Old 02-01-2017, 09:09 PM   #26
RDrancher
RDrancher's Avatar
Re: Impressed with our Burb!
Thank you!
I won't lie, I'm pretty happy and feel blessed to finally be able to do this. I've wanted a lowered Chevy for 17 years, but it didn't fit what I needed for work, or the budget and sometimes both.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 02-02-2017, 05:44 PM   #27
rusty76
rusty76's Avatar
I understand completely
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-02-2017, 05:51 PM   #28
jasonroman
jasonroman's Avatar
are you still getting the 15x6?
if so, how long till they arrive and what size tires are you going with ?
i have stock 15x6 and wondering if there are any good size tires i can put on if i ever get this thing dropped or if i should just keep looking for 8 or 10 inch rally wheels.
found a set here in jersey. but didn't drop truck yet so not sure if i should get wheels and tires before lowering it.
jasonroman is offline   Reply With Quote
Old 03-02-2017, 09:00 PM   #29
RDrancher
RDrancher's Avatar
I got a wild hair and went with 15x7's. I would have used the 6" wheels if they would have sent me four that were matching. I had the tires mounted and picked them up this afternoon. 225/75 for the front and 235/75 for the rear. You can also run either of these sizes on stock 6" wheels. I should have them mounted on the Burb this weekend and I'll take some pics.
Old 03-04-2017, 03:23 PM   #30
RDrancher
RDrancher's Avatar
I got the new tires and wheels mounted up this morning. The chrome valve caps in the pics are long gone.
The old Kellys that were on the Burb when I bought it are a ton wide than any other 235/75's I've seen before, including the new skins.
Old 03-04-2017, 05:57 PM   #31
68Timber
I know the pieces fit
68Timber's Avatar
Too cool! If it were me I'd run the spinners, I like them.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-04-2017, 06:46 PM   #32
RDrancher
RDrancher's Avatar
Thanks! I had the spinners in mind as an option with OEM wheels but I'm a little too impatient to wait for stuff on backorder when I've finally made up my mind to pull the trigger. After a bit of research I found out that Gorilla also made the right size spinners to fit Cragar Delux wheel centers so I went that direction.
Old 03-05-2017, 08:07 AM   #33
rusty76
rusty76's Avatar
Awesome I am really digging the burb.
My build thread
Crossmembers CC
Old 03-05-2017, 10:43 AM   #34
RDrancher
RDrancher's Avatar
A couple more pics.
Now that it's running much better and sitting pretty much the way I want it, the next move is to get the Burb's front end aligned.
The rear bumper is a bit tweaked and lower on the left side. No doubt this had something to do with the dent in that lower quarter panel. The drop accentuates the difference in height so I'll have to address that soon before it drives me crazy.
Old 03-05-2017, 12:15 PM   #35
rusty76
rusty76's Avatar
Dig your license plate. Lol
My build thread
Crossmembers CC
Old 03-05-2017, 12:47 PM   #36
RDrancher
RDrancher's Avatar
Yeah, Texas only had vanity YOM plates available during 1985. Standard plates used the year/month stickers. All of the vanity plates I found had weird thicker letters or numbers at random. In this case it was the C and A. I think they chose the wrong prison to get uniform painting.
The cool thing about running YOM plates is that you don't have to have the stupid registration stickers on the windshield. If you look closely there's a small tag affixed on the plate bolt up in the corner that gives the actual registration expiration info.
Old 03-05-2017, 05:57 PM   #37
rusty76
rusty76's Avatar
That's really cool. Years ago I was digging through some things and found a plate from Delaware. It was from 58 I think, and it has to be the heaviest plate I have ever seen. If it ever fell off a car it would likely go through the windshield. Really cool plate. The words seem to fit the burb.
My build thread
Crossmembers CC
Old 03-06-2017, 06:39 PM   #38
RDrancher
RDrancher's Avatar
Thanks! I think the word fits the Burb perfectly too. I was pretty stoked just to find plates that didn't have someone's name or nickname on them.
Old 03-26-2017, 12:25 PM   #39
RDrancher
RDrancher's Avatar
The alignment guy called and said that the shaft and bushings on the driver's side upper control joint were too far gone to get decent alignment. So I drove the Burb back home and finally had the time to fix it Friday afternoon. I ended up replacing both uppers (with pre-installed ball joints) since the parts store had them in stock. I hope to have time to get it back in for alignment this week.
It's been driving me nuts not being able to drive this thing around and yesterday afternoon the urge was too strong. So I packed up the wife and kids and headed out to a car show in Bowie some 40 miles away. We were late getting there and only a couple cars were left, so we ended up finding a place to eat on the square and then taking the scenic route back home.
A couple observations...
Since it's not aligned yet the steering pulls to one side a bit, but the CPP shocks and cut front coils ride real nice. The rear rides good mostly, but still needs a little tweaking. Even with 110 lbs of air in the shocks, it still (gently) bottomed out twice during the trip. Granted, both times were on transitions from freshly milled asphalt to concrete bridges in a re-paving construction zone with a full tank of fuel and a bunch of groceries, but still not what I want.
