive springs and a specific retainer will give you quite a bit more valve lift capability. Some beehive springs are $$$$ and others not so much. Some guys use a standard spring and retainer and do what is known as a 'ghetto grind' which is basically just grinding the bottoms of the retainers yourself on a bench grinder. Then there are springs, retainers and seals from Alex's Parts. But I have heard a few negative things about his springs not being what they are supposed to be.
https://www.alexsparts.com/valve-spr...rf-hyd-roller/
10-23-2017, 07:29 AM | #16 |
Re: Cam help needed
Gary the super victor for the vortec is not that big and the port shape is about a perfect match. My race engine builder does a lot of circle track stuff and a bunch of crate engines and he is the one who said try it. I had the performer RPM on it and when I tried the super victor I was surprised. He had the dyno experience to back it up and it does work.
Jimmy
