05-05-2017, 11:05 AM | #1 |
81 bed swap question.
I am new to the forum. I have 2 81 pickups. ! fleet side 1 step side. I want to put the step side bed on the fleet side chassis. My question is are they interchangeable?
Thanks in advance. |
05-05-2017, 11:12 AM | #2 |
Re: 81 bed swap question.
i didnt have any problems on my 84
05-05-2017, 12:30 PM | #3 | |
Assuming they are the same wheelbase (ie, both SWB or LWB); the only changes required might be the gravel shields over the rear bumper. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-05-2017, 12:58 PM | #4 |
same wheelbase. what about the gas tank?
05-05-2017, 01:18 PM | #5 |
81-87 should match without any problem as long as wheel base are same length and fuel tanks are on same side? Is that correct?
05-05-2017, 02:45 PM | #6 |
Yes the side tank will line up with the step side. Only problem is if you have dual tanks. you will have to make sure your pass fender has a gas cap door in it.
05-05-2017, 03:55 PM | #7 |
Is there a way to unplug the bed harness? if so where?
Thanks |
05-06-2017, 06:41 AM | #8 |
If I remember correctly the harness follows the frame rail to the back . No need to do anything there and just remove the tail lights and remove the socket and harness and drop it down on both sides and you done . You will see when you get in there .
05-08-2017, 09:34 AM | #9 |
The harness does unplug in the bumper. The bolt holes for the bolts holding the bed will line up??
