01-02-2018, 07:25 PM | #1 |
Build sheets
Does anyone reproduce build sheets based on what our trucks have as far as acessories etc?
Thanks |
01-03-2018, 10:36 AM | #2 |
Re: Build sheets
First pic is of a "build sheet"; second pic is of a "SPID label" (Service Parts ID label).
If you are asking about the SPID label: Site member Chipflyer (Jeff) from http://outintheshop.com/ can reproduce those with whatever RPO content you give him. If you are actually asking about the build sheet (provided from the GM assembly plant): those are not reproduced. You'd have to make your own based on samples that you can find on the forums. The format will vary based on final assembly location. Much of the information on the build sheet does not exist anywhere else, so you'd have to guess/fudge/make stuff up. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-03-2018 at 03:38 PM. |
01-03-2018, 07:29 PM | #3 |
Re: Build sheets
Thanks Keith. I was checkin more for another member but I would like to have a SPID for mine.