To solve the problem I can either get new rear springs and possibly still have to use 1" lift shackles, or have a notch done...just not sure which one to go with. There are no suburban notch kits available, so I'll have to find someone with better fab skills than mine if i go that route. Locally it's been hard enough finding anyone that knows how to do anything other than change parts and diagnose with a scanner. Where are all the old school guys? It's about the only thing I miss about living in SoCal. Well...that and the weather.
Old 03-26-2017, 02:18 PM   #40
rusty76
rusty76's Avatar
Keep on keeping. The old guys are still out there. We youngins just end up making do and learn. Lol
My build thread
Crossmembers CC
Old 03-26-2017, 07:30 PM   #41
Keith Seymore
Keith Seymore's Avatar
I'm here!; in fact, there's a 50/50 chance I watched your Suburban go down the assembly line.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-26-2017, 08:06 PM   #42
RDrancher
RDrancher's Avatar
K
That's cool Keith.
I was pretty surprised when the owner of the alignment place told me he would have to do the Burb himself after hours because none of the guys in his four bays know how to do an old school vehicle. I guess I'm getting old, but 1985 still seems like "new" stuff to me.
Old 04-14-2017, 10:00 PM   #43
RDrancher
RDrancher's Avatar
Nothing exciting to report, just a little fun stuff. I replaced the sticky stock steering wheel with a silver 15" California metal flake wheel from Mooneyes. I gained an inch or so of arm extension compared to the stocker which is much appreciated. I originally purchased a blue flake wheel, but it has kind of a violet pearl shade to it and the interior already has about 20 different shades of blue going on. Adding another was a bit much. While I was at it I replaced the chrome bullet door locks with a set of billet pieces and put on a matching billet shift knob and tilt column stock/knob. A billet turn signal knob was also included in the package, but I won't be using it since our Burb has cruise control.
Old 04-15-2017, 03:00 PM   #44
rusty76
rusty76's Avatar
I dig those wheels exclusively. Metal flake steering wheels are totally kool.
My build thread
Crossmembers CC
Old 04-16-2017, 09:27 PM   #45
DZL1
One day.....
DZL1's Avatar
Very cool Burb!
DZL1.
Bertha build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=733306
'72 C10 short bed. Bessie (traded)
'93 C3500 CC Dually. Bertha (traded)
‘96 C1500 ECSB. Black Beauty
'89 C1500 RCSB LS swap. Black Bean
'06 Silverado CCSB Ghost (Wifes Truck)
'12 GMC Terrain V6. Titanium Bling (Wife’s Daily)
‘14 Chevrolet Cruze. Raspberry (Daughters Ride)
'99 Jeep Wrangler. Road Hog (Sons Ride)
DZL1 is offline   Reply With Quote
Old 04-17-2017, 04:10 PM   #46
RDrancher
RDrancher's Avatar
Thanks folks!
We had a great Resurrection Sunday yesterday and I got a little seat time in the Burb, but of course I wanted more. Woke up this morning to rain with more on the way. Whoo-hoo! My jobsites were too wet to work, so I finished up a couple of proposals early, loaded up the wife and little one and headed for a back country cruise.
Hard to see, but just behind the Burb on the edge of the tree line sits an abandoned '64-'66 shortbed fleetside.
The road followed the property and when I was trying to locate the fleetside from the other side through the trees, I see this.
Once again, hard to see but behind the 4-door Impala sits a 70's C10 or C20 buried in the trees.
I was going to check things out a bit more, but the skies opened up so I high-tailed it back to the Burb. The house and property look abandoned, but we located the address on the old mailbox so my wife will do some checking and find out the status of all the cool old stuff there.
Old 04-17-2017, 05:27 PM   #47
rusty76
rusty76's Avatar
Love the pics. Looking good.
My build thread
Crossmembers CC
Old 05-03-2017, 06:29 PM   #48
RDrancher
RDrancher's Avatar
The wife and I headed out this afternoon for another backroads cruise.
We've been taking pics of old homes, barns and out buildings for quite a few years.
Crossing the highway we stopped to check out this historical marker. I've driven by this one hundreds of times at 70mph and never noticed it before.
A cold front blasted through today and dropped the temps about 20*. We saw several snakes out trying to soak up leftover blacktop heat. This one is about a three and a half foot long chicken snake.
I met the owner of this fine specimen yesterday. He just got it back from the upholstery shop. It has a 502 crate motor under the hood.
Old 05-22-2018, 10:01 PM   #49
RDrancher
RDrancher's Avatar
Hey, I just noticed that my photos are back up. Cool. Not much to update really. My business has been so hectic that I haven't really done much with the Burb. It doesn't look right with the amount of air in the rear shocks that it takes to not bottom out. Gotta get a notch. I did get sick of looking at the peeling black stuff on the wind deflector so I spent some time on Sunday removing it along with the old adhesive. That was fun...not.
When we got the Burb I started collecting old travel decals from the states and places we've been, both the vintage water transfer type and repop vinyl. My plan was to keep on pasting one after another on the deflector until there's no room left and then layer 'em on there after. For some reason the repop folks make the new stickers either larger or smaller than the originals. I don't get it. These are the larger version. I like the idea, but their size doesn't really go with the curve of the deflector so I'm not sure they'll stay. I'll probably try the smaller stickers.
Old 05-23-2018, 05:47 PM   #50
rusty76
rusty76's Avatar
Cool to see some pics and updates. I’m a sticker junkie. Lol.
My build thread
Crossmembers CC
