Old 04-23-2020, 10:26 PM   #1
1977ChevGMCK2025Fan
Transfer Case Wire Question
I have a 1978 K25 that was a TH350/NP203. It was converted to a TH400/NP205. My question is what is the purpose of the wire that went to the 203-a dash indicator? If so, is there a spot on the 205 for this wire; or should I remove it?
Thanks,
Marvin
1977ChevGMCK2025Fan is offline   Reply With Quote
Old 04-23-2020, 11:39 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Transfer Case Wire Question
If it’s the same wire I’m thinking about, it was used to indicate on the dash that the truck was in 4x4. The eary 205s dont have this feature but I believe the later 73+ cases had the option for the light, I don’t believe all the later cases got the light/switch though. I do know the 4x4 shift rail is different between the cases with the light switch and with out. Any idea approximately what year your 205 is?
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-23-2020, 11:42 PM   #3
1977ChevGMCK2025Fan
It’s a later 205, somewhere between 83-87 l believe.
Thanks for the reply!
Last edited by 1977ChevGMCK2025Fan; 04-24-2020 at 12:06 AM. Reason: Spelling error
Old 04-24-2020, 12:33 AM   #4
franken
The switch goes in the shift rail detent spring/ball/plug hole. I have a 205 with switch on the bench now. I'm not sure the switches are available. Might try a micro-switch on the linkage somewhere.
I googled it...
https://torqueking.com/product/30048...icator-switch/
Old 04-24-2020, 08:45 AM   #5
1977ChevGMCK2025Fan
Thanks Franken. It looks like I need to go searching for the male plug in wire. This will probably be hard to locate as 205s are not near as common as 203s.
Marvin
Old 04-25-2020, 10:38 AM   #6
burnin oil
It looks like A standard GM weather pack connection. I would just buy a switch and go to the junkyard. It looks about like the under hood plugs from an 88 up TBI truck.
burnin oil is offline   Reply With Quote
