05-08-2017, 07:12 PM | #1 |
Drop spindles w/original ball joints - cotter key hole?
I am putting a set of Early Classics 2.5" drop spindles on my 71 c10. I got the spindles off craigslist and I'm reusing my ball joints. When I went to put them on, I noticed that the mounts of the spindles are about 1/2" thinner than the originals. This results in the ball joint nuts being well below the cotter key holes. What do I do? Do I drill new holes? Do I put 1/2" of washer under the nuts? Neither sound totally great but I'll trust you're advice!
Thanks!
Curtis - Berea, KY 1969 1/2 ton 2WD CST 1971 1/2 ton 2WD Shortbed 1977 Mercedes 450SL 1966 International Scout |
05-08-2017, 09:12 PM | #2 |
67-72 parts collector,…
Re: Drop spindles w/original ball joints - cotter key hole?
I think you have the wrong spindles.
Balljoints have to match the year of the spindle. So does the outer tie rod. 63-70 spindles are typically smaller than the 71-72 or 73-87 spindles. Any idea what year these spindles are for? I bet those are 73-87 spindles. Larger tapered hole. Your upper balljoint falls thru too far. But the lowers fit, because 71-72 and 73-87 trucks use the same lower balljoint. How's the outer tie rod fit?
05-08-2017, 10:02 PM | #3 | ||
The spindles have some numbers on the back but I don't know if they mean anything. The right has 50505 and the left has 8053 (or maybe B053). This is crappy news. I've been taking it slow and cleaning and getting all the parts together. Now I need to get it done by this weekend and I discover the main part is wrong....
05-08-2017, 10:21 PM | #4 |
Man that does stink! If I were you I'd remove the ball joints and bring the spindle into your local auto parts store and check different ball joints. One should be a nice tight fit.
05-08-2017, 10:24 PM | #5 |
I would just change the upper ball joints, not a big deal. Get one for '73 and up. But, if you need outer tie rod ends as well, you need to get the front realigned......So, more parts, more time - welcome to the world of vintage iron
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
05-08-2017, 10:39 PM | #6 | |
You can now buy 60-62, 63-70, 71-72, and two different 73-87 spindles. These trucks have been around a long time and most have gone though a lot of changes.
