Old 08-19-2014, 07:04 PM   #1
hotrod66
hotrod66's Avatar
anyone ells have this rust issue
i have owned probably 15 of these trucks and this is a first for me. i understand why it happened i have just never seen it and the rest of the door is really solid.i sanded the whole door and sandblasted inside,along the bottom. these are the only holes in the door. once again dang you mother nature !
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 08-19-2014, 08:35 PM   #2
RANDY COX
RANDY COX's Avatar
Re: anyone ells have this rust issue
It is unusual... in that area...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-19-2014, 08:45 PM   #3
hotrod66
hotrod66's Avatar
well nothing about me is normal so i guess nether are my trucks . im not really worried if any thing its a good candidate to be come a shaved door. probably will just inject por15 with a syringe.
what would you guys do?
Old 08-19-2014, 08:54 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Personally I'd fix it with JB Kwik. I've never seen rust in that area before that I can remember.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-19-2014, 09:23 PM   #5
Clyde65
Clyde65's Avatar
I bet it was slightly damaged from the factory and just progressively got umm....worse?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-19-2014, 10:57 PM   #6
LVPhotos
LVPhotos's Avatar
Guy had big knuckles and wore it out. Drill out and tack weld, grind down.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-19-2014, 11:16 PM   #7
63burban
Chevy addict
Come to the Midwest we will show you odd places for rust. I have a couple of parts truck that have rust holes in that area. On the other hand I have a Suburban from Texas that has rust in really odd places.
63burban is offline   Reply With Quote
Old 08-19-2014, 11:26 PM   #8
Dans66Chevy
Drill those puppys out and then weld up the holes...good as new!!!!!
Dans66Chevy is offline   Reply With Quote
Old 08-20-2014, 12:23 PM   #9
61K10
61K10's Avatar
one of my doors had the same pin holes. body also had some pin holes. Had reg. rust as well.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
